Oil Temperature
12-20-2007, 06:51
Oil Temperature
Anyone know where the oil temp sensor is located. Need to know what
the temp guage is reading. After a long idle checking flow on radiator, I have a reading of 170F on guage and 150F on the oil pan. Which is more likely the accurate temperature? R.e. (Ron) Marabito, Dallas, TX 92WB40 |
12-20-2007, 07:21
Oil Temperature
You CANNOT get a diesel up to temp by idleing it>you will do it no good!
Pete -------------- Original message -------------- From: "ronmarabito2002" Anyone know where the oil temp sensor is located. Need to know what the temp guage is reading. After a long idle checking flow on radiator, I have a reading of 170F on guage and 150F on the oil pan. Which is more likely the accurate temperature? R.e. (Ron) Marabito, Dallas, TX 92WB40 [Non-text portions of this message have been removed] |
12-20-2007, 07:29
Oil Temperature
Mine is located on top of the oil filter housing on the road side of the engine.
I would guess both are probably close because of where the temperatures are measured. swag!!! Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion ronmarabito2002 know where the oil temp sensor is located. Need to know what the temp guage is reading. After a long idle checking flow on radiator, I have a reading of 170F on guage and 150F on the oil pan. Which is more likely the accurate temperature? R.e. (Ron) Marabito, Dallas, TX 92WB40 --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. [Non-text portions of this message have been removed] |
12-20-2007, 09:52
Oil Temperature
Both are accurate and relative to a monitored change. the 170 may be
reading closer to the friction and thus a quicker indicator of stress. the pan may be the last place oil temp signals friction stress, the metal pan may also lose heat to the cast block. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > Anyone know where the oil temp sensor is located. Need to know what > the temp guage is reading. After a long idle checking flow on > radiator, I have a reading of 170F on guage and 150F on the oil pan. > Which is more likely the accurate temperature? > > R.e. (Ron) Marabito, Dallas, TX 92WB40 > |
12-20-2007, 10:06
Oil Temperature
But, do you know where the sensor is located?
R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Both are accurate and relative to a monitored change. the 170 may be > reading closer to the friction and thus a quicker indicator of stress. > the pan may be the last place oil temp signals friction stress, the > metal pan may also lose heat to the cast block. > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > Anyone know where the oil temp sensor is located. Need to know what > > the temp guage is reading. After a long idle checking flow on > > radiator, I have a reading of 170F on guage and 150F on the oil pan. > > Which is more likely the accurate temperature? > > > > R.e. (Ron) Marabito, Dallas, TX 92WB40 > > > |
12-20-2007, 15:09
Oil Temperature
Its up above the starter closer to the tranny remote mounted. some
may be hooked up to the oilfilter housing GregroyO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > But, do you know where the sensor is located? > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > Both are accurate and relative to a monitored change. the 170 may be > > reading closer to the friction and thus a quicker indicator of stress. > > the pan may be the last place oil temp signals friction stress, the > > metal pan may also lose heat to the cast block. > > GregoryO'Connor > > 94ptRomolandCa > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > > > > Anyone know where the oil temp sensor is located. Need to know what > > > the temp guage is reading. After a long idle checking flow on > > > radiator, I have a reading of 170F on guage and 150F on the oil pan. > > > Which is more likely the accurate temperature? > > > > > > R.e. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > |
12-21-2007, 03:38
Oil Temperature
Thanks for the location Greg.
R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Its up above the starter closer to the tranny remote mounted. some > may be hooked up to the oilfilter housing > > GregroyO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > But, do you know where the sensor is located? > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > > > Both are accurate and relative to a monitored change. the 170 may > be > > > reading closer to the friction and thus a quicker indicator of > stress. > > > the pan may be the last place oil temp signals friction stress, > the > > > metal pan may also lose heat to the cast block. > > > GregoryO'Connor > > > 94ptRomolandCa > > > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > > > > > > > Anyone know where the oil temp sensor is located. Need to know > what > > > > the temp guage is reading. After a long idle checking flow on > > > > radiator, I have a reading of 170F on guage and 150F on the oil > pan. > > > > Which is more likely the accurate temperature? > > > > > > > > R.e. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > > > |
