Aux Batt solenoid on PT
05-26-2007, 06:53
Where is the auxillary battery solenoid on a PT?
Scott Forman
86 PT38
05-26-2007, 07:48
Scott,
On my 86 PT40 mine is in the compartment with the chargers. But knowing BB and
your coach being a 38 footer it may be different.
Howard Truitt
Camilla, Ga.
86 PT40
> From: "Scott Forman" <sforman@...>
> Date: 2007/05/26 Sat PM 02:53:55 EDT
> Subject: [WanderlodgeForum] Aux Batt solenoid on PT
> Scott Forman
> 86 PT38
05-26-2007, 11:49
Well, if that's it, then mine doesn't work. Where can I get one of
these?
Scott
--- In WanderlodgeForum@yahoogroups.com, wrote:
> Scott,
knowing BB and your coach being a 38 footer it may be different.
> Howard Truitt
> Camilla, Ga.
> 86 PT40
> > Scott Forman
> > 86 PT38
05-26-2007, 11:59
Contact Stephen Birtles. He sells them.
Curt Sprenger
Anaheim Hills, Calif.
> these?
> Scott
> , wrote:
> > Scott,
> > Howard Truitt
> > Camilla, Ga.
> > 86 PT40
> > > Scott Forman
> > > 86 PT38
05-26-2007, 12:17
OK...a little help...
There are solenoids all over the place. There's one on the front
wall of the batter charger compartment. There are two others on the
metal panel that folds down to give access to the charger
compartment. And there are three of them behind the step well,
although it looks like two of them are for the leveling pump. None
of these make the audible "click" when I hit the Aux Batt switch.
The drawings in my Blue Box aren't as comprehensive as they were in
my FC, so I am having trouble figuring all this out.
Help!
Scott Forman
86 PT38
> Scott,
> Howard Truitt
> Camilla, Ga.
> 86 PT40
> > Scott Forman
> > 86 PT38
05-26-2007, 12:35
Scott:
Locate the solenoid that the gen set battery charge diode is connected to.
It should be on the right of the compartment behind an angle bracket. That
is the solenoid that by passes the diode and connects the batteries together.
Safe travels,
84FC35
Duncan, Oklahoma
>Help!
>Scott Forman
>86 PT38
> > Scott,
> > Howard Truitt
> > Camilla, Ga.
> > 86 PT40
> > > Scott Forman
> > > 86 PT38
05-26-2007, 13:07
I was looking for the diode, couldn't find it. But I think I know
the one you are speking of. Lots of connections around that thing.
Thanks
> Scott:
connected to.
bracket. That
together.
> Safe travels,
> 84FC35
> Duncan, Oklahoma
> >Help!
> >Scott Forman
> >86 PT38
> > > Scott,
> > > Howard Truitt
> > > Camilla, Ga.
> > > 86 PT40
> > > > From: "Scott Forman" <sforman@>
> > > > Scott Forman
> > > > 86 PT38
05-26-2007, 15:01
Scott,
On my coach it is in the front drivers side compartment. With the
Gen. radiator, fan, control box, etc.. Mine is not working either.
I've got it narrowed down to the wire from the switch to the
solenoid, has a break in it somewhere?
Tom Sorrentino
1987 PT38
Bedford Hills, NY
> Scott Forman
> 86 PT38
05-26-2007, 18:03
The '86 and '87 are built way different in that compartment.
Curt Sprenger
thomas_sorrentino wrote:
> Scott,
> Tom Sorrentino
> 1987 PT38
> Bedford Hills, NY
> > Scott Forman
> > 86 PT38
05-27-2007, 01:50
Scott,
May I be so bold as to ask what is your problem?
Howard Truitt
Camilla, Ga.
86 PT40
> Date: 2007/05/26 Sat PM 08:17:02 EDT
> Subject: [WanderlodgeForum] Re: Aux Batt solenoid on PT
> Help!
> Scott Forman
> 86 PT38
> > Scott,
> > Howard Truitt
> > Camilla, Ga.
> > 86 PT40
> > > Scott Forman
> > > 86 PT38
