					Zip Dee question
					07-18-2007, 12:45
				Zip Dee question
					My big awning rolls out fine. I extend the front rafter arm and the
			hook on the end drops down over the shaft where it enters the head, holding the awning in the extended position. The rear rafter arm, however, has the hook facing upwards so it engages the shaft from the bottom. The arm is supported only by a short section of the hook and therefor could drop on someone's head at any time, probably mine. Is this the way it should be? I looked at the Zip Dee site diagrams, but they only show the front arm and the parts catalog doesn't differentiate between the front and rear parts. I have the older curved style. Gardner 78FC33  |
					07-18-2007, 13:37
				Zip Dee question
					Been getting extra window awnings all around. Been cleaning my big
			awnings and I think your problem is the hook portion is on backwards. It slides off the portion attached to the side of bus. Take it out and turn it around. Should solve the problem. Bob Lawrence 84 PT36 (with 8 awnings) Tacoma, Wa. > > The rear rafter arm, however, has the hook facing upwards so it > engages the shaft from the bottom. The arm is supported only by a > short section of the hook and therefor could drop on someone's head at > any time, probably mine. > > Is this the way it should be? I looked at the Zip Dee site diagrams, > but they only show the front arm and the parts catalog doesn't > differentiate between the front and rear parts. > > I have the older curved style. > > Gardner > 78FC33 >  |
					07-18-2007, 14:05
				Zip Dee question
					While we're on awnings, anyone know a trick for stretching awning
			fabric? Two of my window awnings will not come out far enough to hook them open, but I have seen a picture of them out so I know that they did reach once upon a time. Suggestions? Scott Forman 86 PT38 --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Been getting extra window awnings all around. Been cleaning my big > awnings and I think your problem is the hook portion is on backwards. > It slides off the portion attached to the side of bus. Take it out > and turn it around. Should solve the problem. > Bob Lawrence > 84 PT36 (with 8 awnings) > Tacoma, Wa. > > > > > The rear rafter arm, however, has the hook facing upwards so it > > engages the shaft from the bottom. The arm is supported only by a > > short section of the hook and therefor could drop on someone's head > at > > any time, probably mine. > > > > Is this the way it should be? I looked at the Zip Dee site > diagrams, > > but they only show the front arm and the parts catalog doesn't > > differentiate between the front and rear parts. > > > > I have the older curved style. > > > > Gardner > > 78FC33 > > >  |
					07-18-2007, 14:10
				Zip Dee question
					Do they come down far enough for a flap of fabric to hang below the roller
			assembly? Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, July 18, 2007 9:05 PM Subject: [WanderlodgeForum] Re: Zip Dee question While we're on awnings, anyone know a trick for stretching awning fabric? Two of my window awnings will not come out far enough to hook them open, but I have seen a picture of them out so I know that they did reach once upon a time. Suggestions? Scott Forman 86 PT38 --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Been getting extra window awnings all around. Been cleaning my big > awnings and I think your problem is the hook portion is on backwards. > It slides off the portion attached to the side of bus. Take it out > and turn it around. Should solve the problem. > Bob Lawrence > 84 PT36 (with 8 awnings) > Tacoma, Wa. > > > > > The rear rafter arm, however, has the hook facing upwards so it > > engages the shaft from the bottom. The arm is supported only by a > > short section of the hook and therefor could drop on someone's head > at > > any time, probably mine. > > > > Is this the way it should be? I looked at the Zip Dee site > diagrams, > > but they only show the front arm and the parts catalog doesn't > > differentiate between the front and rear parts. > > > > I have the older curved style. > > > > Gardner > > 78FC33 > > > [Non-text portions of this message have been removed]  |
					07-18-2007, 14:16
				Zip Dee question
					Yes, they are extending fully, but it's like the material has shrunk.
			--- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Do they come down far enough for a flap of fabric to hang below the roller assembly? > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: Scott Forman > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, July 18, 2007 9:05 PM > Subject: [WanderlodgeForum] Re: Zip Dee question > > > While we're on awnings, anyone know a trick for stretching awning > fabric? Two of my window awnings will not come out far enough to > hook them open, but I have seen a picture of them out so I know that > they did reach once upon a time. Suggestions? > > Scott Forman > 86 PT38 > > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > > > Been getting extra window awnings all around. Been cleaning my big > > awnings and I think your problem is the hook portion is on > backwards. > > It slides off the portion attached to the side of bus. Take it out > > and turn it around. Should solve the problem. > > Bob Lawrence > > 84 PT36 (with 8 awnings) > > Tacoma, Wa. > > > > > > > > The rear rafter arm, however, has the hook facing upwards so it > > > engages the shaft from the bottom. The arm is supported only by a > > > short section of the hook and therefor could drop on someone's > head > > at > > > any time, probably mine. > > > > > > Is this the way it should be? I looked at the Zip Dee site > > diagrams, > > > but they only show the front arm and the parts catalog doesn't > > > differentiate between the front and rear parts. > > > > > > I have the older curved style. > > > > > > Gardner > > > 78FC33 > > > > > > > > > > > [Non-text portions of this message have been removed] >  |
					07-18-2007, 14:50
				Zip Dee question
					Well, I don't know. If the awning is extending fully one could conclude the
			awning material is ok, or it would not extend to its original length. Perhaps the strap itself shrunk some, but I wouldn't know why.???? My mount straps are pretty tight. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, July 18, 2007 9:16 PM Subject: [WanderlodgeForum] Re: Zip Dee question Yes, they are extending fully, but it's like the material has shrunk. --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Do they come down far enough for a flap of fabric to hang below the roller assembly? > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: Scott Forman > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, July 18, 2007 9:05 PM > Subject: [WanderlodgeForum] Re: Zip Dee question > > > While we're on awnings, anyone know a trick for stretching awning > fabric? Two of my window awnings will not come out far enough to > hook them open, but I have seen a picture of them out so I know that > they did reach once upon a time. Suggestions? > > Scott Forman > 86 PT38 > > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > > > Been getting extra window awnings all around. Been cleaning my big > > awnings and I think your problem is the hook portion is on > backwards. > > It slides off the portion attached to the side of bus. Take it out > > and turn it around. Should solve the problem. > > Bob Lawrence > > 84 PT36 (with 8 awnings) > > Tacoma, Wa. > > > > > > > > The rear rafter arm, however, has the hook facing upwards so it > > > engages the shaft from the bottom. The arm is supported only by a > > > short section of the hook and therefor could drop on someone's > head > > at > > > any time, probably mine. > > > > > > Is this the way it should be? I looked at the Zip Dee site > > diagrams, > > > but they only show the front arm and the parts catalog doesn't > > > differentiate between the front and rear parts. > > > > > > I have the older curved style. > > > > > > Gardner > > > 78FC33 > > > > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed]  |
					07-18-2007, 15:05
				Zip Dee question
					Thinking again, if the awning did shrink it would fully extend on the roller but
			not to its original intended position causing the strap to be short. I think. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion [Non-text portions of this message have been removed]  |
					07-18-2007, 23:56
				Zip Dee question
					Bob,
			When your awning is closed how is the rafter arm secured? On mine there is a bolt in the main arm extending at a 45 degree angle upward. The hook on the rafter arm is flat against the main arm when stored. If I reversed it the hook would be about an inch away and it would put quite a bit of sideways stress on it. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Been getting extra window awnings all around. Been cleaning my big > awnings and I think your problem is the hook portion is on backwards. > It slides off the portion attached to the side of bus. Take it out > and turn it around. Should solve the problem. > Bob Lawrence > 84 PT36 (with 8 awnings) > Tacoma, Wa. > > > > > The rear rafter arm, however, has the hook facing upwards so it > > engages the shaft from the bottom. The arm is supported only by a > > short section of the hook and therefor could drop on someone's head > at > > any time, probably mine. > > > > Is this the way it should be? I looked at the Zip Dee site > diagrams, > > but they only show the front arm and the parts catalog doesn't > > differentiate between the front and rear parts. > > > > I have the older curved style. > > > > Gardner > > 78FC33 > > >  |
					07-19-2007, 03:13
				Zip Dee question
					Zip Dee sells replacement straps in 2 lengths, 32" & 42" for the window awnings.
			The longer straps could be shortened to work. Troy Tikalsky Waconia, MN 1986 Newell ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, July 18, 2007 9:50 PM Subject: Re: [WanderlodgeForum] Re: Zip Dee question Well, I don't know. If the awning is extending fully one could conclude the awning material is ok, or it would not extend to its original length. Perhaps the strap itself shrunk some, but I wouldn't know why.???? My mount straps are pretty tight. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, July 18, 2007 9:16 PM Subject: [WanderlodgeForum] Re: Zip Dee question Yes, they are extending fully, but it's like the material has shrunk. --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Do they come down far enough for a flap of fabric to hang below the roller assembly? > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: Scott Forman > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, July 18, 2007 9:05 PM > Subject: [WanderlodgeForum] Re: Zip Dee question > > > While we're on awnings, anyone know a trick for stretching awning > fabric? Two of my window awnings will not come out far enough to > hook them open, but I have seen a picture of them out so I know that > they did reach once upon a time. Suggestions? > > Scott Forman > 86 PT38 > > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > > > Been getting extra window awnings all around. Been cleaning my big > > awnings and I think your problem is the hook portion is on > backwards. > > It slides off the portion attached to the side of bus. Take it out > > and turn it around. Should solve the problem. > > Bob Lawrence > > 84 PT36 (with 8 awnings) > > Tacoma, Wa. > > > > > > > > The rear rafter arm, however, has the hook facing upwards so it > > > engages the shaft from the bottom. The arm is supported only by a > > > short section of the hook and therefor could drop on someone's > head > > at > > > any time, probably mine. > > > > > > Is this the way it should be? I looked at the Zip Dee site > > diagrams, > > > but they only show the front arm and the parts catalog doesn't > > > differentiate between the front and rear parts. > > > > > > I have the older curved style. > > > > > > Gardner > > > 78FC33 > > > > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]  |
