					Entry Step
					07-14-2007, 13:13
				Entry Step
					My entry step is not functioning. Previous owner just left it hang out
			which gave me the willies. I temporarily tied it back with some wire. I'd like to get it working. It looks like I am going to have to replace a bunch of stuff even the steps themselves possibly. Is this stuff all bluebird parts or are there other sources for what I will need? Just need pointed in the right direction. John Heckman Central Pa 73 FC  |
					07-14-2007, 14:08
				Entry Step
					John,
			I am not familiar with the step mechanism on a 73, But there is a troubleshooting guide in the files for a later model, this may help. http://autos.groups.yahoo.com/group/Wand...ir%20Step/ Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > My entry step is not functioning. Previous owner just left it hang out > which gave me the willies. I temporarily tied it back with some wire. > I'd like to get it working. It looks like I am going to have to > replace a bunch of stuff even the steps themselves possibly. Is this > stuff all bluebird parts or are there other sources for what I will > need? Just need pointed in the right direction. > > John Heckman > Central Pa > 73 FC >  |
					07-15-2007, 06:37
				Entry Step
					John,
			The diagrams and directions refer to a "safaety tape." It is pressure sensitive and under the door frame. It is probaly shorted out. It is is a safety measure so that your foot does not get crushed when the step retracts, if you are on the step. In reality it does not seem necessary since it is impossible to shut the door while you are on the step! The strip is black and yellow striped and at one end (right?) are two wires. You can cut them and that may fix the problem. If not you can look elsewhere, but I suspect this will solve the problem. I learned this trick at a RIV a few years ago. One of the BB service techs told me about it. Sid Breese 85PT40 Maysville, MO  |
					07-15-2007, 10:18
				Entry Step
					Thanks for the info however my problems are a little more basic.  I
			don't have much of anything under that step. No mechanism or valves.It appears that most parts are missing so my question is more basic. I have what is an obvious switch on the inside door jam and the steps them selves but I basically am going to have to start over getting the air and electral components. Looks like a job for the professionals. I just was wondering if this is all BB stuff or if other coaches have similar? Don't think I am up to all that is involved with this one. John Heckman central Pa 1973 FC > > John, > The diagrams and directions refer to a "safaety tape." It is pressure > sensitive and under the door frame. It is probaly shorted out. It is > is a safety measure so that your foot does not get crushed when the > step retracts, if you are on the step. In reality it does not seem > necessary since it is impossible to shut the door while you are on the > step! The strip is black and yellow striped and at one end (right?) > are two wires. You can cut them and that may fix the problem. If not > you can look elsewhere, but I suspect this will solve the problem. I > learned this trick at a RIV a few years ago. One of the BB service > techs told me about it. > > Sid Breese > 85PT40 > Maysville, MO >  |
					07-15-2007, 11:16
				Entry Step
					On our 77 pretty basic also it is wired to a 4 way valve
			push the door button in step goes up let the button out step comes out speed regulation is done on the valve itself by way of controlling the speed of the air exhausting It has no micro or mercury switches just the valve the only caveat is as with all other bird steps don't be too close when the step comes out it will knock you on your butt look for the wiring on your on the inside wall of the generator bay there should be a ice cube relay thats where to start if you plan it it out and ask questions here and proceed with moderation you will be able to do it yourself All the parts are available from various sources Randy Dupree has a line on the ram and the valve the relay is available at a good supply house potter and bromfeld ice cube double ice cube if you need a hand give me a call 905 328 0162 Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Thanks for the info however my problems are a little more basic. I > don't have much of anything under that step. No mechanism or > valves.It appears that most parts are missing so my question is more > basic. I have what is an obvious switch on the inside door jam and > the steps them selves but I basically am going to have to start over > getting the air and electral components. Looks like a job for the > professionals. I just was wondering if this is all BB stuff or if > other coaches have similar? Don't think I am up to all that is > involved with this one. > John Heckman > central Pa > 1973 FC > > > > > > > > > John, > > The diagrams and directions refer to a "safaety tape." It is > pressure > > sensitive and under the door frame. It is probaly shorted out. It > is > > is a safety measure so that your foot does not get crushed when the > > step retracts, if you are on the step. In reality it does not seem > > necessary since it is impossible to shut the door while you are on > the > > step! The strip is black and yellow striped and at one end > (right?) > > are two wires. You can cut them and that may fix the problem. If > not > > you can look elsewhere, but I suspect this will solve the problem. > I > > learned this trick at a RIV a few years ago. One of the BB service > > techs told me about it. > > > > Sid Breese > > 85PT40 > > Maysville, MO > > >  |
					07-16-2007, 03:45
				Entry Step
					John,
			I had to put a different switch on my Newell because of a new step installation. And replacing the plunge switch in the door jamb with the newere magnetic switch at the bottom was nice improvement. Only thing..it was stuck on with double stick tape..came off..but I found it before it was too late and superglued it back on. If you want the original BB air-actuated step, the magnetic quick-ee switch may not work, I don't know. Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@...: jehdds@...: Sun, 15 Jul 2007 22:18:53 +0000Subject: [WanderlodgeForum] Re: Entry Step Thanks for the info however my problems are a little more basic. I don't have much of anything under that step. No mechanism or valves.It appears that most parts are missing so my question is more basic. I have what is an obvious switch on the inside door jam and the steps them selves but I basically am going to have to start over getting the air and electral components. Looks like a job for the professionals. I just was wondering if this is all BB stuff or if other coaches have similar? Don't think I am up to all that is involved with this one. John Heckmancentral Pa 1973 FC>> John,> The diagrams and directions refer to a "safaety tape." It is pressure > sensitive and under the door frame. It is probaly shorted out. It is > is a safety measure so that your foot does not get crushed when the > step retracts, if you are on the step. In reality it does not seem > necessary since it is impossible to shut the door while you are on the > step! The strip is black and yellow striped and at one end (right?) > are two wires. You can cut them and that may fix the problem. If not > you can look elsewhere, but I suspect this will solve the problem. I > learned this trick at a RIV a few years ago. One of the BB service > techs told me about it.> > Sid Breese> 85PT40> Maysville, MO> _________________________________________________________________ Local listings, incredible imagery, and driving directions - all in one place! Find it! http://maps.live.com/?wip=69&FORM=MGAC01 [Non-text portions of this message have been removed]  |
					07-16-2007, 07:00
				Entry Step
					I've done a little looking around on line and there are replacement
			steps made buy KwiKee and I am thinking about going that route. The entire step really needs replaced and this would seem to me to be an easier way to do it. They are 12 volt operated and they come with everything needed. On the other hand what do I know??? But I will be learnin' John Heckman central Pa 1973 FC > > > John, > I had to put a different switch on my Newell because of a new step installation. > And replacing the plunge switch in the door jamb with the newere magnetic switch > at the bottom was nice improvement. Only thing..it was stuck on with double stick tape..came off..but I found it before it was too late and superglued it back on. If you want the original BB air- actuated step, the magnetic quick-ee switch may not work, I don't know. Brad Barton 00LXiDFW bbartonwx@... > > > To: WanderlodgeForum@...: jehdds@...: Sun, 15 Jul 2007 22:18:53 +0000Subject: [WanderlodgeForum] Re: Entry Step > > > > > Thanks for the info however my problems are a little more basic. I don't have much of anything under that step. No mechanism or valves.It appears that most parts are missing so my question is more basic. I have what is an obvious switch on the inside door jam and the steps them selves but I basically am going to have to start over getting the air and electral components. Looks like a job for the professionals. I just was wondering if this is all BB stuff or if other coaches have similar? Don't think I am up to all that is involved with this one. John Heckmancentral Pa 1973 FC>> John,> The diagrams and directions refer to a "safaety tape." It is pressure > sensitive and under the door frame. It is probaly shorted out. It is > is a safety measure so that your foot does not get crushed when the > step retracts, if you are on the step. In reality it does not seem > necessary since it is impossible to shut the door while you are on the > step! The strip is black and yellow striped and at one end (right?) > are two wires. You can cut them and that may fix the problem. If not > you can look elsewhere, but I suspect this will solve the problem. I > learned this trick at a RIV a few years ago. One of the BB service > techs told me about it.> > Sid Breese> 85PT40> Maysville, MO> > > > _________________________________________________________________ > Local listings, incredible imagery, and driving directions - all in one place! Find it! > http://maps.live.com/?wip=69&FORM=MGAC01 > > [Non-text portions of this message have been removed] >  |
					07-16-2007, 10:03
				Entry Step
					John,
			One thing I didn't look at was the step on the BB that Tom Eastman is parting out. That might be an option if it wasn't damaged in the accident. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of bubblerboy64 Sent: Monday, July 16, 2007 2:01 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Entry Step I've done a little looking around on line and there are replacement steps made buy KwiKee and I am thinking about going that route. The entire step really needs replaced and this would seem to me to be an easier way to do it. They are 12 volt operated and they come with everything needed. On the other hand what do I know??? But I will be learnin' John Heckman central Pa 1973 FC > > > John, > I had to put a different switch on my Newell because of a new step installation. > And replacing the plunge switch in the door jamb with the newere magnetic switch > at the bottom was nice improvement. Only thing..it was stuck on with double stick tape..came off..but I found it before it was too late and superglued it back on. If you want the original BB air- actuated step, the magnetic quick-ee switch may not work, I don't know. Brad Barton 00LXiDFW bbartonwx@... > > > To: WanderlodgeForum@...: jehdds@...: Sun, 15 Jul 2007 22:18:53 +0000Subject: [WanderlodgeForum] Re: Entry Step > > > > > Thanks for the info however my problems are a little more basic. I don't have much of anything under that step. No mechanism or valves.It appears that most parts are missing so my question is more basic. I have what is an obvious switch on the inside door jam and the steps them selves but I basically am going to have to start over getting the air and electral components. Looks like a job for the professionals. I just was wondering if this is all BB stuff or if other coaches have similar? Don't think I am up to all that is involved with this one. John Heckmancentral Pa 1973 FC>> John,> The diagrams and directions refer to a "safaety tape." It is pressure > sensitive and under the door frame. It is probaly shorted out. It is > is a safety measure so that your foot does not get crushed when the > step retracts, if you are on the step. In reality it does not seem > necessary since it is impossible to shut the door while you are on the > step! The strip is black and yellow striped and at one end (right?) > are two wires. You can cut them and that may fix the problem. If not > you can look elsewhere, but I suspect this will solve the problem. I > learned this trick at a RIV a few years ago. One of the BB service > techs told me about it.> > Sid Breese> 85PT40> Maysville, MO> > > > __________________________________________________________ > Local listings, incredible imagery, and driving directions - all in one place! Find it! > http://maps. <http://maps.live.com/?wip=69&FORM=MGAC01> live.com/?wip=69&FORM=MGAC01 > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed]  |
					07-16-2007, 10:26
				Entry Step
					John,
			I had excellent luck with my Kwikee step but it replaced a similar electric step instead of air-operated as in BB's. I think the whole installation was about 500 dollars parts and labor.Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@...: jehdds@...: Mon, 16 Jul 2007 19:00:38 +0000Subject: [WanderlodgeForum] Re: Entry Step I've done a little looking around on line and there are replacement steps made buy KwiKee and I am thinking about going that route. The entire step really needs replaced and this would seem to me to be an easier way to do it. They are 12 volt operated and they come with everything needed. On the other hand what do I know??? But I will be learnin'John Heckmancentral Pa 1973 FC >> > John, > I had to put a different switch on my Newell because of a new step installation.> And replacing the plunge switch in the door jamb with the newere magnetic switch > at the bottom was nice improvement. Only thing..it was stuck on with double stick tape..came off..but I found it before it was too late and superglued it back on. If you want the original BB air-actuated step, the magnetic quick-ee switch may not work, I don't know. Brad Barton 00LXiDFW bbartonwx@...> > > To: WanderlodgeForum@...: jehdds@...: Sun, 15 Jul 2007 22:18:53 +0000Subject: [WanderlodgeForum] Re: Entry Step> > > > > Thanks for the info however my problems are a little more basic. I don't have much of anything under that step. No mechanism or valves.It appears that most parts are missing so my question is more basic. I have what is an obvious switch on the inside door jam and the steps them selves but I basically am going to have to start over getting the air and electral components. Looks like a job for the professionals. I just was wondering if this is all BB stuff or if other coaches have similar? Don't think I am up to all that is involved with this one. John Heckmancentral Pa 1973 FC>> John,> The diagrams and directions refer to a "safaety tape." It is pressure > sensitive and under the door frame. It is probaly shorted out. It is > is a safety measure so that your foot does not get crushed when the > step retracts, if you are on the step. In reality it does not seem > necessary since it is impossible to shut the door while you are on the > step! The strip is black and yellow striped and at one end (right?) > are two wires. You can cut them and that may fix the problem. If not > you can look elsewhere, but I suspect this will solve the problem. I > learned this trick at a RIV a few years ago. One of the BB service > techs told me about it.> > Sid Breese> 85PT40> Maysville, MO> > > > __________________________________________________________> Local listings, incredible imagery, and driving directions - all in one place! Find it!> http://maps.live.com/?wip=69&FORM=MGAC01> > [Non-text portions of this message have been removed]> _________________________________________________________________ Local listings, incredible imagery, and driving directions - all in one place! Find it! http://maps.live.com/?wip=69&FORM=MGAC01 [Non-text portions of this message have been removed]  |
					07-17-2007, 04:13
				Entry Step
			wrote: > > I've done a little looking around on line and there are replacement > steps made buy KwiKee and I am thinking about going that route. The > entire step really needs replaced and this would seem to me to be an > easier way to do it. They are 12 volt operated and they come with > everything needed. On the other hand what do I know??? But I will be > learnin' > John Heckman > central Pa > 1973 FC > > > > > > John, > > I had to put a different switch on my Newell because of a new step > installation. > > And replacing the plunge switch in the door jamb with the newere > magnetic switch > > at the bottom was nice improvement. Only thing..it was stuck on > with double stick tape..came off..but I found it before it was too > late and superglued it back on. If you want the original BB air- > actuated step, the magnetic quick-ee switch may not work, I don't > know. Brad Barton 00LXiDFW bbartonwx@ > > > > > > To: WanderlodgeForum@: jehdds@: Sun, 15 Jul 2007 22:18:53 > +0000Subject: [WanderlodgeForum] Re: Entry Step > > > > > > > > > > Thanks for the info however my problems are a little more basic. I > don't have much of anything under that step. No mechanism or > valves.It appears that most parts are missing so my question is more > basic. I have what is an obvious switch on the inside door jam and > the steps them selves but I basically am going to have to start over > getting the air and electral components. Looks like a job for the > professionals. I just was wondering if this is all BB stuff or if > other coaches have similar? Don't think I am up to all that is > involved with this one. John Heckmancentral Pa 1973 FC>> John,> The > diagrams and directions refer to a "safaety tape." It is pressure > > sensitive and under the door frame. It is probaly shorted out. It is > > is a safety measure so that your foot does not get crushed when the > > step retracts, if you are on the step. In reality it does not seem > > necessary since it is impossible to shut the door while you are on > the > step! The strip is black and yellow striped and at one end > (right?) > are two wires. You can cut them and that may fix the > problem. If not > you can look elsewhere, but I suspect this will > solve the problem. I > learned this trick at a RIV a few years ago. > One of the BB service > techs told me about it.> > Sid Breese> > 85PT40> Maysville, MO> > > > > > > _________________________________________________________________ > > Local listings, incredible imagery, and driving directions - all in > one place! Find it! > > http://maps.live.com/?wip=69&FORM=MGAC01 > > > > [Non-text portions of this message have been removed] > > > Bubble Boy have you ever thought about going to an RV Salvage yard to look for some used steps and operational gear? I was just thinking about your problem and this could be a fair and reasonable way to get your steps up and working. We have one large RV Recycling yard that I know of up here in Washington and that one I think is in Rochester. Well anyway just a thought as I know if your like me than money doesn't grow on trees. Jon  |
