Constant Door Chime
04-04-2007, 04:39
Constant Door Chime
Gregory you're not nearly old enough to remember that movie.
Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Gregory OConnor To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, April 03, 2007 3:06 PM Subject: [WanderlodgeForum] Re: Constant Door Chime Keith, Kevin is thinking you are using the wrong switch. You need a momentary switch like the old starter buttons; the moment you push- it makes contact, the moment you release- it loses contact. If the doorbell button you are using now clicks when pushed, it may unclick when pushed the second time. That would be a POPO switch I am looking for a door bell chime that rings like the NewMoon trailer in the LongLong Trailer movie. GregoryO'Connor 94PTRomolandCa --- In WanderlodgeForum@yahoogroups.com "Keith Strehle" > > Okay, I got it. SPST = Single Pole Single Throw. A SPST momentary > switch returns to its normally open (off) position when you release > the button. A standard doorbell switch. It doesn't solve the problem > (yet) but I know what it is now... > > Thanks, Keith > 84FC35 > > > > > --- In WanderlodgeForum@yahoogroups.com krminyl@ wrote: > > > > Are you sure it's a momentary, SPST push button switch? What > happens when > > you disconnect both wires from the switch? Does the chime stop? > Touch the > > wires together, does the chime turn on again? If so, your switch > is the wrong > > type. Use a multimeter on the switch contacts, and see what the > switch does. > > The switch could be grounded also, with one of the poles being > momentary > > "on" and the other always "on" always and off when pushed. > > > > Kevin Mc > > Yorba Linda, CA > > 86 38 PT > > > > > > > > ************************************** See what's free at > http://www.aol.com.<http://www.aol.com./> > > > > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed] |
04-04-2007, 06:05
Constant Door Chime
Hey Shane, I just called Nutone. The told me to go to Radio Shack
and pick up diode 1N4002 thru 1N4009. They said any of them will work. I'll pick one up and let you know what happens. Keith 84FC35 --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Hi Keith, > > That same thing happened to me- I believe that it has something to > do with the original door chime button being an "insulated" switch. > Most of the newer residential ones are mounted to wood brick molding > or a non-grounded aluminum screen door frame. In a residential > application, this doesn't matter because the door frame is not > grounded, so if the metal housing for a residential switch contacts > the spring mechanism in the doorbell- nothing happens. On our coaches, > however, this creates problems because the skin of the coach serves as > a ground and as soon as you attach to new doorbell, the switch grounds > itself. Bluebird appears to have used an insulated switch mechanism > where the spring does not contact the metal switch housing. I'd like > to replace mine too, but it's not very high on the priorities list so > I did not pursue it. Please let us know if you find a suitable > replacement. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > It's a standard door bell switch from Home Depot. It releases when > > you stop pushing. But even if you pushed it down and held it there > > the bell should stop ringing until you push it again. Otherwise > > every kid in the hood would be taping your dooebell button down! > > It's a basic doorbell switch just like the one in my house. There > > must be something else to this story. ????????? > > > > Keith > > 84FC35 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > > > Keith, Kevin is thinking you are using the wrong switch. You need a > > > momentary switch like the old starter buttons; the moment you push- > > > it makes contact, the moment you release- it loses contact. If the > > > doorbell button you are using now clicks when pushed, it may > > unclick > > > when pushed the second time. That would be a POPO switch > > > > > > > > > I am looking for a door bell chime that rings like the NewMoon > > > trailer in the LongLong Trailer movie. > > > GregoryO'Connor > > > 94PTRomolandCa > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > > > > > > > Okay, I got it. SPST = Single Pole Single Throw. A SPST > > momentary > > > > switch returns to its normally open (off) position when you > > release > > > > the button. A standard doorbell switch. It doesn't solve the > > > problem > > > > (yet) but I know what it is now... > > > > > > > > Thanks, Keith > > > > 84FC35 > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: > > > > > > > > > > Are you sure it's a momentary, SPST push button switch? What > > > > happens when > > > > > you disconnect both wires from the switch? Does the chime > > > stop? > > > > Touch the > > > > > wires together, does the chime turn on again? If so, your > > > switch > > > > is the wrong > > > > > type. Use a multimeter on the switch contacts, and see what > > the > > > > switch does. > > > > > The switch could be grounded also, with one of the poles > > being > > > > momentary > > > > > "on" and the other always "on" always and off when pushed. > > > > > > > > > > Kevin Mc > > > > > Yorba Linda, CA > > > > > 86 38 PT > > > > > > > > > > > > > > > > > > > > ************************************** See what's free at > > > > http://www.aol.com. > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > |
04-04-2007, 10:53
Constant Door Chime
Keith. Not sure if this will help you but, I got courious with all this door
chime talk, seeing as mine didn't work either. Mine was a 2 part problem. First thing I did was to throw in a new set of batteries. I pressed the switch, and nothing. So I took of the cover of the chime, and jumped the 2 wires and still nothing. I took the chime off of the wall and dug out the booklet for it and started reading it. On the back , right under the part where it basicly says it's going to outlive you, there was what appeared to be some type of rectifier taped to the book. The scotch tape was rather yellow and brittle so not sure if it was a factory issue or not, but anyway, I took the circut board out of the plastic housing, and the groundstrap, for one of the batteries fell out on the dinette table It looked like someone had dissassembled it and while reassembling, maybe put a little too much pressure on the tabs ( you have to do this to get the board back in) I soldered the tab back on and traced down the location of the diode rectifier It fits in the D9 slot marked on the circut board. I was going to solder the new one in but decided to put it back together, I jumped the terminals while it was on the table, and off it went. I installed it back on the wall and again tried it, with the switch, and nothing. I removed the switch (mine has a brass rectangled backing plate about 1 1/4" x 2 1/2" or so, with a white button that looks like it should light. I threw my ohm meter across the terminals while on the bench, and pressed the button, and no change on the meter, which told me the switch was open. I layed the switch horizontally and sprayed CRC Powerlube in the button. I like to use this lube for a few reasons. It's dielectric, which means you can use it in electrical switches, and dries after a day or so, so when you spray it inside your ignition switch, you can put your keys in your pocket, without staining your clothes.lol I use this on anything that moves. It works real well on the drawer slides etc. Anyway I started pressing the button with the meter connected and after about a dozen times the meter started to move, the switch was stuck open, after a few more times moving it it was working fine. I tested also for a grounded switch and it wasn't grounded at the button, it's insulated, I installed it back on the bus and although no light it works just fine, I think the light is not servicable, it looked sealed. I hope this helps. Jimmy Harvie 82FC 35 SB Boston Ma Keith Strehle Hey Shane, I just called Nutone. The told me to go to Radio Shack and pick up diode 1N4002 thru 1N4009. They said any of them will work. I'll pick one up and let you know what happens. Keith 84FC35 --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Hi Keith, > > That same thing happened to me- I believe that it has something to > do with the original door chime button being an "insulated" switch. > Most of the newer residential ones are mounted to wood brick molding > or a non-grounded aluminum screen door frame. In a residential > application, this doesn't matter because the door frame is not > grounded, so if the metal housing for a residential switch contacts > the spring mechanism in the doorbell- nothing happens. On our coaches, > however, this creates problems because the skin of the coach serves as > a ground and as soon as you attach to new doorbell, the switch grounds > itself. Bluebird appears to have used an insulated switch mechanism > where the spring does not contact the metal switch housing. I'd like > to replace mine too, but it's not very high on the priorities list so > I did not pursue it. Please let us know if you find a suitable > replacement. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > It's a standard door bell switch from Home Depot. It releases when > > you stop pushing. But even if you pushed it down and held it there > > the bell should stop ringing until you push it again. Otherwise > > every kid in the hood would be taping your dooebell button down! > > It's a basic doorbell switch just like the one in my house. There > > must be something else to this story. ????????? > > > > Keith > > 84FC35 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > > > Keith, Kevin is thinking you are using the wrong switch. You need a > > > momentary switch like the old starter buttons; the moment you push- > > > it makes contact, the moment you release- it loses contact. If the > > > doorbell button you are using now clicks when pushed, it may > > unclick > > > when pushed the second time. That would be a POPO switch > > > > > > > > > I am looking for a door bell chime that rings like the NewMoon > > > trailer in the LongLong Trailer movie. > > > GregoryO'Connor > > > 94PTRomolandCa > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > > > > > > > Okay, I got it. SPST = Single Pole Single Throw. A SPST > > momentary > > > > switch returns to its normally open (off) position when you > > release > > > > the button. A standard doorbell switch. It doesn't solve the > > > problem > > > > (yet) but I know what it is now... > > > > > > > > Thanks, Keith > > > > 84FC35 > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: > > > > > > > > > > Are you sure it's a momentary, SPST push button switch? What > > > > happens when > > > > > you disconnect both wires from the switch? Does the chime > > > stop? > > > > Touch the > > > > > wires together, does the chime turn on again? If so, your > > > switch > > > > is the wrong > > > > > type. Use a multimeter on the switch contacts, and see what > > the > > > > switch does. > > > > > The switch could be grounded also, with one of the poles > > being > > > > momentary > > > > > "on" and the other always "on" always and off when pushed. > > > > > > > > > > Kevin Mc > > > > > Yorba Linda, CA > > > > > 86 38 PT > > > > > > > > > > > > > > > > > > > > ************************************** See what's free at > > > > http://www.aol.com. > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > --------------------------------- Never miss an email again! Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out. [Non-text portions of this message have been removed] |
04-04-2007, 11:13
Constant Door Chime
Mine does not have batteries in it. But it still works from the
button on the unit. Actually, it works fine from the remote button, except that it won't stop. The folks at Nutone said to attach the diode on the button teminals then attach the wires and it should work. The diodes are availabble at Radio Shack. Only problem is they come 25 to a package. The good news is they are $2.59 per package. So, if you or anyone else needs a door bell diode.... Keith 84FC35 --- In WanderlodgeForum@yahoogroups.com, James Harvie > > Keith. Not sure if this will help you but, I got courious with all this door chime talk, seeing as mine didn't work either. Mine was a 2 part problem. First thing I did was to throw in a new set of batteries. I pressed the switch, and nothing. So I took of the cover of the chime, and jumped the 2 wires and still nothing. I took the chime off of the wall and dug out the booklet for it and started reading it. On the back , right under the part where it basicly says it's going to outlive you, there was what appeared to be some type of rectifier taped to the book. The scotch tape was rather yellow and brittle so not sure if it was a factory issue or not, but anyway, I took the circut board out of the plastic housing, and the groundstrap, for one of the batteries fell out on the dinette table It looked like someone had dissassembled it and while reassembling, maybe put a little too much pressure on the tabs ( you have to do this to get the board back in) I soldered the tab back > on and traced down the location of the diode rectifier It fits in the D9 slot marked on the circut board. I was going to solder the new one in but decided to put it back together, I jumped the terminals while it was on the table, and off it went. I installed it back on the wall and again tried it, with the switch, and nothing. I removed the switch (mine has a brass rectangled backing plate about 1 1/4" x 2 1/2" or so, with a white button that looks like it should light. I threw my ohm meter across the terminals while on the bench, and pressed the button, and no change on the meter, which told me the switch was open. I layed the switch horizontally and sprayed CRC Powerlube in the button. I like to use this lube for a few reasons. It's dielectric, which means you can use it in electrical switches, and dries after a day or so, so when you spray it inside your ignition switch, you can put your keys in your pocket, without staining your clothes.lol I use this on anything that > moves. It works real well on the drawer slides etc. Anyway I started pressing the button with the meter connected and after about a dozen times the meter started to move, the switch was stuck open, after a few more times moving it it was working fine. I tested also for a grounded switch and it wasn't grounded at the button, it's insulated, I installed it back on the bus and although no light it works just fine, I think the light is not servicable, it looked sealed. I hope this helps. > Jimmy Harvie > 82FC 35 SB > Boston Ma > > Keith Strehle > Hey Shane, I just called Nutone. The told me to go to Radio Shack > and pick up diode 1N4002 thru 1N4009. They said any of them will > work. I'll pick one up and let you know what happens. > > Keith > 84FC35 > > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> > wrote: > > > > Hi Keith, > > > > That same thing happened to me- I believe that it has something > to > > do with the original door chime button being an "insulated" switch. > > Most of the newer residential ones are mounted to wood brick molding > > or a non-grounded aluminum screen door frame. In a residential > > application, this doesn't matter because the door frame is not > > grounded, so if the metal housing for a residential switch contacts > > the spring mechanism in the doorbell- nothing happens. On our > coaches, > > however, this creates problems because the skin of the coach serves > as > > a ground and as soon as you attach to new doorbell, the switch > grounds > > itself. Bluebird appears to have used an insulated switch mechanism > > where the spring does not contact the metal switch housing. I'd like > > to replace mine too, but it's not very high on the priorities list > so > > I did not pursue it. Please let us know if you find a suitable > > replacement. > > > > Shane Fedeli > > 85PT40 > > Hershey, PA > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > > > > It's a standard door bell switch from Home Depot. It releases > when > > > you stop pushing. But even if you pushed it down and held it > there > > > the bell should stop ringing until you push it again. Otherwise > > > every kid in the hood would be taping your dooebell button down! > > > It's a basic doorbell switch just like the one in my house. > There > > > must be something else to this story. ????????? > > > > > > Keith > > > 84FC35 > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > > > > > > Keith, Kevin is thinking you are using the wrong switch. You > need a > > > > momentary switch like the old starter buttons; the moment you > push- > > > > it makes contact, the moment you release- it loses contact. If > the > > > > doorbell button you are using now clicks when pushed, it may > > > unclick > > > > when pushed the second time. That would be a POPO switch > > > > > > > > > > > > I am looking for a door bell chime that rings like the NewMoon > > > > trailer in the LongLong Trailer movie. > > > > GregoryO'Connor > > > > 94PTRomolandCa > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > > > > > > > > > > Okay, I got it. SPST = Single Pole Single Throw. A SPST > > > momentary > > > > > switch returns to its normally open (off) position when you > > > release > > > > > the button. A standard doorbell switch. It doesn't solve the > > > > problem > > > > > (yet) but I know what it is now... > > > > > > > > > > Thanks, Keith > > > > > 84FC35 > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: > > > > > > > > > > > > Are you sure it's a momentary, SPST push button switch? > What > > > > > happens when > > > > > > you disconnect both wires from the switch? Does the chime > > > > stop? > > > > > Touch the > > > > > > wires together, does the chime turn on again? If so, your > > > > switch > > > > > is the wrong > > > > > > type. Use a multimeter on the switch contacts, and see > what > > > the > > > > > switch does. > > > > > > The switch could be grounded also, with one of the poles > > > being > > > > > momentary > > > > > > "on" and the other always "on" always and off when pushed. > > > > > > > > > > > > Kevin Mc > > > > > > Yorba Linda, CA > > > > > > 86 38 PT > > > > > > > > > > > > > > > > > > > > > > > > ************************************** See what's free at > > > > > http://www.aol.com. > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > Never miss an email again! > Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out. > > [Non-text portions of this message have been removed] > |
04-04-2007, 17:49
Constant Door Chime
When the door bell is next on the list of repairs, the friggin bus must
be road ready. Mount a knocker and go RV'n GregoryO'Connor 94ptRomolandCa |
04-04-2007, 21:52
Constant Door Chime
Hi Keith,
Mine is 12V like yours. Are you saying to solder the diode between the two contacts on the back of the new switch? What polarity is recommended? Sounds like an easy fix and I already have a really nice bronze switch to try out. -Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > Mine does not have batteries in it. But it still works from the > button on the unit. Actually, it works fine from the remote button, > except that it won't stop. The folks at Nutone said to attach the > diode on the button teminals then attach the wires and it should > work. The diodes are availabble at Radio Shack. Only problem is > they come 25 to a package. The good news is they are $2.59 per > package. So, if you or anyone else needs a door bell diode.... > > Keith > 84FC35 > > --- In WanderlodgeForum@yahoogroups.com, James Harvie > > > > > Keith. Not sure if this will help you but, I got courious with all > this door chime talk, seeing as mine didn't work either. Mine was a 2 > part problem. First thing I did was to throw in a new set of > batteries. I pressed the switch, and nothing. So I took of the cover > of the chime, and jumped the 2 wires and still nothing. I took the > chime off of the wall and dug out the booklet for it and started > reading it. On the back , right under the part where it basicly says > it's going to outlive you, there was what appeared to be some type of > rectifier taped to the book. The scotch tape was rather yellow and > brittle so not sure if it was a factory issue or not, but anyway, I > took the circut board out of the plastic housing, and the > groundstrap, for one of the batteries fell out on the dinette table > It looked like someone had dissassembled it and while reassembling, > maybe put a little too much pressure on the tabs ( you have to do > this to get the board back in) I soldered the tab back > > on and traced down the location of the diode rectifier It fits in > the D9 slot marked on the circut board. I was going to solder the new > one in but decided to put it back together, I jumped the terminals > while it was on the table, and off it went. I installed it back on > the wall and again tried it, with the switch, and nothing. I removed > the switch (mine has a brass rectangled backing plate about 1 1/4" x > 2 1/2" or so, with a white button that looks like it should light. I > threw my ohm meter across the terminals while on the bench, and > pressed the button, and no change on the meter, which told me the > switch was open. I layed the switch horizontally and sprayed CRC > Powerlube in the button. I like to use this lube for a few reasons. > It's dielectric, which means you can use it in electrical switches, > and dries after a day or so, so when you spray it inside your > ignition switch, you can put your keys in your pocket, without > staining your clothes.lol I use this on anything that > > moves. It works real well on the drawer slides etc. Anyway I > started pressing the button with the meter connected and after about > a dozen times the meter started to move, the switch was stuck open, > after a few more times moving it it was working fine. I tested also > for a grounded switch and it wasn't grounded at the button, it's > insulated, I installed it back on the bus and although no light it > works just fine, I think the light is not servicable, it looked > sealed. I hope this helps. > > > Jimmy Harvie > > > 82FC 35 SB > > > Boston Ma > > > > Keith Strehle > > Hey Shane, I just called Nutone. The told me to go to > Radio Shack > > and pick up diode 1N4002 thru 1N4009. They said any of them will > > work. I'll pick one up and let you know what happens. > > > > Keith > > 84FC35 > > > > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> > > wrote: > > > > > > Hi Keith, > > > > > > That same thing happened to me- I believe that it has something > > to > > > do with the original door chime button being an "insulated" > switch. > > > Most of the newer residential ones are mounted to wood brick > molding > > > or a non-grounded aluminum screen door frame. In a residential > > > application, this doesn't matter because the door frame is not > > > grounded, so if the metal housing for a residential switch > contacts > > > the spring mechanism in the doorbell- nothing happens. On our > > coaches, > > > however, this creates problems because the skin of the coach > serves > > as > > > a ground and as soon as you attach to new doorbell, the switch > > grounds > > > itself. Bluebird appears to have used an insulated switch > mechanism > > > where the spring does not contact the metal switch housing. I'd > like > > > to replace mine too, but it's not very high on the priorities > list > > so > > > I did not pursue it. Please let us know if you find a suitable > > > replacement. > > > > > > Shane Fedeli > > > 85PT40 > > > Hershey, PA > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > > > > > > > It's a standard door bell switch from Home Depot. It releases > > when > > > > you stop pushing. But even if you pushed it down and held it > > there > > > > the bell should stop ringing until you push it again. Otherwise > > > > every kid in the hood would be taping your dooebell button > down! > > > > It's a basic doorbell switch just like the one in my house. > > There > > > > must be something else to this story. ????????? > > > > > > > > Keith > > > > 84FC35 > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > > > > > > > > > Keith, Kevin is thinking you are using the wrong switch. You > > need a > > > > > momentary switch like the old starter buttons; the moment you > > push- > > > > > it makes contact, the moment you release- it loses contact. > If > > the > > > > > doorbell button you are using now clicks when pushed, it may > > > > unclick > > > > > when pushed the second time. That would be a POPO switch > > > > > > > > > > > > > > > I am looking for a door bell chime that rings like the > NewMoon > > > > > trailer in the LongLong Trailer movie. > > > > > GregoryO'Connor > > > > > 94PTRomolandCa > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > > > > > > > > > > > > > Okay, I got it. SPST = Single Pole Single Throw. A SPST > > > > momentary > > > > > > switch returns to its normally open (off) position when you > > > > release > > > > > > the button. A standard doorbell switch. It doesn't solve > the > > > > > problem > > > > > > (yet) but I know what it is now... > > > > > > > > > > > > Thanks, Keith > > > > > > 84FC35 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: > > > > > > > > > > > > > > Are you sure it's a momentary, SPST push button switch? > > What > > > > > > happens when > > > > > > > you disconnect both wires from the switch? Does the chime > > > > > stop? > > > > > > Touch the > > > > > > > wires together, does the chime turn on again? If so, your > > > > > switch > > > > > > is the wrong > > > > > > > type. Use a multimeter on the switch contacts, and see > > what > > > > the > > > > > > switch does. > > > > > > > The switch could be grounded also, with one of the poles > > > > being > > > > > > momentary > > > > > > > "on" and the other always "on" always and off when pushed. > > > > > > > > > > > > > > Kevin Mc > > > > > > > Yorba Linda, CA > > > > > > > 86 38 PT > > > > > > > > > > > > > > > > > > > > > > > > > > > > ************************************** See what's free at > > > > > > http://www.aol.com. > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > Never miss an email again! > > Yahoo! Toolbar alerts you the instant new Mail arrives. Check it > out. > > > > [Non-text portions of this message have been removed] > > > |
04-05-2007, 03:40
Constant Door Chime
A door knocker! Dang! I never thought of that! Greg, this doorbell
thing is one of those little things you think will be an easy fix. A new doorbell button and in five minutes, done. It didn't work out that way and became more like a challenge. We all have them. Your're a pretty intelligent guy. Tell me whay it doesn't work like it's supposed to? Thanks, Keith 84FC35 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > When the door bell is next on the list of repairs, the friggin bus must > be road ready. Mount a knocker and go RV'n > > GregoryO'Connor > 94ptRomolandCa > |
04-05-2007, 04:24
Constant Door Chime
The Nutone tech support person said to "attach" the diode to the
terminals. No mention of polarity? I'm going to wrap the diode wires around the terminal screws, hook it up and see what happen. If it doesn't work, I'm out $2.59.... --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Hi Keith, > > Mine is 12V like yours. Are you saying to solder the diode between > the two contacts on the back of the new switch? What polarity is > recommended? Sounds like an easy fix and I already have a really nice > bronze switch to try out. > > -Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > Mine does not have batteries in it. But it still works from the > > button on the unit. Actually, it works fine from the remote button, > > except that it won't stop. The folks at Nutone said to attach the > > diode on the button teminals then attach the wires and it should > > work. The diodes are availabble at Radio Shack. Only problem is > > they come 25 to a package. The good news is they are $2.59 per > > package. So, if you or anyone else needs a door bell diode.... > > > > Keith > > 84FC35 > > > > --- In WanderlodgeForum@yahoogroups.com, James Harvie > > > > > > > > Keith. Not sure if this will help you but, I got courious with all > > this door chime talk, seeing as mine didn't work either. Mine was a 2 > > part problem. First thing I did was to throw in a new set of > > batteries. I pressed the switch, and nothing. So I took of the cover > > of the chime, and jumped the 2 wires and still nothing. I took the > > chime off of the wall and dug out the booklet for it and started > > reading it. On the back , right under the part where it basicly says > > it's going to outlive you, there was what appeared to be some type of > > rectifier taped to the book. The scotch tape was rather yellow and > > brittle so not sure if it was a factory issue or not, but anyway, I > > took the circut board out of the plastic housing, and the > > groundstrap, for one of the batteries fell out on the dinette table > > It looked like someone had dissassembled it and while reassembling, > > maybe put a little too much pressure on the tabs ( you have to do > > this to get the board back in) I soldered the tab back > > > on and traced down the location of the diode rectifier It fits in > > the D9 slot marked on the circut board. I was going to solder the new > > one in but decided to put it back together, I jumped the terminals > > while it was on the table, and off it went. I installed it back on > > the wall and again tried it, with the switch, and nothing. I removed > > the switch (mine has a brass rectangled backing plate about 1 1/4" x > > 2 1/2" or so, with a white button that looks like it should light. I > > threw my ohm meter across the terminals while on the bench, and > > pressed the button, and no change on the meter, which told me the > > switch was open. I layed the switch horizontally and sprayed CRC > > Powerlube in the button. I like to use this lube for a few reasons. > > It's dielectric, which means you can use it in electrical switches, > > and dries after a day or so, so when you spray it inside your > > ignition switch, you can put your keys in your pocket, without > > staining your clothes.lol I use this on anything that > > > moves. It works real well on the drawer slides etc. Anyway I > > started pressing the button with the meter connected and after about > > a dozen times the meter started to move, the switch was stuck open, > > after a few more times moving it it was working fine. I tested also > > for a grounded switch and it wasn't grounded at the button, it's > > insulated, I installed it back on the bus and although no light it > > works just fine, I think the light is not servicable, it looked > > sealed. I hope this helps. > > > > > Jimmy Harvie > > > > > 82FC 35 SB > > > > > Boston Ma > > > > > > Keith Strehle > > > Hey Shane, I just called Nutone. The told me to go to > > Radio Shack > > > and pick up diode 1N4002 thru 1N4009. They said any of them will > > > work. I'll pick one up and let you know what happens. > > > > > > Keith > > > 84FC35 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> > > > wrote: > > > > > > > > Hi Keith, > > > > > > > > That same thing happened to me- I believe that it has something > > > to > > > > do with the original door chime button being an "insulated" > > switch. > > > > Most of the newer residential ones are mounted to wood brick > > molding > > > > or a non-grounded aluminum screen door frame. In a residential > > > > application, this doesn't matter because the door frame is not > > > > grounded, so if the metal housing for a residential switch > > contacts > > > > the spring mechanism in the doorbell- nothing happens. On our > > > coaches, > > > > however, this creates problems because the skin of the coach > > serves > > > as > > > > a ground and as soon as you attach to new doorbell, the switch > > > grounds > > > > itself. Bluebird appears to have used an insulated switch > > mechanism > > > > where the spring does not contact the metal switch housing. I'd > > like > > > > to replace mine too, but it's not very high on the priorities > > list > > > so > > > > I did not pursue it. Please let us know if you find a suitable > > > > replacement. > > > > > > > > Shane Fedeli > > > > 85PT40 > > > > Hershey, PA > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > > > > > > > > > > It's a standard door bell switch from Home Depot. It releases > > > when > > > > > you stop pushing. But even if you pushed it down and held it > > > there > > > > > the bell should stop ringing until you push it again. Otherwise > > > > > every kid in the hood would be taping your dooebell button > > down! > > > > > It's a basic doorbell switch just like the one in my house. > > > There > > > > > must be something else to this story. ????????? > > > > > > > > > > Keith > > > > > 84FC35 > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > > > > > > > > > > > > Keith, Kevin is thinking you are using the wrong switch. You > > > need a > > > > > > momentary switch like the old starter buttons; the moment you > > > push- > > > > > > it makes contact, the moment you release- it loses contact. > > If > > > the > > > > > > doorbell button you are using now clicks when pushed, it may > > > > > unclick > > > > > > when pushed the second time. That would be a POPO switch > > > > > > > > > > > > > > > > > > I am looking for a door bell chime that rings like the > > NewMoon > > > > > > trailer in the LongLong Trailer movie. > > > > > > GregoryO'Connor > > > > > > 94PTRomolandCa > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > > > > > > > > > > > > > > > > Okay, I got it. SPST = Single Pole Single Throw. A SPST > > > > > momentary > > > > > > > switch returns to its normally open (off) position when you > > > > > release > > > > > > > the button. A standard doorbell switch. It doesn't solve > > the > > > > > > problem > > > > > > > (yet) but I know what it is now... > > > > > > > > > > > > > > Thanks, Keith > > > > > > > 84FC35 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: > > > > > > > > > > > > > > > > Are you sure it's a momentary, SPST push button switch? > > > What > > > > > > > happens when > > > > > > > > you disconnect both wires from the switch? Does the chime > > > > > > stop? > > > > > > > Touch the > > > > > > > > wires together, does the chime turn on again? If so, your > > > > > > switch > > > > > > > is the wrong > > > > > > > > type. Use a multimeter on the switch contacts, and see > > > what > > > > > the > > > > > > > switch does. > > > > > > > > The switch could be grounded also, with one of the poles > > > > > being > > > > > > > momentary > > > > > > > > "on" and the other always "on" always and off when pushed. > > > > > > > > > > > > > > > > Kevin Mc > > > > > > > > Yorba Linda, CA > > > > > > > > 86 38 PT > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ************************************** See what's free at > > > > > > > http://www.aol.com. > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > Never miss an email again! > > > Yahoo! Toolbar alerts you the instant new Mail arrives. Check it > > out. > > > > > > [Non-text portions of this message have been removed] > > > > > > |
04-05-2007, 04:38
Constant Door Chime
The first item in the Nutone online FAQ is:
What is the small electronic part that comes with the LA-52WH? It is a diode that needs to be put across the button that connects to the front terminals. The diode is polarized. If it does not work when first installed, then reverse the diode. On 4/5/2007 at 4:24 PM Keith Strehle wrote: >The Nutone tech support person said to "attach" the diode to the >terminals. No mention of polarity? I'm going to wrap the diode >wires around the terminal screws, hook it up and see what happen. If >it doesn't work, I'm out $2.59.... > > >--- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> >wrote: >> >> Hi Keith, >> >> Mine is 12V like yours. Are you saying to solder the diode between >> the two contacts on the back of the new switch? What polarity is >> recommended? Sounds like an easy fix and I already have a really >nice >> bronze switch to try out. >> >> -Shane Fedeli >> 85PT40 >> Hershey, PA >> >> --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" >> >> > >> > Mine does not have batteries in it. But it still works from the >> > button on the unit. Actually, it works fine from the remote >button, >> > except that it won't stop. The folks at Nutone said to attach >the >> > diode on the button teminals then attach the wires and it should >> > work. The diodes are availabble at Radio Shack. Only problem is >> > they come 25 to a package. The good news is they are $2.59 per >> > package. So, if you or anyone else needs a door bell diode.... >> > >> > Keith >> > 84FC35 >> > >> > --- In WanderlodgeForum@yahoogroups.com, James Harvie >> > >> > > >> > > Keith. Not sure if this will help you but, I got courious with >all >> > this door chime talk, seeing as mine didn't work either. Mine was >a 2 >> > part problem. First thing I did was to throw in a new set of >> > batteries. I pressed the switch, and nothing. So I took of the >cover >> > of the chime, and jumped the 2 wires and still nothing. I took >the >> > chime off of the wall and dug out the booklet for it and started >> > reading it. On the back , right under the part where it basicly >says >> > it's going to outlive you, there was what appeared to be some >type of >> > rectifier taped to the book. The scotch tape was rather yellow >and >> > brittle so not sure if it was a factory issue or not, but anyway, >I >> > took the circut board out of the plastic housing, and the >> > groundstrap, for one of the batteries fell out on the dinette >table >> > It looked like someone had dissassembled it and while >reassembling, >> > maybe put a little too much pressure on the tabs ( you have to do >> > this to get the board back in) I soldered the tab back >> > > on and traced down the location of the diode rectifier It >fits in >> > the D9 slot marked on the circut board. I was going to solder the >new >> > one in but decided to put it back together, I jumped the >terminals >> > while it was on the table, and off it went. I installed it back >on >> > the wall and again tried it, with the switch, and nothing. I >removed >> > the switch (mine has a brass rectangled backing plate about 1 >1/4" x >> > 2 1/2" or so, with a white button that looks like it should >light. I >> > threw my ohm meter across the terminals while on the bench, and >> > pressed the button, and no change on the meter, which told me the >> > switch was open. I layed the switch horizontally and sprayed CRC >> > Powerlube in the button. I like to use this lube for a few >reasons. >> > It's dielectric, which means you can use it in electrical >switches, >> > and dries after a day or so, so when you spray it inside your >> > ignition switch, you can put your keys in your pocket, without >> > staining your clothes.lol I use this on anything that >> > > moves. It works real well on the drawer slides etc. Anyway I >> > started pressing the button with the meter connected and after >about >> > a dozen times the meter started to move, the switch was stuck >open, >> > after a few more times moving it it was working fine. I tested >also >> > for a grounded switch and it wasn't grounded at the button, it's >> > insulated, I installed it back on the bus and although no light >it >> > works just fine, I think the light is not servicable, it looked >> > sealed. I hope this helps. >> > >> >> > Jimmy Harvie >> > >> >> > 82FC 35 SB >> > >> >> > Boston Ma >> > > >> > > Keith Strehle >> > > Hey Shane, I just called Nutone. The told me to go to >> > Radio Shack >> > > and pick up diode 1N4002 thru 1N4009. They said any of them >will >> > > work. I'll pick one up and let you know what happens. >> > > >> > > Keith >> > > 84FC35 >> > > >> > > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> >> > > wrote: >> > > > >> > > > Hi Keith, >> > > > >> > > > That same thing happened to me- I believe that it has >something >> > > to >> > > > do with the original door chime button being an "insulated" >> > switch. >> > > > Most of the newer residential ones are mounted to wood brick >> > molding >> > > > or a non-grounded aluminum screen door frame. In a residential >> > > > application, this doesn't matter because the door frame is not >> > > > grounded, so if the metal housing for a residential switch >> > contacts >> > > > the spring mechanism in the doorbell- nothing happens. On our >> > > coaches, >> > > > however, this creates problems because the skin of the coach >> > serves >> > > as >> > > > a ground and as soon as you attach to new doorbell, the >switch >> > > grounds >> > > > itself. Bluebird appears to have used an insulated switch >> > mechanism >> > > > where the spring does not contact the metal switch housing. >I'd >> > like >> > > > to replace mine too, but it's not very high on the priorities >> > list >> > > so >> > > > I did not pursue it. Please let us know if you find a suitable >> > > > replacement. >> > > > >> > > > Shane Fedeli >> > > > 85PT40 >> > > > Hershey, PA >> > > > >> > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" >> > > > >> > > > > >> > > > > It's a standard door bell switch from Home Depot. It >releases >> > > when >> > > > > you stop pushing. But even if you pushed it down and held >it >> > > there >> > > > > the bell should stop ringing until you push it again. >Otherwise >> > > > > every kid in the hood would be taping your dooebell button >> > down! >> > > > > It's a basic doorbell switch just like the one in my house. >> > > There >> > > > > must be something else to this story. ????????? >> > > > > >> > > > > Keith >> > > > > 84FC35 >> > > > > >> > > > > >> > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" >> > > > > >> > > > > > >> > > > > > Keith, Kevin is thinking you are using the wrong switch. >You >> > > need a >> > > > > > momentary switch like the old starter buttons; the moment >you >> > > push- >> > > > > > it makes contact, the moment you release- it loses >contact. >> > If >> > > the >> > > > > > doorbell button you are using now clicks when pushed, it >may >> > > > > unclick >> > > > > > when pushed the second time. That would be a POPO switch >> > > > > > >> > > > > > >> > > > > > I am looking for a door bell chime that rings like the >> > NewMoon >> > > > > > trailer in the LongLong Trailer movie. >> > > > > > GregoryO'Connor >> > > > > > 94PTRomolandCa >> > > > > > >> > > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" >> > > > > > >> > > > > > > >> > > > > > > Okay, I got it. SPST = Single Pole Single Throw. A SPST >> > > > > momentary >> > > > > > > switch returns to its normally open (off) position when >you >> > > > > release >> > > > > > > the button. A standard doorbell switch. It doesn't >solve >> > the >> > > > > > problem >> > > > > > > (yet) but I know what it is now... >> > > > > > > >> > > > > > > Thanks, Keith >> > > > > > > 84FC35 >> > > > > > > >> > > > > > > >> > > > > > > >> > > > > > > >> > > > > > > --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: >> > > > > > > > >> > > > > > > > Are you sure it's a momentary, SPST push button >switch? >> > > What >> > > > > > > happens when >> > > > > > > > you disconnect both wires from the switch? Does the >chime >> > > > > > stop? >> > > > > > > Touch the >> > > > > > > > wires together, does the chime turn on again? If so, >your >> > > > > > switch >> > > > > > > is the wrong >> > > > > > > > type. Use a multimeter on the switch contacts, and >see >> > > what >> > > > > the >> > > > > > > switch does. >> > > > > > > > The switch could be grounded also, with one of the >poles >> > > > > being >> > > > > > > momentary >> > > > > > > > "on" and the other always "on" always and off when >pushed. >> > > > > > > > >> > > > > > > > Kevin Mc >> > > > > > > > Yorba Linda, CA >> > > > > > > > 86 38 PT >> > > > > > > > >> > > > > > > > >> > > > > > > > >> > > > > > > > ************************************** See what's >free at >> > > > > > > http://www.aol.com. >> > > > > > > > >> > > > > > > > >> > > > > > > > [Non-text portions of this message have been removed] >> > > > > > > > >> > > > > > > >> > > > > > >> > > > > >> > > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > --------------------------------- >> > > Never miss an email again! >> > > Yahoo! Toolbar alerts you the instant new Mail arrives. Check >it >> > out. >> > > >> > > [Non-text portions of this message have been removed] >> > > >> > >> > > > > > >Yahoo! Groups Links > > > Don Bradner 90 PT40 "Blue Thunder" Eureka, CA |
04-05-2007, 05:00
Constant Door Chime
Thanks Don, it's a small project but didn't make sense so I couldn't
just drop it. One of the others here Shane(?) mentioned that he found a diode taped to the booklet that came with his Nutone door chime. Thanks, Keith 84FC35 --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > The first item in the Nutone online FAQ is: > > What is the small electronic part that comes with the LA-52WH? > > It is a diode that needs to be put across the button that connects to the front terminals. The diode is polarized. If it does not work when first installed, then reverse the diode. > > > On 4/5/2007 at 4:24 PM Keith Strehle wrote: > > >The Nutone tech support person said to "attach" the diode to the > >terminals. No mention of polarity? I'm going to wrap the diode > >wires around the terminal screws, hook it up and see what happen. If > >it doesn't work, I'm out $2.59.... > > > > > >--- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> > >wrote: > >> > >> Hi Keith, > >> > >> Mine is 12V like yours. Are you saying to solder the diode between > >> the two contacts on the back of the new switch? What polarity is > >> recommended? Sounds like an easy fix and I already have a really > >nice > >> bronze switch to try out. > >> > >> -Shane Fedeli > >> 85PT40 > >> Hershey, PA > >> > >> --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > >> > >> > > >> > Mine does not have batteries in it. But it still works from the > >> > button on the unit. Actually, it works fine from the remote > >button, > >> > except that it won't stop. The folks at Nutone said to attach > >the > >> > diode on the button teminals then attach the wires and it should > >> > work. The diodes are availabble at Radio Shack. Only problem is > >> > they come 25 to a package. The good news is they are $2.59 per > >> > package. So, if you or anyone else needs a door bell diode.... > >> > > >> > Keith > >> > 84FC35 > >> > > >> > --- In WanderlodgeForum@yahoogroups.com, James Harvie > >> > > >> > > > >> > > Keith. Not sure if this will help you but, I got courious with > >all > >> > this door chime talk, seeing as mine didn't work either. Mine was > >a 2 > >> > part problem. First thing I did was to throw in a new set of > >> > batteries. I pressed the switch, and nothing. So I took of the > >cover > >> > of the chime, and jumped the 2 wires and still nothing. I took > >the > >> > chime off of the wall and dug out the booklet for it and started > >> > reading it. On the back , right under the part where it basicly > >says > >> > it's going to outlive you, there was what appeared to be some > >type of > >> > rectifier taped to the book. The scotch tape was rather yellow > >and > >> > brittle so not sure if it was a factory issue or not, but anyway, > >I > >> > took the circut board out of the plastic housing, and the > >> > groundstrap, for one of the batteries fell out on the dinette > >table > >> > It looked like someone had dissassembled it and while > >reassembling, > >> > maybe put a little too much pressure on the tabs ( you have to do > >> > this to get the board back in) I soldered the tab back > >> > > on and traced down the location of the diode rectifier It > >fits in > >> > the D9 slot marked on the circut board. I was going to solder the > >new > >> > one in but decided to put it back together, I jumped the > >terminals > >> > while it was on the table, and off it went. I installed it back > >on > >> > the wall and again tried it, with the switch, and nothing. I > >removed > >> > the switch (mine has a brass rectangled backing plate about 1 > >1/4" x > >> > 2 1/2" or so, with a white button that looks like it should > >light. I > >> > threw my ohm meter across the terminals while on the bench, and > >> > pressed the button, and no change on the meter, which told me the > >> > switch was open. I layed the switch horizontally and sprayed CRC > >> > Powerlube in the button. I like to use this lube for a few > >reasons. > >> > It's dielectric, which means you can use it in electrical > >switches, > >> > and dries after a day or so, so when you spray it inside your > >> > ignition switch, you can put your keys in your pocket, without > >> > staining your clothes.lol I use this on anything that > >> > > moves. It works real well on the drawer slides etc. Anyway I > >> > started pressing the button with the meter connected and after > >about > >> > a dozen times the meter started to move, the switch was stuck > >open, > >> > after a few more times moving it it was working fine. I tested > >also > >> > for a grounded switch and it wasn't grounded at the button, it's > >> > insulated, I installed it back on the bus and although no light > >it > >> > works just fine, I think the light is not servicable, it looked > >> > sealed. I hope this helps. > >> > > >> > >> > Jimmy Harvie > >> > > >> > >> > 82FC 35 SB > >> > > >> > >> > Boston Ma > >> > > > >> > > Keith Strehle > >> > > Hey Shane, I just called Nutone. The told me to go to > >> > Radio Shack > >> > > and pick up diode 1N4002 thru 1N4009. They said any of them > >will > >> > > work. I'll pick one up and let you know what happens. > >> > > > >> > > Keith > >> > > 84FC35 > >> > > > >> > > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> > >> > > wrote: > >> > > > > >> > > > Hi Keith, > >> > > > > >> > > > That same thing happened to me- I believe that it has > >something > >> > > to > >> > > > do with the original door chime button being an "insulated" > >> > switch. > >> > > > Most of the newer residential ones are mounted to wood brick > >> > molding > >> > > > or a non-grounded aluminum screen door frame. In a residential > >> > > > application, this doesn't matter because the door frame is not > >> > > > grounded, so if the metal housing for a residential switch > >> > contacts > >> > > > the spring mechanism in the doorbell- nothing happens. On our > >> > > coaches, > >> > > > however, this creates problems because the skin of the coach > >> > serves > >> > > as > >> > > > a ground and as soon as you attach to new doorbell, the > >switch > >> > > grounds > >> > > > itself. Bluebird appears to have used an insulated switch > >> > mechanism > >> > > > where the spring does not contact the metal switch housing. > >I'd > >> > like > >> > > > to replace mine too, but it's not very high on the priorities > >> > list > >> > > so > >> > > > I did not pursue it. Please let us know if you find a suitable > >> > > > replacement. > >> > > > > >> > > > Shane Fedeli > >> > > > 85PT40 > >> > > > Hershey, PA > >> > > > > >> > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > >> > > > > >> > > > > > >> > > > > It's a standard door bell switch from Home Depot. It > >releases > >> > > when > >> > > > > you stop pushing. But even if you pushed it down and held > >it > >> > > there > >> > > > > the bell should stop ringing until you push it again. > >Otherwise > >> > > > > every kid in the hood would be taping your dooebell button > >> > down! > >> > > > > It's a basic doorbell switch just like the one in my house. > >> > > There > >> > > > > must be something else to this story. ????????? > >> > > > > > >> > > > > Keith > >> > > > > 84FC35 > >> > > > > > >> > > > > > >> > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > >> > > > > > >> > > > > > > >> > > > > > Keith, Kevin is thinking you are using the wrong switch. > >You > >> > > need a > >> > > > > > momentary switch like the old starter buttons; the moment > >you > >> > > push- > >> > > > > > it makes contact, the moment you release- it loses > >contact. > >> > If > >> > > the > >> > > > > > doorbell button you are using now clicks when pushed, it > >may > >> > > > > unclick > >> > > > > > when pushed the second time. That would be a POPO switch > >> > > > > > > >> > > > > > > >> > > > > > I am looking for a door bell chime that rings like the > >> > NewMoon > >> > > > > > trailer in the LongLong Trailer movie. > >> > > > > > GregoryO'Connor > >> > > > > > 94PTRomolandCa > >> > > > > > > >> > > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > >> > > > > > > >> > > > > > > > >> > > > > > > Okay, I got it. SPST = Single Pole Single Throw. A SPST > >> > > > > momentary > >> > > > > > > switch returns to its normally open (off) position when > >you > >> > > > > release > >> > > > > > > the button. A standard doorbell switch. It doesn't > >solve > >> > the > >> > > > > > problem > >> > > > > > > (yet) but I know what it is now... > >> > > > > > > > >> > > > > > > Thanks, Keith > >> > > > > > > 84FC35 > >> > > > > > > > >> > > > > > > > >> > > > > > > > >> > > > > > > > >> > > > > > > --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: > >> > > > > > > > > >> > > > > > > > Are you sure it's a momentary, SPST push button > >switch? > >> > > What > >> > > > > > > happens when > >> > > > > > > > you disconnect both wires from the switch? Does the > >chime > >> > > > > > stop? > >> > > > > > > Touch the > >> > > > > > > > wires together, does the chime turn on again? If so, > >your > >> > > > > > switch > >> > > > > > > is the wrong > >> > > > > > > > type. Use a multimeter on the switch contacts, and > >see > >> > > what > >> > > > > the > >> > > > > > > switch does. > >> > > > > > > > The switch could be grounded also, with one of the > >poles > >> > > > > being > >> > > > > > > momentary > >> > > > > > > > "on" and the other always "on" always and off when > >pushed. > >> > > > > > > > > >> > > > > > > > Kevin Mc > >> > > > > > > > Yorba Linda, CA > >> > > > > > > > 86 38 PT > >> > > > > > > > > >> > > > > > > > > >> > > > > > > > > >> > > > > > > > ************************************** See what's > >free at > >> > > > > > > http://www.aol.com. > >> > > > > > > > > >> > > > > > > > > >> > > > > > > > [Non-text portions of this message have been removed] > >> > > > > > > > > >> > > > > > > > >> > > > > > > >> > > > > > >> > > > > >> > > > >> > > > >> > > > >> > > > >> > > > >> > > > >> > > --------------------------------- > >> > > Never miss an email again! > >> > > Yahoo! Toolbar alerts you the instant new Mail arrives. Check > >it > >> > out. > >> > > > >> > > [Non-text portions of this message have been removed] > >> > > > >> > > >> > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > Don Bradner > 90 PT40 "Blue Thunder" > Eureka, CA > |
