Filter List for '95 WL with DD Series 60 engine
06-30-2007, 05:27
As a couple of folks requested, following is the filter list for the
'95 (and probably several later years) with the Detroit Diesel Series 60 engine and the PowerTech 15kw generator. This will align if you apply a fixed width font such as Courier. PowerTech PTS MH-15 Generator (with Kubota Engine) ================================================== (Powertech part no) NAPA WIX Fram Oil filter 70000-32091 1191 51191 3569 Fuel Filter 70000-43081 3390 33390 N/A Air Filter 70000-11080 6296 46296 OEM: Donaldson DuraLite Air Cleaner ECC (type), Part # C65002 Oil: Use 10w30 oil. Takes 2.4 gallons plus oil filter. Use an appropriate heavy duty Diesel type. Detroit Diesel Series 60 Engine =============================== Racor (Model 1000FG) Use element 2020TM -- 10 micron. DD# AC-Delco WIX Fuel Filter (spin-on type) Primary 25014275 TP915D 22-25 micron 33118 Secondary 25014342 TP916D 6-8 micron 33120 Oil Filter 25414505 PF2100 51971 Requires 2 per change Oil: Use 15w40. (Do not use single weight oils). Capacity 26 quarts to low mark 32 quarts to full mark 40 quarts when oil filters are changed. Note: NAPA part numbers are usually the same as the last four digits of the WIX number. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... [Non-text portions of this message have been removed] |
06-30-2007, 06:08
Pete, thanks for that filter list. You are a man of your word and you can't ask
for anything better. Ron Thompson Waller, Tx. 1995 42' Wanderlodge Bluebird, WBDA Pete Masterson couple of folks requested, following is the filter list for the '95 (and probably several later years) with the Detroit Diesel Series 60 engine and the PowerTech 15kw generator. This will align if you apply a fixed width font such as Courier. PowerTech PTS MH-15 Generator (with Kubota Engine) ================================================== (Powertech part no) NAPA WIX Fram Oil filter 70000-32091 1191 51191 3569 Fuel Filter 70000-43081 3390 33390 N/A Air Filter 70000-11080 6296 46296 OEM: Donaldson DuraLite Air Cleaner ECC (type), Part # C65002 Oil: Use 10w30 oil. Takes 2.4 gallons plus oil filter. Use an appropriate heavy duty Diesel type. Detroit Diesel Series 60 Engine =============================== Racor (Model 1000FG) Use element 2020TM -- 10 micron. DD# AC-Delco WIX Fuel Filter (spin-on type) Primary 25014275 TP915D 22-25 micron 33118 Secondary 25014342 TP916D 6-8 micron 33120 Oil Filter 25414505 PF2100 51971 Requires 2 per change Oil: Use 15w40. (Do not use single weight oils). Capacity 26 quarts to low mark 32 quarts to full mark 40 quarts when oil filters are changed. Note: NAPA part numbers are usually the same as the last four digits of the WIX number. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... [Non-text portions of this message have been removed] Ron Thompson Waller, Tx. 1995 42' Blue Bird [Non-text portions of this message have been removed] |
