Power problem in our bus
02-09-2007, 15:46
i checked at the two 50 amp breakers that are linked together in the
bedroom. they each had 110 v at the breaker and I have flipped them several times and they feel normal. is it possible that one is bad. is there anything else to check? thank you all for your help. Robert Rahn 88 pt 40 Kalispell, Mt. |
02-09-2007, 15:58
Did you check the input side or the outlet side of the breaker? I'm
betting you have a bad breaker if you have full voltage going to each breaker or leg. R.E. (Ron) Marabito, Dallas, TX 92WB40 currently in Hondo, TX --- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn" > > i checked at the two 50 amp breakers that are linked together in the > bedroom. they each had 110 v at the breaker and I have flipped them > several times and they feel normal. is it possible that one is bad. is > there anything else to check? thank you all for your help. > > Robert Rahn > 88 pt 40 > Kalispell, Mt. > |
02-09-2007, 16:01
Does the dead leg 1 have power out of the breaker? Both sides hot as Curt
suggested? Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Robert & Teri Rahn To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 09, 2007 9:46 PM Subject: [WanderlodgeForum] Power problem in our bus i checked at the two 50 amp breakers that are linked together in the bedroom. they each had 110 v at the breaker and I have flipped them several times and they feel normal. is it possible that one is bad. is there anything else to check? thank you all for your help. Robert Rahn 88 pt 40 Kalispell, Mt. [Non-text portions of this message have been removed] |
02-09-2007, 16:36
If both sides of the circuit breaker are hot, the only other thing I can think
of is check all of your wall outlets for GFI's and reset them. Maybe others have ideas to help. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 09, 2007 10:01 PM Subject: Re: [WanderlodgeForum] Power problem in our bus Does the dead leg 1 have power out of the breaker? Both sides hot as Curt suggested? Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Robert & Teri Rahn To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 09, 2007 9:46 PM Subject: [WanderlodgeForum] Power problem in our bus i checked at the two 50 amp breakers that are linked together in the bedroom. they each had 110 v at the breaker and I have flipped them several times and they feel normal. is it possible that one is bad. is there anything else to check? thank you all for your help. Robert Rahn 88 pt 40 Kalispell, Mt. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
