Cracked wheel
05-04-2007, 03:43
Cracked wheel
Just wanted to highlight the importance of checking lug nut torque
after having tires changed or brake work performed. A couple of weeks
ago, after having brake work, I noticed 2 stress cracks had developed
in one of the tag axle wheels. The shop would not admit responsibility
for the excess torque but did share the cost of replacing the wheel. I
checked torque on the other wheels and found that all of them were over
torqued. It is the first time I have failed to check lug nut torque
after having work done and I wound up paying a price.
Royal Washburn
97 43 BBWL
05-04-2007, 05:02
Cracked wheel
Mike Hohnstein,
Was that $100 for a *NEW* Matco 450 lb 3/4" drive torque wrench? You
got a part number for that? Sounds way cheap. Did a quick search on
Matco site and don't immediately see it.
Thanks,
1991 WB40 "Texas Minivan"
<MHOHNSTEIN@...> wrote:
> A forum member showed me a "torque stick" a couple years ago. He
required the tire guy to use it when servicing his coach. I bought
one right away and keep it in the side compartment. Mine is yellow in
color, set @ 450 #s 3/4" drive, Matco cost around $100, I think.
> MH
> From: bbwlwb88
> Sent: Friday, May 04, 2007 9:43 AM
> Subject: [WanderlodgeForum] Cracked wheel
responsibility
wheel. I
over
> Royal Washburn
> 97 43 BBWL
05-04-2007, 05:40
Cracked wheel
A forum member showed me a "torque stick" a couple years ago. He required the
tire guy to use it when servicing his coach. I bought one right away and keep
it in the side compartment. Mine is yellow in color, set @ 450 #s 3/4" drive,
MH
Royal Washburn
97 43 BBWL
05-04-2007, 06:37
Cracked wheel
How do these work Mike? Do they yield if you exceed their
rated torque (brake/twist)?
David Brady
'02 LXi, Smokey
NC
> required the tire guy to use it when servicing his coach. I bought one
> MH
> From: bbwlwb88
> Royal Washburn
> 97 43 BBWL
> Version: 7.5.467 / Virus Database: 269.6.2/787 - Release Date: 5/3/2007 2:11
PM
05-04-2007, 06:44
Cracked wheel
You also need to inspect the lugs and nuts themselves. I have had
two lugs shear off on my FC35 rear axle. These types of things have
a duty cycle and every time you hit a bump or take the wheels off
they get older. The lugs themselves are about $2/each and are easy
for any shop to replace. Heck you can even do it yourself with a
sledgehammer (on the side of road) or harbor freight shop press.
Thomas Eastham
713-851-9693
thomase@...
Houston, TX
83' FC35
84' FC33 parting out
05-04-2007, 08:47
Cracked wheel
I used mine per directions with my Snap On 3/4 air gun @ 175#s shop air.
Checked with the torque wrench, it was OK. They are intended to protect fragile
wheels from caveman installers and they do that. Instructions essentially say
lay into the lug nut until the socket quits turning.
MH
Sent: Friday, May 04, 2007 12:37 PM
Subject: Re: [WanderlodgeForum] Cracked wheel
David Brady
'02 LXi, Smokey
NC
> MH
> From: bbwlwb88
> Royal Washburn
> 97 43 BBWL
PM
05-04-2007, 08:54
Cracked wheel
A "torque stick", looks like a 10" extension. It's like a torsion bar thing
that protects wheels from over torquing lug nuts. You use like a socket
extension. They are available in every conceivable torque range. Go check out
your local tire store, they will have them and if they don't, you need another
tire supplier.
MH
MH
Sent: Friday, May 04, 2007 11:02 AM
Subject: [WanderlodgeForum] Re: Cracked wheel
Mike Hohnstein,
Thanks,
> MH
> From: bbwlwb88
responsibility
wheel. I
over
> Royal Washburn
> 97 43 BBWL
