Air suspension
04-09-2007, 00:27
Air suspension
Phil,
Few years ago I had to replace air valve on our rear air suspension due to leak
problem.
First place I would check is the valves regulating air pressure to your front
air bags to
control level. Do you have one or two valves up front?
Eric in San Antonio
84FC35SBWL2
--- In WanderlodgeForum@yahoogroups.com, "iwander_85pt40" wrote:
> Hi all,
> Last weekend as we returned home from a short trip, the front air bags
> deflated while on the freeway. It was easy to tell when I went over
> the first bump. Luckily, we were within a couple of miles of home,
> so I eased on in.
> Here are the symptoms:
> Front air bags deflated while cruising;
> Air pressure--80 psi;
> Brake pressure maintains at 70 psi;
> Dumped the tag axle to back into parking spot--drive axle bags deflated;
> My wife said she could hear an air leak as I was backing in;
> By the time I finished backing in, set the brakes, and exited the
> coach, the air pressure had dropped almost to zero, so I was unable to
> pinpoint the leak.
> I couldn't do anything about the issue during the week because of work.
> Today, I started the coach up to build air pressure, and look for a
> leak. Everything worked normally, although it took awhile for the
> suspension to air up.
> And, of course, there is no air leak to be heard. What else is new?
> Anyway, the Ridewell manual points me to the suspension air filter
> (possibly clogged) as causing slow air bag inflation and, of course,
> an air leak in the lines/fittings, causing the suspension to drop.
> However, I don't find anything that explains the deflation of the
> front air bags, and subsequent deflation of the drive axle air bags
> after I dumped the tag.
> Because my wife heard an air leak, and because things seemed to be
> somewhat normal today, I suspect a valve within the air suspension
> system is malfunctioning.
> Anybody experience the same issue? If so, what was the fix?
> Anybody know where the suspension air filter is located? According to
> the schematic, it appears to be between the rear air tanks.
> Other suggestions are welcome.
> TIA,
> Phil
> 'iWander' 85PT40
> Left Coast
05-20-2007, 16:36
Air suspension
I have been experimenting the past two days. Actually, I've been wiring
the TV to use the same AMP as the Stereo Radio/CD system. So I have time
to monitor things while playing in the coach... With the air springs
deflated, the 120V air compressor will run every 15 minutes or there
abouts. With the air springs aired up, the 120V compressor cycles about
at 70 minutes.
Any thoughts on why the difference?
Curt Sprenger
Anaheim Hills, Calif.
05-20-2007, 19:17
Air suspension
Mine too Curt, at least 70 minutes.
To: wanderlodge@yahoogroups.com ;
Sent: Sunday, May 20, 2007 9:36 PM
Subject: [WanderlodgeForum] Air Suspension
at 70 minutes.
Curt Sprenger
05-21-2007, 02:27
Air suspension
My compressor cycled about every hour presumably to replace normal air loss. I
have a leak at my step solenoid valve and have not solved that problem yet.
I have noticed the following:
The aux air system which operates the step, air ducts, stepwell cover, dump
valves and other stuff bleeds off rapidly due to the step valve leak but the
main air gauges do not. Don't know why?
If I start the engine immediately after the aux tank bleeds off( doesn't have a
gauge), and the main air gauges registering between 95-100psi, the low air
buzzer squeals until the aux tank is filled. That suggests the pressure switch
and buzzer are in the aux system??? Don't know why that would be either.
It sounds like a leak in the aux system in your case, and I don't know why I am
saying that.
Just more questions than answers. I gotta get my step valve working properly
before I can figure anything out. Let us know what you find, It could help me
figure out my problem.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com
Sent: Sunday, May 20, 2007 11:36 PM
at 70 minutes.
Curt Sprenger
05-21-2007, 04:15
Air suspension
I would guess that if you have your Jacks down that your dump valves are being
actuated.
Jim Riordan
** WBLW XXV
Stuart, Fl.
wiring
at 70 minutes.
Curt Sprenger
Sucker-punch spam with award-winning protection.
Try the free Yahoo! Mail Beta.
05-21-2007, 07:27
Air suspension
Jacks not down.
Curt Sprenger
> are being actuated.
> Jim Riordan
> ** WBLW XXV
> Stuart, Fl.
> at 70 minutes.
> Curt Sprenger
