No Water Pressure
07-04-2007, 09:15
No Water Pressure
I am still trying to get some water. I have checked out the pump. One
of the 1/2 inch nylon connectors was broken on the pump.I replaced
that. When you switch the pump on it seems to have good pressure as
water lashes out of the pump hose. BUT when I connect it all back up
there is no water in any of the taps? I have bypassed one of the
filters the metal filter with the valve on top. Still no water, can
anyone help hoping to have a shower tonight!
Hope you all have a safe and fun Independence Day.
1982 FC-35 "Perfect Weekend" currently in Crestline CA.
07-04-2007, 09:25
No Water Pressure
Check your shore water "fill" switch, to be sure it's in the "off"
position?
Curt Sprenger
Anaheim Hills, Calif.
07-04-2007, 10:38
No Water Pressure
The fill switch is set to off? Is there a relay I can check or clean
it sure seems like the system is switched off in some way.
> position?
> Curt Sprenger
07-04-2007, 19:03
No Water Pressure
The Sporlan Valve may have junk in it. There are write ups on the forums
on how to clean a Sporlan Valve.
Curt Sprenger
> , Curt Sprenger
> > position?
> > Curt Sprenger
07-05-2007, 04:19
No Water Pressure
Ok thanks for the help, I cleaned the Sporlan valve and the water
works now.
I have three new problems:
1. No shower water, cant seem to even turn on the shower? There is
very little movement in the controls.
2. The battery low voltage buzzer keeps going off. we are on shore power.
3. Ice maker, turned it on, it there a seperate tap for water to the
ice maker.
Thanks for all the help
forums
> Curt Sprenger
> > , Curt Sprenger
> > > position?
> > > Curt Sprenger
pump. One
pressure as
back up
water, can
07-05-2007, 05:35
No Water Pressure
My icemaker has a quarter inch plastic water line with a small T shutoff
valve. It is located under the sink which is next to the Icemaker
> works now.
> ice maker.
> Curt Sprenger
> forums
> > Curt Sprenger
> > > --- In
> > > , Curt Sprenger
> > > > position?
> > > > Curt Sprenger
> pump. One
> pressure as
> back up
> water, can
Rob, Sue & Merlin Robinson
94 WLWB
