Water Pump was: Re: LXi headlight surround/bumper
10-17-2007, 04:47
Rebuild kits are available for most of the water pumps -- you may
only need to clean the interior of the pump and replace the diaphragm. Both my pumps were leaking badly -- and considering the amount of work to remove, rebuild, and replace them I opted instead to replace both pumps with a single variable (5.9 gpm) speed pump. It eliminates the need for the pressure tank as well -- simplifying the plumbing considerably. Several 'bird owners have made this modification, at least one left the pressure tank in place which does reduce the amount of cycling by the pump. I've had the new pump in operation for more than 6 months and I'm very satisfied with it. It provides a maximum 65 lbs of pressure, giving much improved water flow, especially for a shower. It does use up the fresh water tank a bit faster. (The Microphor toilet prefers a max of 50 lbs pressure -- I plan to install a pressure limiter on the water line to the Microphor in the near future.) Can't directly address your toilet compressor -- but I have a Microphor compressor just for the toilet. It's a 12 v compressor with about a 4 gal pancake tank. It's set to a maximum of 90 psi and kicks in at 60 psi. You might be able to find something similar that's not OEM. I do not have an auxiliary compressor for other air-powered systems which is annoying for dumping the waste tanks when parked for long periods. (I carry a "contractors" compressor for that purpose and to top up the air in my tires.) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Idaho Springs, CO On Oct 16, 2007, at 7:43 PM, brad barton wrote: > <snip> > I have to replace the "A" water pump and toilet compressor. I > assume I'll go back with OEM parts unless anyone has a better > idea. Brad Barton 00LXiDFWbbartonwx@... |
10-17-2007, 05:21
Brad,
I also removed the 2 shurflo's and the accumlator and installed one Shurflo Extreme Series "Smart Sensor" 5.7 gpm pump and am very satisfied. I agree with everything Pete said about it. The installation is simple with water input/output and power; eliminating the original rat's nest of plumbing is very satisfying. Plus, the pump powers up on-demand - no more random water pump noise. Turn the faucet on just a crack, and the pump makes a constant whisper - no more cycling. On the LXi, the Microphor toilet compressor is also used for the slide seal. The compressor pump is stand-alone and is plumbed into a 10 gallon storage tank. I replaced mine with an original unit from BlueBird. I also installed a filter from Clippard, part number MMFRS-3Q. The filter was installed on the storage tank output. I find that my Microphor toilet pressure regulator works better (lasts longer) if it gets clean air. David Brady '02 LXi, NC Pete Masterson wrote: > > Rebuild kits are available for most of the water pumps -- you may > only need to clean the interior of the pump and replace the diaphragm. > > Both my pumps were leaking badly -- and considering the amount of > work to remove, rebuild, and replace them I opted instead to replace > both pumps with a single variable (5.9 gpm) speed pump. It eliminates > the need for the pressure tank as well -- simplifying the plumbing > considerably. Several 'bird owners have made this modification, at > least one left the pressure tank in place which does reduce the > amount of cycling by the pump. > > I've had the new pump in operation for more than 6 months and I'm > very satisfied with it. It provides a maximum 65 lbs of pressure, > giving much improved water flow, especially for a shower. It does use > up the fresh water tank a bit faster. (The Microphor toilet prefers a > max of 50 lbs pressure -- I plan to install a pressure limiter on the > water line to the Microphor in the near future.) > > Can't directly address your toilet compressor -- but I have a > Microphor compressor just for the toilet. It's a 12 v compressor with > about a 4 gal pancake tank. It's set to a maximum of 90 psi and kicks > in at 60 psi. You might be able to find something similar that's not > OEM. > > I do not have an auxiliary compressor for other air-powered systems > which is annoying for dumping the waste tanks when parked for long > periods. (I carry a "contractors" compressor for that purpose and to > top up the air in my tires.) > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at Idaho Springs, CO > > On Oct 16, 2007, at 7:43 PM, brad barton wrote: > > > <snip> > > I have to replace the "A" water pump and toilet compressor. I > > assume I'll go back with OEM parts unless anyone has a better > > idea. Brad Barton 00LXiDFWbbartonwx@... > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.488 / Virus Database: 269.14.13/1074 - Release Date: 10/16/2007 2:14 PM > [Non-text portions of this message have been removed] |
10-17-2007, 13:15
Pete and Dave,
Thanks for the info. I think Ryan at Mr. Olivers is planning to replace the A pump and the microphor 12V compressor w/ identical units. Maybe not an improvement but I like the idea of lower water pressure except when the better half is taking a shower. First granddaughter arrived at 1:02 P.M. She'll take her first Blue Bird ride at Christmas. Brad Barton 00LXiDFWbbartonwx@... _________________________________________________________________ Climb to the top of the charts! Play Star Shuffle: the word scramble challenge with star power. http://club.live.com/star_shuffle.aspx?i...xtlink_oct [Non-text portions of this message have been removed] |
