Dometic refir not cooling well
09-02-2007, 03:48
My Dometic refir is no cooling well, will only get down to about 48-50
degrees. The freezer works fine. Seems to make no difference on gas
vs electric. Ideas?
Scott Forman
86 PT38
Memphis
09-02-2007, 04:00
Scott,
Check to make sure nothing inside the refrigerator is keeping the door
from closing completely. Ensure the door is closed. I have sometimes
found that my door is running into something that keeps it from sealing
completely, like a bottle or can or shelf that isn't fully clear.
Gary
SOB
50
> vs electric. Ideas?
> Scott Forman
> 86 PT38
> Memphis
09-02-2007, 05:20
Scott,
The problem could be icing on the cooling fins located at the inside top of
the refirgerator compartment. I've experienced this when I leave the unit on
for months at a time. A defrost resolved the problem.
On 9/2/07, trekkersmith1 wrote:
> Scott,
> Gary
> SOB
> 50
> > vs electric. Ideas?
> > Scott Forman
> > 86 PT38
> > Memphis
Curt Sprenger
Anaheim Hills, CA
09-02-2007, 05:30
My fins have no frost/ice, in fact they have liquid condensation on
them when the unit is running
Scott
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
> Scott,
inside top of
the unit on
> > Scott,
door
sometimes
sealing
> > Gary
> > SOB
> > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > "Scott Forman" <sforman@>
about 48-
> > 50
gas
> > > vs electric. Ideas?
> > > Scott Forman
> > > 86 PT38
> > > Memphis
> Curt Sprenger
> Anaheim Hills, CA
09-02-2007, 07:24
I just posted the Dometic trouble shooting .pdf that Dometic sent
when we were having trouble with ours. It is in the Files area and
named "Dometic.pdf".
This guide covers the operation and problem symptoms for most Dometic
refers. I does not reference every model, but once you identify
which section applies to the model family yours came from, you should
be able to quickly zero in on the things that can go wrong. Worked
for us.
If your symptoms lead to a bad circuit board, I recommend the
Dinasaur replacement.
Bob Griesel Dometic 3663
> Scott
> > Scott,
> inside top of
> the unit on
> > > Scott,
> door
> sometimes
> sealing
clear.
> > > Gary
> > > SOB
> > > --- In WanderlodgeForum@yahoogroups.com > 40yahoogroups.com>,
> about 48-
> > > 50
on
> gas
> > > > vs electric. Ideas?
> > > > Scott Forman
> > > > 86 PT38
> > > > Memphis
> > Curt Sprenger
> > Anaheim Hills, CA
09-02-2007, 07:31
I had to pull the file - it was not the one I thought. I'll keep
looking - it may be on my computer at work. If so, I will post it
Monday.
Bob Griesel
--- In WanderlodgeForum@yahoogroups.com, "freewill2008"
Dometic
should
> for us.
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@>
on
> > Scott
> > wrote:
> > > Scott,
> > inside top of
leave
> > the unit on
> > > > Scott,
> the
> > door
> > sometimes
from
> > sealing
> clear.
> > > > Gary
> > > > SOB
> > > > --- In WanderlodgeForum@yahoogroups.com > > 40yahoogroups.com>,
> > about 48-
> > > > 50
difference
> on
> > gas
> > > > > vs electric. Ideas?
> > > > > Scott Forman
> > > > > 86 PT38
> > > > > Memphis
> > > Curt Sprenger
> > > Anaheim Hills, CA
09-02-2007, 07:37
OK - I found the right document and re-posted. The file is
named "Dometic Diagnostics".
Best of luck with your unit.
Bob Griesel
> Monday.
> Bob Griesel
> Dometic
> should
Worked
> > for us.
<sforman@>
condensation
> on
> > > Scott
> > > wrote:
> > > > Scott,
> > > inside top of
> leave
> > > the unit on
> > > > > Scott,
keeping
> > the
> > > door
> > > sometimes
> from
> > > sealing
> > clear.
> > > > > Gary
> > > > > SOB
> > > > > --- In WanderlodgeForum@yahoogroups.com > > > 40yahoogroups.com>,
to
> > > about 48-
> > > > > 50
> difference
> > on
> > > gas
> > > > > > vs electric. Ideas?
> > > > > > Scott Forman
> > > > > > 86 PT38
> > > > > > Memphis
> > > > Curt Sprenger
> > > > Anaheim Hills, CA
09-02-2007, 07:47
Thanks Bob!
> Bob Griesel
it
> > Monday.
> > Bob Griesel
sent
> and
> > Dometic
identify
> > should
> Worked
> > > for us.
> <sforman@>
> condensation
> > on
> > > > Scott
> > > > wrote:
> > > > > Scott,
> > > > inside top of
> > leave
> > > > the unit on
> > > > > > Scott,
> keeping
> > > the
> > > > door
have
> > > > sometimes
it
> > from
> > > > sealing
fully
> > > clear.
> > > > > > Gary
> > > > > > SOB
> > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > 40yahoogroups.com>,
> to
> > > > about 48-
> > > > > > 50
> > difference
> > > on
> > > > gas
> > > > > > > vs electric. Ideas?
> > > > > > > Scott Forman
> > > > > > > 86 PT38
> > > > > > > Memphis
> > > > > Curt Sprenger
> > > > > Anaheim Hills, CA
09-02-2007, 08:46
Scott,
You don't mention what setting it's on so I will assume 5. Do you have a
refrigerator fan and is it working? I replaced my fan and that dropped my temps
about 8 degrees when it comes on. There is a 110 degree thermostat in line to
the fan. You can heat it with a long butane charcoal lighter to get it on. Look
up just inside the swing up door to the back of the refrig.
Have you had it cleaned and serviced. Check the exhaust on the roof for
blockage. Mine cools best when I run it on gas. I start off on three and move up
one at a time. On #4 I run 0 in freezer and 35 in refrig. At least I did
yesterday.
When I first got my coach the frig. would not cool a cousin told me to run it on
gas for four or five days and after four days it started cooling it's been
working since.
Check the cooling coils to be sure they are not blocked.
Howard T.
Sent: Sunday, September 02, 2007 11:48 AM
Subject: [WanderlodgeForum] Dometic refir not cooling well
vs electric. Ideas?
Scott Forman
86 PT38
Memphis
Checked by AVG Free Edition.
Version: 7.5.476 / Virus Database: 269.12.10/977 - Release Date: 8/28/2007
4:29 PM
09-02-2007, 09:41
Scott,
I added 2 12V fans to the back compartment which blow across the
evaporator coils. They dropped my temp in the 'fridge from 45-50 to
around 25 degrees when the setting is on "5". It was a cheap fix and
has worked great for the past few months. Bob Robinson and John Finn
had similar setups and were kind enough to share the idea with me at
OshKosh.
Shane Fedeli
85PT40
Hershey, PA
> vs electric. Ideas?
> Scott Forman
> 86 PT38
> Memphis
