Jacks not functioning properly
05-16-2007, 05:04
Year and model of your BB???
Kevin YL CA 86 38 PT ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
05-16-2007, 08:57
Hello, We just went to get our bus from Olympia Washington. When we
got home, the jacks did not work properly. The pannel came on like normal, but when we went to press the button it just made a clicking noise that could be heard both inside and out. Finally they went down after many tries of pushing the button. After they set they could not be adjusted - like the controls were not working?? Any help would be greatly appreciated! Thank you! Teri & Robert Rahn Kalispell, MT |
05-16-2007, 09:44
Opps, Sorry.....Forgot that part.
It's a 1988 pt 40 Thanks, Teri |
05-16-2007, 12:40
Probably the relay located under the bus behind the steps. Lay down and
look behind the steps and you will see a selenoid that has various cables coming out of it. Thes get loose and corroded. Clean these and tighten, this might do it. Did for us. Bob Lawrence 84 PT36 Tacoma, Wa. --- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn" > > Hello, We just went to get our bus from Olympia Washington. When we > got home, the jacks did not work properly. The pannel came on like > normal, but when we went to press the button it just made a clicking > noise that could be heard both inside and out. Finally they went down > after many tries of pushing the button. After they set they could not > be adjusted - like the controls were not working?? Any help would be > greatly appreciated! > > Thank you! > > Teri & Robert Rahn > Kalispell, MT > |
