PT36 retarder & other things
08-23-2007, 13:21
Post: #21
Yeah, but a Jake on a 892, whata beautiful noise.
MH
Sent: Thursday, August 23, 2007 4:25 PM
Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things
Howard, you sure can. I have two verbal bids for a Jake Brake addition on my
8v92 DDEC II. $9,500 and $9,000. Non -DDEC systems may be slightly cheaper,
around $6-8,000. I did not want to buy a new bus, I just wanted a Jake brake.
lol
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Thursday, August 23, 2007 5:10 PM
Shane,
Could you add a jacob brake and have both a retarder and a jake brake.
Howard T., Sowega, 86 PT40
Sent: Thursday, August 23, 2007 11:31 AM
Subject: [WanderlodgeForum] Re: PT36 retarder & other things
Hi All,
My tranny reading is regularly 230 degrees. Of course, it could be
a faulty sending unit, but my engine oil temp is around the same too,
if not a little warmer. I would expect both oil sumps to be pretty
close in temperature and seem to recall the blue book indicating that
200 to 250 was the normal operating temp for the Allison that I have.
In any event, I change the fluid annually. It's relatively cheap and
easy to do on the mid-80's PT models. You just need a BIG bucket.
Varying brands of tranny fluid have different flash points and
additives. I've been using Lubrication Engineers
[http://www.le-inc.com] 7500 MONOLEC® Power Fluid in numerous vehicles
for a number of years with great results and never smell burned fluid
when I drain. If you're really concerned about the tranny temps, or
drive the western Rockies, get a Jacobs Engine Retarder.
Shane Fedeli
85PT40
Hershey, PA
> I found this on another website:
> Why Atf Wears Out
> An automatic transmission creates a lot of internal heat through
friction: the friction of the
> fluid churning inside the torque converter, friction created when
the clutch plates engage,
> and the normal friction created by gears and bearings carrying their
loads.
> It doesn't take long for the automatic transmission fluid (ATF) to
heat up once the vehicle
> is in motion. Normal driving will raise fluid temperatures to 175
degrees F., which is the
> usual temperature range at which most fluids are designed to
operate. If fluid
> temperatures can be held to 175 degrees F., ATF will last almost
indefinitely -- say up to
> 100,000 miles. But if the fluid temperature goes much higher, the
life of the fluid begins
> to plummet. The problem is even normal driving can push fluid
temperatures well beyond
> safe limits. And once that happens, the trouble begins.
> At elevated operating temperatures, ATF oxidizes, turns brown and
takes on a smell like
> burnt toast. As heat destroys the fluid's lubricating qualities and
friction characteristics,
> varnish begins to form on internal parts (such as the valve body)
which interferes with the
> operation of the transmission. If the temperature gets above 250
degrees F., rubber seals
> begin to harden, which leads to leaks and pressure losses. At higher
temperatures the
> transmission begins to slip, which only aggravates overheating even
more. Eventually the
> clutches burn out and the transmission calls it quits. The only way
to repair the damage
> now is with an overhaul -- a job which can easily run upwards of
$1500 on a late model
> front-wheel drive car or minivan.
> As a rule of thumb, every 20 degree increase in operating
temperature above 175 degrees
> F. cuts the life of the fluid in half!
> At 195 degrees F., for instance, fluid life is reduced to 50,000
miles. At 220 degrees,
> which is commonly encountered in many transmissions, the fluid is
only good for about
> 25,000 miles. At 240 degrees F., the fluid won't go much over 10,000
miles. Add another
> 20 degrees, and life expectancy drops to 5,000 miles. Go to 295 or
300 degrees F., and
> 1,000 to 1,500 miles is about all you'll get before the transmission
burns up.
> Kerry
> 82 FC 35
> Denver
> > Those temperatures seem really high to me. I was looking at hose
temperature ratings
> > and fluid temperature ratings when I was redoing my power
steering. My recollection is
> > that standard hydraulic hose was rated to 250 degrees and the
expensive high
> > temperature hose was rated to 325 or 350. I think regular
transmission fluid was rated
> as
> > functional up to about 250 degrees and synthetics up to about 350.
These numbers are
> > from my memory, If anyone else has knowledge about the functional
temperatures of
> > transmission fluid, I'd like to know. I'd be quite concerned with
temperatures over 300
> > degrees.
> > Kerry
> > 82 FC 35
> > Denver
> > be sure to keep it below
> > > 320-330 degrees or you'll shorten the life of the tranny fluid
> > > greatly. Most commercial bus drivers have to change the tranny fluid
> > > every 50K miles when using the tranny retarder often. Mine
easily goes
> > > from 230 to 300 degrees when descending a steep off-ramp. One way to
> > > slow the heat is to engage the fan override and let the hydro
fan rob
> > > 25-30 horses from the engine and cool the tranny fluid a little
> > > quicker. On an off-ramp it does not make much difference, but on
the 3
> > > or 4 mile grade, you can usually make it to the bottom under 320
> > > degrees if you also use the service brakes along with the tranny
brake
> > > and fan to slow the coach down.
> > > Shane Fedeli
> > > 85PT40
> > > Hershey, PA
Checked by AVG Free Edition.
Version: 7.5.476 / Virus Database: 269.12.2/966 - Release Date: 8/22/2007 9:05
AM
08-23-2007, 13:23
Post: #22
Reference using an engine brake and a tranny retarder together, keep in mind
that the engine brake slows the coach by increased engine braking, and the
primary connection between the engine and tires is the input shaft on the
tranny. The tranny retarder slows the coach at the tranny, no additional strain
on the tranny input shaft. Use both and since there is no syncronization (s.p.?)
between the braking forces, the transmission may try to "outrun" the engine that
is trying to brake, resulting in excess strain on the tranny input shaft and
breakage thereof. Simply put, the engine brake does not talk to the tranny
retarder, so they may get in a fight and the tranny input shaft will be the
loser.
Still trying to build a coach up to BB standards, I think I'm losing, but I
have posted some new pics.
http://ImageEvent.com/reddog/1990thomasbuiltbusdogbus
Doug in Colorado
Richard Hayden wrote:
Here's what the Allison Operator's Manual says on page 18, in a
Caution box at the bottom of the page:
"DO NOT OPERATE THE INPUT OR OUTPUT RETARTDER SIMULTANEOUSLY WITH AN ENGINE
EXHAUST BRAKE. Extreme torque loads can be produced in the range section,
damaging the transmission".
Leroy may have some other information on this. I know he was looking into doing
this very thing.
Sent: Thursday, August 23, 2007 3:57 PM
I don't know Ernie. It's arranged the same on mine. The Allison Operator's
Manual simply states not to use them together with no expansion on that. I did
operate the bus using both at first until I got my hands on an Operator's
Manual, no more. Maybe one of gurus can offer something.
erniecarpet@... o:erniecarpet@...>>
To:
WanderlodgeForum@yahoogroups.com :WanderlodgeForum@yahoogroups.com>
Sent: Thursday, August 23, 2007 3:45 PM
I wonder why the Allison manual says to not use the Jake and transmission
retarder together? The jake on my coach is exhaust. The tranny retarder is on
the transmission.
83PT40
Livingston, Mt
http://discover.aol.com/memed/aolcom30tour<http://discover.aol.com/memed/aolcom3\
0tour><http://discover.aol.com/memed/aolcom30tour<http://discover.aol.com/memed/\
aolcom30tour>>
Doug Engel, Gunnison, CO. Bird Usta Be, now 1990 Thomas Skoolie, "Hormone
Derange"
Be a better Heartthrob. Get better relationship answers from someone who knows.
Yahoo! Answers - Check it out.
08-24-2007, 05:58
Post: #23
Oh boy, Ben might be listening and want that recorded!
Troy
Sent: Thursday, August 23, 2007 8:21 PM
MH
lol
Leroy Eckert
Niceville, FL
Shane,
Hi All,
Shane Fedeli
85PT40
Hershey, PA
> Why Atf Wears Out
loads.
operate. If fluid
temperatures the
only good for about
miles. Add another
300 degrees F., and
burns up.
> Kerry
> 82 FC 35
> Denver
temperature ratings
expensive high
> as
These numbers are
temperatures of
> > degrees.
> > Kerry
> > 82 FC 35
> > Denver
easily goes
fan rob
the 3
brake
> > > Shane Fedeli
> > > 85PT40
> > > Hershey, PA
AM
08-24-2007, 05:59
Post: #24
Have you tried locating a used system from a truck salvage yard?
Troy
Sent: Thursday, August 23, 2007 5:25 PM
lol
Leroy Eckert
Niceville, FL
Shane,
Hi All,
Shane Fedeli
85PT40
Hershey, PA
> Why Atf Wears Out
loads.
operate. If fluid
temperatures the
only good for about
miles. Add another
300 degrees F., and
burns up.
> Kerry
> 82 FC 35
> Denver
temperature ratings
expensive high
> as
These numbers are
temperatures of
> > degrees.
> > Kerry
> > 82 FC 35
> > Denver
easily goes
fan rob
the 3
brake
> > > Shane Fedeli
> > > 85PT40
> > > Hershey, PA
AM
08-24-2007, 06:59
Post: #25
There was one on eBay a while back. Seems like it sold for around
$1,000. I believe that all the 92 series engines use the same brake,
just additional cylinder adapters for the 8V vs the 6V.
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
> Troy
> From: Leroy Eckert
> on my 8v92 DDEC II. $9,500 and $9,000. Non -DDEC systems may be
> slightly cheaper, around $6-8,000. I did not want to buy a new bus, I
> just wanted a Jake brake. lol
> Leroy Eckert
> Niceville, FL
> From: Howard O. Truitt
> Shane,
> From: sfedeli3
> Hi All,
> [http://www.le-inc.com <http://www.le-inc.com>] 7500 MONOLEC® Power
> Shane Fedeli
> 85PT40
> Hershey, PA
> > Why Atf Wears Out
> loads.
> operate. If fluid
> temperatures the
> only good for about
> miles. Add another
> 300 degrees F., and
> burns up.
> > Kerry
> > 82 FC 35
> > Denver
> temperature ratings
> expensive high
> > as
> These numbers are
> temperatures of
> > > degrees.
> > > Kerry
> > > 82 FC 35
> > > Denver
> easily goes
> fan rob
> the 3
> brake
> > > > Shane Fedeli
> > > > 85PT40
> > > > Hershey, PA
> 8/22/2007 9:05 AM
08-24-2007, 07:36
Post: #26
The implications of that are disturbing.
MH
Sent: Friday, August 24, 2007 11:58 AM
Troy
MH
lol
Leroy Eckert
Niceville, FL
Shane,
Hi All,
Shane Fedeli
85PT40
Hershey, PA
> Why Atf Wears Out
loads.
operate. If fluid
temperatures the
only good for about
miles. Add another
300 degrees F., and
burns up.
> Kerry
> 82 FC 35
> Denver
temperature ratings
expensive high
> as
These numbers are
temperatures of
> > degrees.
> > Kerry
> > 82 FC 35
> > Denver
easily goes
fan rob
the 3
brake
> > > Shane Fedeli
> > > 85PT40
> > > Hershey, PA
AM
08-24-2007, 15:07
Post: #27
I have a Jake on my 6v92. When we are coming to the Hoodsport Wa.
rally last year, came down off the hills and put on the Jake.
The guys in camp said "Here comes Bob"..seems I'm the only one with a
Jake, others have the retarder.
Bob Lawrence
84 PT36
Tacky Tacoma, Wa.
> MH
> From: Leroy Eckert
addition on my 8v92 DDEC II. $9,500 and $9,000. Non -DDEC systems may
be slightly cheaper, around $6-8,000. I did not want to buy a new
bus, I just wanted a Jake brake. lol
> Leroy Eckert
> Niceville, FL
> Shane,
brake.
> From: sfedeli3
> Hi All,
too,
that
have.
vehicles
fluid
or
> Shane Fedeli
> 85PT40
> Hershey, PA
> > Why Atf Wears Out
when
their
> loads.
to
175
> operate. If fluid
body)
higher
> temperatures the
even
way
is
> only good for about
10,000
> miles. Add another
or
> 300 degrees F., and
transmission
> burns up.
> > Kerry
> > 82 FC 35
> > Denver
hose
> temperature ratings
> expensive high
> > as
350.
> These numbers are
functional
> temperatures of
with
> > > degrees.
> > > Kerry
> > > 82 FC 35
> > > Denver
fluid
tranny fluid
> easily goes
One way to
hydro
> fan rob
little
but on
> the 3
under 320
tranny
> brake
> > > > Shane Fedeli
> > > > 85PT40
> > > > Hershey, PA
8/22/2007 9:05 AM
