					Leveling Motor removal, ARRRGGGHHH!!!!!
					07-28-2007, 04:11
					It would help us out if we knew what coach you have------- and to please
			sign your posts. Thank you, Ernie Ekberg 83PT40 Weatherford, Tx--Livingston, Mt Wanderlodgeforum.org, owner ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed]  |
					07-28-2007, 07:12
					The pump motor and selenoid for my leveling system are both burned
			out. The selenoid was an easy remove, but the motor is another thing altogether.I had to cut a hole in the floor under the step to remove the last bolt that connected the motor to the pump. No big deal the metal was soft and the sawzall went right thru it, and it will be easy to repair later and out of sight, under the step. But it turns out that the MOTOR holds up the pump. There appears to be two bolts or studs that go thru te step wall, but are unseen on the other side . Has anyone any information on how to go about removing the motor without completely butchering the steps.I have posted some picts of job as it stands now, labeled "Leveling motor".Any help would be appreciated, but I feel it may be time to get out the pry bar anyway.  |
					07-28-2007, 08:32
					The bolts are visible on the front face of the step, just peel the
			carpet back to expose them. They thread directly into the motor housing. Support the motor as you remove them, as when they are gone gravity will take over. I replaced the leveling motor and reservoir on my old FC, and did not have to make any "modifications" to get it out. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "bi222444" wrote: > > The pump motor and selenoid for my leveling system are both burned > out. The > > selenoid was an easy remove, but the motor is another thing > altogether.I had > > to cut a hole in the floor under the step to remove the last bolt > that > > connected the motor to the pump. No big deal the metal was soft and > the > > sawzall went right thru it, and it will be easy to repair later and > out of > > sight, under the step. But it turns out that the MOTOR holds up the > pump. > > There appears to be two bolts or studs that go thru te step wall, but > are > > unseen on the other side . Has anyone any information on how to go > about > > removing the motor without completely butchering the steps.I have > posted > > some picts of job as it stands now, labeled "Leveling motor".Any help > would > > be appreciated, but I feel it may be time to get out the pry bar > anyway. >  |
					07-28-2007, 14:05
			Then that's it, the pry bar shall have it's dzy.I tried feeling for the bolt heads but found none. The hinge of the access step is held on with finishing nails and also holds the rug in place.I'll pull it off in the AM and see whats under there. Thanks for the help. Fred Wells, 1980 FC,NYC, 65000 MILES YOUNG. -- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > The bolts are visible on the front face of the step, just peel the > carpet back to expose them. They thread directly into the motor > housing. Support the motor as you remove them, as when they are gone > gravity will take over. I replaced the leveling motor and reservoir > on my old FC, and did not have to make any "modifications" to get it > out. > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "bi222444" > wrote: > > > > The pump motor and selenoid for my leveling system are both burned > > out. The > > > > selenoid was an easy remove, but the motor is another thing > > altogether.I had > > > > to cut a hole in the floor under the step to remove the last bolt > > that > > > > connected the motor to the pump. No big deal the metal was soft > and > > the > > > > sawzall went right thru it, and it will be easy to repair later and > > out of > > > > sight, under the step. But it turns out that the MOTOR holds up the > > pump. > > > > There appears to be two bolts or studs that go thru te step wall, > but > > are > > > > unseen on the other side . Has anyone any information on how to go > > about > > > > removing the motor without completely butchering the steps.I have > > posted > > > > some picts of job as it stands now, labeled "Leveling motor".Any > help > > would > > > > be appreciated, but I feel it may be time to get out the pry bar > > anyway. > > >  |
					07-28-2007, 14:27
					The bolt heads are in recessed holes, you can't feel them through the
			carpet, but they are there. Scott --- In WanderlodgeForum@yahoogroups.com, "bi222444" wrote: > > - > Then that's it, the pry bar shall have it's dzy.I tried feeling > for the bolt heads but found none. The hinge of the access step is > held on with finishing nails and also holds the rug in place.I'll > pull it off in the AM and see whats under there. Thanks for the help. > > Fred Wells, 1980 FC,NYC, 65000 MILES YOUNG. > > -- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > The bolts are visible on the front face of the step, just peel the > > carpet back to expose them. They thread directly into the motor > > housing. Support the motor as you remove them, as when they are > gone > > gravity will take over. I replaced the leveling motor and > reservoir > > on my old FC, and did not have to make any "modifications" to get > it > > out. > > > > Scott Forman > > 86 PT38 > > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com, "bi222444" > > wrote: > > > > > > The pump motor and selenoid for my leveling system are both > burned > > > out. The > > > > > > selenoid was an easy remove, but the motor is another thing > > > altogether.I had > > > > > > to cut a hole in the floor under the step to remove the last bolt > > > that > > > > > > connected the motor to the pump. No big deal the metal was soft > > and > > > the > > > > > > sawzall went right thru it, and it will be easy to repair later > and > > > out of > > > > > > sight, under the step. But it turns out that the MOTOR holds up > the > > > pump. > > > > > > There appears to be two bolts or studs that go thru te step wall, > > but > > > are > > > > > > unseen on the other side . Has anyone any information on how to > go > > > about > > > > > > removing the motor without completely butchering the steps.I have > > > posted > > > > > > some picts of job as it stands now, labeled "Leveling motor".Any > > help > > > would > > > > > > be appreciated, but I feel it may be time to get out the pry bar > > > anyway. > > > > > >  |
					07-30-2007, 13:48
			wrote: Well it's done. The new motor and seleoid was only $ 165 at a local ignition shop. Total time including labor,running around for the parts and head scratching was about 8 hours.Tested and it works fine now. The reason I had to cut the hole in the step base was because I did not remove the pump, I left it blocked up in it's original position. I did not want to disturb the hydaulic lines or pump for fear of creating another problem. I intend to look at the pump tomorrow and see if there isn't some way of bracing the back end of the pump. I don't like the existing mount at all. > > - > Then that's it, the pry bar shall have it's dzy.I tried feeling > for the bolt heads but found none. The hinge of the access step is > held on with finishing nails and also holds the rug in place.I'll > pull it off in the AM and see whats under there. Thanks for the help. > > Fred Wells, 1980 FC,NYC, 65000 MILES YOUNG. > > -- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > The bolts are visible on the front face of the step, just peel the > > carpet back to expose them. They thread directly into the motor > > housing. Support the motor as you remove them, as when they are > gone > > gravity will take over. I replaced the leveling motor and > reservoir > > on my old FC, and did not have to make any "modifications" to get > it > > out. > > > > Scott Forman > > 86 PT38 > > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com, "bi222444" > > wrote: > > > > > > The pump motor and selenoid for my leveling system are both > burned > > > out. The > > > > > > selenoid was an easy remove, but the motor is another thing > > > altogether.I had > > > > > > to cut a hole in the floor under the step to remove the last bolt > > > that > > > > > > connected the motor to the pump. No big deal the metal was soft > > and > > > the > > > > > > sawzall went right thru it, and it will be easy to repair later > and > > > out of > > > > > > sight, under the step. But it turns out that the MOTOR holds up > the > > > pump. > > > > > > There appears to be two bolts or studs that go thru te step wall, > > but > > > are > > > > > > unseen on the other side . Has anyone any information on how to > go > > > about > > > > > > removing the motor without completely butchering the steps.I have > > > posted > > > > > > some picts of job as it stands now, labeled "Leveling motor".Any > > help > > > would > > > > > > be appreciated, but I feel it may be time to get out the pry bar > > > anyway. > > > > > >  |
