Added external propane quick connector
06-10-2007, 15:55
Sent: Sunday, June 10, 2007 9:08 PM
Subject: [WanderlodgeForum] Re: Added external propane quick connector
Jim Thank you
Bob Loomas 1985 PT 36
--- In WanderlodgeForum@yahoogroups.com, "bloomas"
wrote:That would be Carbon monoxide.
Jim
> From: davidkerryedwards
> Sent: Sunday, June 10, 2007 6:10 PM
> Subject: [WanderlodgeForum] Added external propane quick connector
> Yes and you can also kill you and your family from carbodioxide
if the bird is not properly ventilated.It is
> your bird do with it you want.
> Added a quick connect fitting to the propane tank today so I can
hook up outside campstove.
> Took the elbow going into the regulator and replaced it with a T,
put a second regulator
> above the existing one with a quick connect hose fitting. Took
about an hour and about $20
> in parts. I can also plug in a small propane heater, running the
hose in thru a window so
> when dry camping I can get propane heat without the need for
electricity if necessary.
> Kerry
> 82 Fc 35
> Denver
