					camera problems
					09-20-2007, 11:44
				camera problems
					hello group. I too am having problems. My backup camera is operating
			intermitently... which means it won't work when I need it! I have eliminated the camera and monitor as the problem. A while back I thought I read a discusion about a relay or sum such in the overhead between the switch and the monitor.. can anybody recall or steer me in the right direction? Thanks! Rob Sargent 85pt36.  |
					09-20-2007, 13:04
				camera problems
					Rob if ultimately you need a new system then I recommend you contact Tim at
			rvcams.com He has great prices, service and has supplied several of us with colour systems. You can even use your existing coax if you can live without sound. On 20/09/2007, aokkoa2003 > > hello group. I too am having problems. My backup camera is operating > intermitently... which means it won't work when I need it! I have > eliminated the camera and monitor as the problem. A while back I > thought I read a discusion about a relay or sum such in the overhead > between the switch and the monitor.. can anybody recall or steer me in > the right direction? Thanks! Rob Sargent 85pt36. > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed]  |
					09-20-2007, 13:21
				camera problems
					Rob,
			Check the solder joints on the monitor boards. Howard T. ----- Original Message ----- From: Rob Robinson To: WanderlodgeForum@yahoogroups.com Sent: Thursday, September 20, 2007 9:04 PM Subject: Re: [WanderlodgeForum] camera problems Rob if ultimately you need a new system then I recommend you contact Tim at rvcams.com He has great prices, service and has supplied several of us with colour systems. You can even use your existing coax if you can live without sound. On 20/09/2007, aokkoa2003 > > hello group. I too am having problems. My backup camera is operating > intermitently... which means it won't work when I need it! I have > eliminated the camera and monitor as the problem. A while back I > thought I read a discusion about a relay or sum such in the overhead > between the switch and the monitor.. can anybody recall or steer me in > the right direction? Thanks! Rob Sargent 85pt36. > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.485 / Virus Database: 269.13.21/1010 - Release Date: 9/15/2007 7:54 PM [Non-text portions of this message have been removed]  |
					09-21-2007, 04:05
				camera problems
					Bob
			I have the same coach as you. Mine does have a small relay in the front overhead. Mine is over the top of the CB radio. Is mine "factory"? I don't know There is a backup camera trigger lead in that overhead load center. It's activated by turning on the ignition. That lead operated the relay I mentioned . If you need guidence let me know. I've hand traced the wiring for the backup camera. Art Weatherly Riverside Ca '85 PT36 --- In WanderlodgeForum@yahoogroups.com, "aokkoa2003" > > hello group. I too am having problems. My backup camera is operating > intermitently... which means it won't work when I need it! I have > eliminated the camera and monitor as the problem. A while back I > thought I read a discusion about a relay or sum such in the overhead > between the switch and the monitor.. can anybody recall or steer me in > the right direction? Thanks! Rob Sargent 85pt36. >  |
					09-22-2007, 02:21
				camera problems
					thanks to all who responded to my problem post.. in the next few days i
			will get a chance to explore those thoughts, and let you'all know the results. Rob Sargent 85pt36.  |
					09-22-2007, 04:01
				camera problems
					I'm thinking about replacing our setup with a color camera and color LCD.  I
			find the low contrast B&W image to be almost useless much of the time. Anyone have experience doing that and recommendations on cameras and LCDs? Thanks! Greg Young '86 PT40 Escondido, CA ----- Original Message ---- From: amweath To: WanderlodgeForum@yahoogroups.com Sent: Friday, September 21, 2007 9:05:23 AM Subject: [WanderlodgeForum] Re: camera problems Bob I have the same coach as you. Mine does have a small relay in the front overhead. Mine is over the top of the CB radio. Is mine "factory"? I don't know There is a backup camera trigger lead in that overhead load center. It's activated by turning on the ignition. That lead operated the relay I mentioned . If you need guidence let me know. I've hand traced the wiring for the backup camera. Art Weatherly Riverside Ca '85 PT36 --- In WanderlodgeForum@ yahoogroups. com, "aokkoa2003" > > hello group. I too am having problems. My backup camera is operating > intermitently. .. which means it won't work when I need it! I have > eliminated the camera and monitor as the problem. A while back I > thought I read a discusion about a relay or sum such in the overhead > between the switch and the monitor.. can anybody recall or steer me in > the right direction? Thanks! Rob Sargent 85pt36. > [Non-text portions of this message have been removed]  |
					09-22-2007, 04:21
				camera problems
					Greg,
			You will get a lot of good input on this topic. I'll forward the notes that I made when upgrading our camera system. On 9/22/07, Greg Young > > I'm thinking about replacing our setup with a color camera and color > LCD. I find the low contrast B&W image to be almost useless much of the > time. Anyone have experience doing that and recommendations on cameras and > LCDs? > > Thanks! > Greg Young > '86 PT40 > Escondido, CA > > ----- Original Message ---- > From: amweath > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, September 21, 2007 9:05:23 AM > Subject: [WanderlodgeForum] Re: camera problems > > Bob > > I have the same coach as you. Mine does have a small relay in the > front overhead. Mine is over the top of the CB radio. Is > mine "factory"? I don't know There is a backup camera trigger lead in > that overhead load center. It's activated by turning on the ignition. > That lead operated the relay I mentioned . If you need guidence let me > know. > I've hand traced the wiring for the backup camera. > > Art Weatherly > Riverside Ca > '85 PT36 > > --- In WanderlodgeForum@ yahoogroups. com, "aokkoa2003" > > > > > hello group. I too am having problems. My backup camera is operating > > intermitently. .. which means it won't work when I need it! I have > > eliminated the camera and monitor as the problem. A while back I > > thought I read a discusion about a relay or sum such in the overhead > > between the switch and the monitor.. can anybody recall or steer me > in > > the right direction? Thanks! Rob Sargent 85pt36. > > > > [Non-text portions of this message have been removed] > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed]  |
