Dometic refir not cooling well
09-03-2007, 05:23
Post: #21
Scott,
I replaced mine with an O/E BB replacement fan. The other fellows that used the
electronic fans have a good idea that I didn't consider. No more power than the
computer fans draw I could see having 2 or 3 seperately wired with power from
the fan switch but with different rated thermostats say 85 degree, 100 degrees
and 110 degrees this should work quite well.
Howard
Sent: Monday, September 03, 2007 9:41 AM
Subject: [WanderlodgeForum] Re: Dometic refir not cooling well
I found the thermostat, but looks like the fan has been removed.
Scott
--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt"
> Scott,
> It should be behind the outside vent to the back of your frig.
> Howard
> From: Scott Forman
> Sent: Sunday, September 02, 2007 6:31 PM
> Where is the refir fan if I have one?
> Scott
> > Scott,
> > You don't mention what setting it's on so I will assume 5. Do
you
> have a refrigerator fan and is it working? I replaced my fan and
that
> dropped my temps about 8 degrees when it comes on. There is a 110
> degree thermostat in line to the fan. You can heat it with a long
> butane charcoal lighter to get it on. Look up just inside the
swing
> up door to the back of the refrig.
> > Have you had it cleaned and serviced. Check the exhaust on the
roof
> for blockage. Mine cools best when I run it on gas. I start off
on
> three and move up one at a time. On #4 I run 0 in freezer and 35
in
> refrig. At least I did yesterday.
> > When I first got my coach the frig. would not cool a cousin
told me
> to run it on gas for four or five days and after four days it
started
> cooling it's been working since.
> > Check the cooling coils to be sure they are not blocked.
> > Howard T.
> > From: Scott Forman
> > Sent: Sunday, September 02, 2007 11:48 AM
> > Subject: [WanderlodgeForum] Dometic refir not cooling well
> > My Dometic refir is no cooling well, will only get down to
about
> 48-50
> > degrees. The freezer works fine. Seems to make no difference on
> gas
> > vs electric. Ideas?
> > Scott Forman
> > 86 PT38
> > Memphis
> > No virus found in this incoming message.
> > Checked by AVG Free Edition.
> > Version: 7.5.476 / Virus Database: 269.12.10/977 - Release
Date:
> 8/28/2007 4:29 PM
> > [Non-text portions of this message have been removed]
> Version: 7.5.476 / Virus Database: 269.12.10/977 - Release Date:
8/28/2007 4:29 PM
Version: 7.5.476 / Virus Database: 269.12.10/977 - Release Date: 8/28/2007
4:29 PM
09-03-2007, 07:27
Post: #22
Well, I went and picked up a 4.7" computer fan from Radio Shack and
have wired it directly to the 'Refir Fan' switch in the coach. It is
running now and I have turned the refir back on, we'll see if she
cools. It is starting from ambient temp above 90, so I expect it
will be at least 24 hrs before I see if the fan had any effect or
not. I will post my results.
Scott
> Scott,
that used the electronic fans have a good idea that I didn't
consider. No more power than the computer fans draw I could see
having 2 or 3 seperately wired with power from the fan switch but
with different rated thermostats say 85 degree, 100 degrees and 110
> Howard
> From: Scott Forman
> Scott
> > Scott,
> > Howard
> > From: Scott Forman
> > Scott
> > wrote:
> > > Scott,
> you
> that
110
long
> swing
> roof
> on
35
> in
> told me
> started
> > > Howard T.
> > > From: Scott Forman
> about
> > 48-50
on
> > gas
> > > vs electric. Ideas?
> > > Scott Forman
> > > 86 PT38
> > > Memphis
> Date:
> > 8/28/2007 4:29 PM
Date:
> 8/28/2007 4:29 PM
8/28/2007 4:29 PM
09-03-2007, 07:34
Post: #23
Another thing to do and maybe it's been mentioned before, is to add one or
two little fans inside the frig., the double D battery squirrel cage ones
that Camping World sells. With these fans it's good to leave a little space
along the frig. sides for the air to circulate. The batteries will last 35 -
40 days.
> Scott
> "Howard O. Truitt"
> > Scott,
> > Howard
> > From: Scott Forman
> > Scott
> "Howard O. Truitt"
> > wrote:
> > > Scott,
> > > Howard
> > > From: Scott Forman
> > > Scott
> > > --- In
> "Howard O. Truitt"
> > > wrote:
> > > > Scott,
> > you
> and
> > that
> 110
> long
> > swing
> the
> > roof
> > on
> 35
> > in
> > told me
> > started
> > > > Howard T.
> > > > From: Scott Forman
> > about
> > > 48-50
> on
> > > gas
> > > > vs electric. Ideas?
> > > > Scott Forman
> > > > 86 PT38
> > > > Memphis
> > Date:
> > > 8/28/2007 4:29 PM
> Date:
> > 8/28/2007 4:29 PM
> 8/28/2007 4:29 PM
Curt Sprenger
Anaheim Hills, CA
09-03-2007, 08:11
Post: #24
I also picked up one of those on eBay this morning, I will try that
as a variable as well.
Scott
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
one or
cage ones
little space
last 35 -
> 40 days.
is
> > Scott
> > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > "Howard O. Truitt"
> > wrote:
> > > Scott,
fellows
110
> > > Howard
> > > From: Scott Forman
> > > To: WanderlodgeForum@yahoogroups.com 40yahoogroups.com>
> > > Scott
> > "Howard O. Truitt"
> > > wrote:
> > > > Scott,
> > > > Howard
> > > > From: Scott Forman
> > > > Scott
> > "Howard O. Truitt"
> > > > wrote:
> > > > > Scott,
Do
> > > you
> > and
> > > that
> > 110
> > long
> > > swing
> > the
> > > roof
off
> > > on
> > 35
> > > in
> > > told me
> > > started
> > > > > Howard T.
> > > > > From: Scott Forman
> > > about
> > > > 48-50
> > on
> > > > gas
> > > > > vs electric. Ideas?
> > > > > Scott Forman
> > > > > 86 PT38
> > > > > Memphis
> > > Date:
> > > > 8/28/2007 4:29 PM
> > Date:
> > > 8/28/2007 4:29 PM
> > 8/28/2007 4:29 PM
> Curt Sprenger
> Anaheim Hills, CA
09-03-2007, 09:06
Post: #25
Greg,
I agree, a good fan at the upper vent would be better. I used the adjustable
thermostat with on/off to control the fan. If I just had a switch, and it
was ON, it would be on all the time unless I remember to read my Quick
Reference card. You'll know what I mean in another 20 years.
On 9/3/07, Gregory OConnor wrote:
> Curt, I used a led lighted toggle switch to power my fan. Got the fan
> from Radio shack 12 volt about $30.00, has a good hummmm. Powered it
> from the 12 volt input to the refer. (I would have used a leaf
> blower if that what it took the make the friggin-fridge work)
> Of interesing note is the gas heater element has a heat stack that
> passes next to the evap coil. the stack ends near the middle of the
> fridge, below one other coil????? I dont know if it is intended to
> passivly heat the other coil????? create heat convection and draw
> more air over the evap coil??? all I know is with the fan, every
> thing stays cool. (I'll leave amonia refrig engineering to Albert
> Einstine the theory inventer)
> I think an exhaust fan at the roof would work better with limited
> space. When I tried putting a fan over the coil, the results proved
> minimal improvement. That method seemed to just recirculate the
> trapped hot air in the fridge mechanical area.
> http://www.pbase.com/gregoryoc/image/83321477
> GregoryO'Connor
> 94ptRomolandCa
> 118f and shaking from a 4.7
> "Curt Sprenger"
> > Scott,
> > A computer or electronics cooling fan works well. Get one about 4",
> > depending on the space between the frig. coil and the outer wall.
> You can
> > usually find them at a surplus electronics store for about $5.00.Or
> you can
> > send me your address and I'll mail you a fan. I used zip-ties to
> anchor it
> > behind the frig., and installed a cheap household heating/cooling
> thermostat
> > from H-Depot, and leave it set to about 85 degrees to turn on the
> fan. I'm
> > about to install a second fan that will be switched and will be
> used only on
> > the very hot days, like today when it gets to 104 degrees here in
> sunny CA.
> > More air flow is better. Keep in mind that the fan will run when
> the coach
> > is parked, unless you turn it off...a drain on the batteries.
Curt Sprenger
Anaheim Hills, CA
09-03-2007, 13:39
Post: #26
Camping World sells one. I mounted it so it blows up on all the coils.
Has a thermostat that mounts on the cooling tubes and comes on at 90
degrees.
Bob Lawrence
84 PT36
Tacoma, Wa.
> Where could I find such a fan?
> --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@>
> > Scott,
> > I added 2 12V fans to the back compartment which blow across
> > evaporator coils. They dropped my temp in the 'fridge from 45-50
to
> > around 25 degrees when the setting is on "5". It was a cheap fix
> > has worked great for the past few months. Bob Robinson and John
Finn
> > had similar setups and were kind enough to share the idea with me
at
> > OshKosh.
> > Shane Fedeli
> > 85PT40
> > Hershey, PA
> > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman"
about
> 48-50
on
> gas
> > > vs electric. Ideas?
> > > Scott Forman
> > > 86 PT38
> > > Memphis
09-04-2007, 04:43
Post: #27
God, I love this web site. I have all of the symptoms you guys have
been describing and then some, the ice maker also leaks when turned
on! Turn it off and the leak stops. Freezer works great. Never cool
enough in the fridge for safe long term food storage.
My PT42 has an angled fridge and the compartment it is mounted in is
cavernous.
According to this site, http://www.rvmobile.com/Tech/Trouble/vent.htm
This configuration is not good. There is too much area for the
convection process to do its job.
I was in the process of installing cooling fans in the engine
compartment and inverter bay, so I guess I'll just keep moving around
the coach to the fridge compartment.
According to the above web site, they state that direct cooling of
the coils is not appropriate. But there is a problem with this! The
specs given for a proper installation are less than 1" from the coils
up to the roof, so you would have to put in ductwork and maybe some
baffles from the side vent up to the roof vent. Not really what I
wanted to hear. The space is so large behind the fridge that I
believe direct cooling with small fans is the only practical way of
venting this set up. Some of guys on this post are doing this and
they are having good results with it. In addition some type of power
vent in the roof to extract the hot air would also be good. A max air
would defiantly do it, but mounting it in place of the fridge vent on
my coach does not look encouraging at the moment.
I believe it will have to be a set up on the inside of the fridge
compartment. Not really a problem I have to pull the fridge to fix
the ice maker water leak anyway. And there is enough space behind the
fridge to mount just about any type of fan system you need. I may be
wrong but I think a fan in the side vent won't help as much as a fan
in the roof vent. The idea being that it's a convection system and
moving air past the coils and extracting it from the compartment is
how this was designed to work.
I'll be watching these posts with great interest, any thoughts or
ideas would be greatly appreciated. As soon as I'm done with the new
engine compartment fans I'll post the results and pics, this may not
be practical but they were fun to put together. 2 - 16" 2500 CFM fans
on the louvered door curb side, 1 small fan in the opening between
the inverter compartment and the engine compartment. 2 – 14" 2000 CFM
fans on the Air Cooler and Radiator, and 1 or 2 fans on the A/C
condenser size yet to be determined, all fans are thermostatically
controlled with manual over ride. Oh yea, fans in the A/C compartment
Kurt Horvath
Bumpersbird
'95 PT-42 WLWB
"Indulgence"
09-04-2007, 07:14
Post: #28
Local computer recyclers sell these for $1 - $2
http://www.materialsprocessing.com/
Troy
Sent: Monday, September 03, 2007 9:51 AM
Scott,
You can usually locate them at Radio Shack or a local electronic
parts warehouse in your area. Here is a website that sells them-
[http://www.sofasco.com/products/dc_axial/d12038.html] They can be
easily fit into the compartment with zip-ties that secure them to the
coils or any other fixed surface. They draw almost no current and can
run continuously. Most of the 'birds came with a snap-disk thermostat
in the reefer compartment. I removed mine and wired the fans directly
to the "Refrigerator Fan" switch that is on my galley control panel
(right below the water pump switch)
Shane Fedeli
85PT40
Hershey, PA
> > Scott,
> > I added 2 12V fans to the back compartment which blow across the
> > evaporator coils. They dropped my temp in the 'fridge from 45-50 to
> > around 25 degrees when the setting is on "5". It was a cheap fix and
> > has worked great for the past few months. Bob Robinson and John Finn
> > had similar setups and were kind enough to share the idea with me at
> > OshKosh.
> > Shane Fedeli
> > 85PT40
> > Hershey, PA
> > <sforman@> wrote:
> > > My Dometic refir is no cooling well, will only get down to about
> 48-50
> gas
> > > vs electric. Ideas?
> > > Scott Forman
> > > 86 PT38
> > > Memphis
09-04-2007, 14:54
Post: #29
Kent,
Your comment about your icemaker leak triggered an unpleasant memory. After the
coach had set winterized for a couple months, we took a winter trip and noticed
the icemaker was leaking. Every other pipe had been purged of water but the
tiny plastic water line and a plastic valve in the icemaker had split. Since
then, I run the icemaker throgh a couple cycles after purging the water lines
just to make sure. Brad Barton 00LXiDFWbbartonwx@...
News, entertainment and everything you care about at Live.com. Get it now!
http://www.live.com/getstarted.aspx
09-08-2007, 07:11
Post: #30
On Sun, 02 Sep 2007 21:41:18 -0000, you wrote:
>Scott,
>OshKosh.
>Shane Fedeli
>85PT40
>Hershey, PA
Why would you want to freeze water in your fridge? Does'nt that make
the beer hard to drink?
Regards,
Pete Arnold
You only need two things in life.......
Duct tape and WD40
If it moves and shouldn't...use the duct tape.
If it doesn't move and should...use the WD40!
