					6V92 won't start
					08-29-2007, 17:40
				6V92 won't start
					The only 'no start' situation I've ever encountered was related to the
			starter. On top of my starter is a solenoid with a bent metal flat bar electrical connection between it and the starter. This right angle bent metal connection is about two inches long. After this was removed, cleaned and replaced the engine has started every time. This was more than three years ago. On 29/08/2007, mrkane1952 <mrkane@...> wrote: > > Greetings All: > > I was again exercising the systems after being stationary in this park > for two months, in preparation for getting back on the road next week. > I could not start the coach engine, an '85 6V92. This is the first > failure to start I have experienced in the eighteen months I've owned > the coach. Usually it goes almost as soon as the key engages the > starter. > > Symptoms: the starter motor does not turn. All the dash responses are > normal when switching on the ignition--relays audibly toggle, low air > buzzer and light are active and the suspension dump light is on. The > safeline lights flash in the overhead. Turning the key to "start" > causes a couple meters to peg low, but the 12 volt ammeter shows no > change, nor does the volt meter. > > I have checked: > 1) Battery condition--On this coach, all six 6 volt batteries are tied > together; there is no dedicated house or starting set. All have > sufficient water, and each reads about 6.3 volts with the charger off. > Voltage from the positive tie point to the chassis reads about 12.5 > volts--roughly the same as the dash meter. Resistance from the > battery posts to the tie point, and from the negative posts to the > chassis is about 2 ohms (without cleaning the grease off.) No > corrosion is visible at any connector. > > 2) Engaging the "aux. battery" switch made no difference. > > 3) The no-start response is similar to the times I didn't get the > transmission selector fully into the "N" neutral position before > trying to crank the motor over, so I cycled the selector several times > to be sure. > > 4) Toggled the A/T switch. > > 5) I have no key for the rear start switch, but I cycled the > front-off-rear switch several times. For the present I decided not to > remove and open the box until further consultation. > > 6) Fuel (5/8 tank, Racor no water) and coolant seem correct. > > Riding a Harley since the seventies prepared me for a certain amount > of backroad repair using what little I had in my saddlebags, but now I > have discovered how difficult it is to troubleshoot a 40 foot long > coach without a helper or sufficient tools. Even tried reading my > Fluke in the backup camera, but no luck. It embarrasses me to say I > don't fit under the bus to get to the starter, either! > > The lack or prior symptoms makes me suspect a safety interlock > somewhere may be the cause, rather than the starter itself. So the > question for the group is what else to try before I call for a mobile > repair tech (at $110 /hour)? > > Thanks-- > > M.R.Kane > 1985 PT 40 > near Sanger, TX > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed]  |
					08-30-2007, 14:09
				6V92 won't start
					If the voltage meter drops to below 9 or 10 volts charge the battries, always do
			the simple, cheap things first. re brake> > From: "mrkane1952" <mrkane@...> > Date: 2007/08/29 Wed PM 01:57:46 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] 6V92 won't start > > Greetings All: > > I was again exercising the systems after being stationary in this park > for two months, in preparation for getting back on the road next week. > I could not start the coach engine, an '85 6V92. This is the first > failure to start I have experienced in the eighteen months I've owned > the coach. Usually it goes almost as soon as the key engages the > starter. > > Symptoms: the starter motor does not turn. All the dash responses are > normal when switching on the ignition--relays audibly toggle, low air > buzzer and light are active and the suspension dump light is on. The > safeline lights flash in the overhead. Turning the key to "start" > causes a couple meters to peg low, but the 12 volt ammeter shows no > change, nor does the volt meter. > > I have checked: > 1) Battery condition--On this coach, all six 6 volt batteries are tied > together; there is no dedicated house or starting set. All have > sufficient water, and each reads about 6.3 volts with the charger off. > Voltage from the positive tie point to the chassis reads about 12.5 > volts--roughly the same as the dash meter. Resistance from the > battery posts to the tie point, and from the negative posts to the > chassis is about 2 ohms (without cleaning the grease off.) No > corrosion is visible at any connector. > > 2) Engaging the "aux. battery" switch made no difference. > > 3) The no-start response is similar to the times I didn't get the > transmission selector fully into the "N" neutral position before > trying to crank the motor over, so I cycled the selector several times > to be sure. > > 4) Toggled the A/T switch. > > 5) I have no key for the rear start switch, but I cycled the > front-off-rear switch several times. For the present I decided not to > remove and open the box until further consultation. > > 6) Fuel (5/8 tank, Racor no water) and coolant seem correct. > > Riding a Harley since the seventies prepared me for a certain amount > of backroad repair using what little I had in my saddlebags, but now I > have discovered how difficult it is to troubleshoot a 40 foot long > coach without a helper or sufficient tools. Even tried reading my > Fluke in the backup camera, but no luck. It embarrasses me to say I > don't fit under the bus to get to the starter, either! > > The lack or prior symptoms makes me suspect a safety interlock > somewhere may be the cause, rather than the starter itself. So the > question for the group is what else to try before I call for a mobile > repair tech (at $110 /hour)? > > Thanks-- > > M.R.Kane > 1985 PT 40 > near Sanger, TX > > > > >  |
