					Adding auxiliary air
					11-21-2007, 08:01
					My '86 PT-40 did not come with an auxiliary air compressor. I'd like
			to add one. Any thoughts on how one might go about this? Would be really nice if I could just buy that "option" from Blue Bird or elsewhere and add it as if it were factory. If not, I can rig something up, but could use advice on where to mount the thing and how to properly tie in with the air system, etc. -Ryan '86 PT-40 8V92  |
					11-21-2007, 12:09
					Hi Ryan,
			I might be wrong, but I think the aux air compressor was used primarily just for the air flush toilet, and the air dump valves...Curt?? Kevin McKeown Yorba Linda, CA 1986 38' PT (For Sale) **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-product...0000000001) [Non-text portions of this message have been removed]  |
					11-22-2007, 02:47
					On mine the aux air compressor provides air to the air dump valves, the brake
			system and the aux air tank. There is a separate compressor and tank for the air toilet. Leroy krminyl@... wrote: Hi Ryan, I might be wrong, but I think the aux air compressor was used primarily just for the air flush toilet, and the air dump valves...Curt?? Kevin McKeown Yorba Linda, CA 1986 38' PT (For Sale) **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-product...0000000001) [Non-text portions of this message have been removed] Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Dahlonega, GA --------------------------------- Get easy, one-click access to your favorites. Make Yahoo! your homepage. [Non-text portions of this message have been removed]  |
					11-22-2007, 03:40
			Pete Masterson, Author of Book Design and Production: A Guide for Authors and Publishers Aeonix1@... Aeonix Publishing Group http://www.aeonix.com =============================================== On Nov 21, 2007, at 11:09 PM, krminyl@... wrote: > Hi Ryan, > > I might be wrong, but I think the aux air compressor was used > primarily just > for the air flush toilet, and the air dump valves...Curt?? > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT (For Sale) > > > > **************************************Check out AOL's list of > 2007's hottest > products. > (http://money.aol.com/special/hot-products-2007? > NCID=aoltop00030000000001) > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > >  |
					11-22-2007, 05:45
					Two different systems on my '95.  I have the Microphor air tank
			dedicated to flush and an auxiliary compressor for dump valves, air suspension, etc. Tom McCarthy 95 PT42 Poway CA --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > Hi Ryan, > > I might be wrong, but I think the aux air compressor was used primarily just > for the air flush toilet, and the air dump valves...Curt?? > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT (For Sale) > > > > **************************************Check out AOL's list of 2007's hottest > products. > (http://money.aol.com/special/hot-products-2007? NCID=aoltop00030000000001) > > > [Non-text portions of this message have been removed] >  |
					11-22-2007, 23:55
					Ryan:
			I had an 86 PT40 and the first question that comes to mind is do you really need it. Here is why I thought I needed an aux compressor. Did not want to start engine: 1. To use the water line blow out when winterizing 2. To raise the suspension for an early am departure 3. To re position the driver or pax chair 4. To raise the suspension in order to work under coach I know a couple of guys that got a 150 PSI pancake compresser from Sears, threw away the tank, and mounted it in the aft street side bay. They used some isolation mounts to limit vibration and plumbed into the input side of the air dryer. One would need a feed back circuit to turn off the pump once the desired air pressure has been reached in the air system. I guess it might be a big deal if there was sometime you wanted air pressure without starting the engine--if you install an air toilet for instance. To make a long story short, I did not do it, mainly because I didn't want to give up space in that bay. Regards, Jim Scoggins >  |
					11-23-2007, 04:17
					I have no need for 1, 3, or 4, but number 2 is a big one for us. I never like to
			sit in an RV Park with an engine running longer than necessary, and I very much hate listening to low-air buzzers! I start my departure morning (which is almost never early!) with block heater and air compressor. That combo means that I can release the brake and drive away as soon as I have oil pressure. Items that are also important to us where the compressor is handy are: Dump valves (frequently, due to washer/dryer) and oil top-up (infrequently). In short, the aux compresson is one of the many things I didn't have in my SOB that I greatly appreciate in the Bird! Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 11/23/2007 at 11:55 AM scoggins_jim wrote: >Ryan: >I had an 86 PT40 and the first question that comes to mind is do you >really need it. > >Here is why I thought I needed an aux compressor. Did not want to >start engine: >1. To use the water line blow out when winterizing >2. To raise the suspension for an early am departure >3. To re position the driver or pax chair >4. To raise the suspension in order to work under coach > >I know a couple of guys that got a 150 PSI pancake compresser from >Sears, threw away the tank, and mounted it in the aft street side bay. >They used some isolation mounts to limit vibration and plumbed into >the input side of the air dryer. One would need a feed back circuit >to turn off the pump once the desired air pressure has been reached >in the air system. > >I guess it might be a big deal if there was sometime you wanted air >pressure without starting the engine--if you install an air toilet >for instance. > >To make a long story short, I did not do it, mainly because I didn't >want to give up space in that bay. > >Regards, >Jim Scoggins  |
					11-24-2007, 02:07
					Ryan, on my return to Texas last Dec, temps were close to zero. I found  that
			at those cold temps, air leaks seem to abound in my coach. One particular leak was in the air throttle. I finally took a heat gun and warmed that up. So, don't feel that you are alone in the cold weather driving. My air, also. took forever to build up. Ernie Ekberg 83PT40 Weatherford, Tx ---glad to be where things aren't that cold, yet **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-product...0000000001) [Non-text portions of this message have been removed]  |
					11-24-2007, 07:01
					Thanks, folks, for the continued replies on this topic.
			Jim: There are a few reasons I want to add the auxiliary air. One you mentioned - raising the suspension before starting the engine. Don also mentioned the oil top off, which I check before leaving and would rather not turn the engine on and wait for air to build, and the annoying low air buzzer which takes a few minutes after every engine start to go away. I'd also like the ability to run air tools off the coach when parked without the engine running. One of the most important reasons for me, however, came to surface last weekend: We tried to leave from a family's house and the cold weather (28 degrees) seemed to have an effect on our air system because we were unable to build air at a normal rate. Ralph Fullenwider graciously accepted my emergency phone call for help and gave me some advice but in the end we wound up running the engine over 2 hours on high idle to build up enough pressure to leave. On the freeway pressure dropped to 70psi several times after braking and took quite some time to build back up, which caused me quite a bit of concern. Once we got into warmer temperatures, pressure jumped to 120 and stayed there. My assumption is there are leaks in the system and/or there was a problem with the pop-off valve or it's heater as Ralph suggested. I'm going to go through the coach and R&R the entire air system before going out of town again, but had we an aux compressor, we would have been able to assist the engine compressor enough to build up air and leave earlier. I like the idea of an emergency supplemental air source on board. -Ryan '86 PT-40 8V92 On Nov 23, 2007 8:17 AM, Don Bradner > > I have no need for 1, 3, or 4, but number 2 is a big one for us. I never > like to sit in an RV Park with an engine running longer than necessary, and > I very much hate listening to low-air buzzers! > > I start my departure morning (which is almost never early!) with block > heater and air compressor. That combo means that I can release the brake and > drive away as soon as I have oil pressure. > > Items that are also important to us where the compressor is handy are: Dump > valves (frequently, due to washer/dryer) and oil top-up (infrequently). > > In short, the aux compresson is one of the many things I didn't have in my > SOB that I greatly appreciate in the Bird! > > Don Bradner > 90 PT40 "Blue Thunder" > Eureka, CA  |
					11-24-2007, 07:26
					Ryan,
			On our first Blue Bird..an 84 FC, we had an extra valve installed to raise the rear air bags b another 8" to permit us to get up a very steep driveway. The new bags, valve and control switch on the dash were kindof pricey but it came in handy more than once. Brad Barton 00LXiDFWbbartonwx@... _________________________________________________________________ Share life as it happens with the new Windows Live.Download today it's FREE! http://www.windowslive.com/share.html?oc...ife_112007 [Non-text portions of this message have been removed]  |
