What PID's/ SID's/FID's are
02-06-2007, 05:42
Hello everyone:
For those who are not familiar with codes, multiplexing or other forms of reporting used in this day and age, I will attempt to bring to light a little about these systems in the later Coaches. The reporting codes and information are inputs and outputs much like on the computer you are using for the Forum. And each code is simply an address of where in a computer, the information is stored. So in order to get a readout for that code, you have to have the input/output (I/O) schedule for the addresses. Though we see the codes reported in decimal (number) form, the actual addresses are usually programmed in Hex or Octal or even machine coding, then converted to binary and finally to numbers. In doing this, one wire can be used to send a signal out on and to report back on several addresses depending on the speed of the polling process. The reason for the software, readers and so forth is to convert these multiplexed addresses to a form that we can attach a number to and have a readout of what code or instruction is in that address. The codes are usually preset with a read out of what it is. Example: A polling takes place sending out a question to a certain address, then if no flags are set nothing comes back. But if an address, such as the DDEC address for Low coolant is polled and a flag set, it sends back a number of 13. Then you look up the code on the map and it tells you, code 13 is coolant level sensor low, add coolant and the flag goes off satisfied. This is much simplified, to be sure, but the general idea comes across. Easy huh? Hope this helps a little for those wondering what people are talking about in some of the posts. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma |
02-06-2007, 08:06
Ralph, It may just be my nature but; I dont believe that all the
digital equipment is worth the worry. When I get a check engine light; I check the engine. If the heat goes up; I back off the demand. I have driven a good 400,000 on used class 8 diesel trucks with as much as 700,000 miles on the clocks. Things do not often go wrong and when they do: 1- it showes up in water/ oil heat and or performance or 2-too late even while you watch a PC digital stuff I see as more of a hobby. GregoryO'Connor 94ptRomolandCA --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Hello everyone: > > For those who are not familiar with codes, multiplexing or other forms of > reporting used in this day and age, I will attempt to bring to light a > little about these systems in the later Coaches. > > The reporting codes and information are inputs and outputs much like on the > computer you are using for the Forum. And each code is simply an address of > where in a computer, the information is stored. So in order to get a > readout for that code, you have to have the input/output (I/O) schedule for > the addresses. > > Though we see the codes reported in decimal (number) form, the actual > addresses are usually programmed in Hex or Octal or even machine coding, > then converted to binary and finally to numbers. In doing this, one wire > can be used to send a signal out on and to report back on several addresses > depending on the speed of the polling process. > > The reason for the software, readers and so forth is to convert these > multiplexed addresses to a form that we can attach a number to and have a > readout of what code or instruction is in that address. > > The codes are usually preset with a read out of what it is. Example: A > polling takes place sending out a question to a certain address, then if no > flags are set nothing comes back. But if an address, such as the DDEC > address for Low coolant is polled and a flag set, it sends back a number of > 13. Then you look up the code on the map and it tells you, code 13 is > coolant level sensor low, add coolant and the flag goes off satisfied. > > This is much simplified, to be sure, but the general idea comes across. > Easy huh? Hope this helps a little for those wondering what people are > talking about in some of the posts. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Ralph's RV Solutions, Duncan, Oklahoma > |
02-06-2007, 09:11
Greg: You are 100% correct about the engine data program and the Hobby element,
and I personally don't need a cell phone, in motion satellite TV, remote control HD flat screen, iPod, Two way radio, GPS, DVD, PSP, MP3, high speed cable internet, Xbox, VMSpc, Bluetooth, PC wireless laptop, WiFi, Broadband, Federal Income tax, State income tax, SUI, FUI, LUI, or even a Bluebird WB-40. That is a lot of @#$%. Beer is good! Except for the taxes, this day and age, the above make life a little more comfortable wouldn't you say? Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Gregory OConnor To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, February 06, 2007 2:06 PM Subject: [WanderlodgeForum] Re: What PID's/ SID's/FID's are Ralph, It may just be my nature but; I dont believe that all the digital equipment is worth the worry. When I get a check engine light; I check the engine. If the heat goes up; I back off the demand. I have driven a good 400,000 on used class 8 diesel trucks with as much as 700,000 miles on the clocks. Things do not often go wrong and when they do: 1- it showes up in water/ oil heat and or performance or 2-too late even while you watch a PC digital stuff I see as more of a hobby. GregoryO'Connor 94ptRomolandCA --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Hello everyone: > > For those who are not familiar with codes, multiplexing or other forms of > reporting used in this day and age, I will attempt to bring to light a > little about these systems in the later Coaches. > > The reporting codes and information are inputs and outputs much like on the > computer you are using for the Forum. And each code is simply an address of > where in a computer, the information is stored. So in order to get a > readout for that code, you have to have the input/output (I/O) schedule for > the addresses. > > Though we see the codes reported in decimal (number) form, the actual > addresses are usually programmed in Hex or Octal or even machine coding, > then converted to binary and finally to numbers. In doing this, one wire > can be used to send a signal out on and to report back on several addresses > depending on the speed of the polling process. > > The reason for the software, readers and so forth is to convert these > multiplexed addresses to a form that we can attach a number to and have a > readout of what code or instruction is in that address. > > The codes are usually preset with a read out of what it is. Example: A > polling takes place sending out a question to a certain address, then if no > flags are set nothing comes back. But if an address, such as the DDEC > address for Low coolant is polled and a flag set, it sends back a number of > 13. Then you look up the code on the map and it tells you, code 13 is > coolant level sensor low, add coolant and the flag goes off satisfied. > > This is much simplified, to be sure, but the general idea comes across. > Easy huh? Hope this helps a little for those wondering what people are > talking about in some of the posts. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Ralph's RV Solutions, Duncan, Oklahoma > [Non-text portions of this message have been removed] |
02-06-2007, 13:11
Greg:
I agree with the use of the KISS method and analog readouts. I had a couple of back channel questions concerning some of the technical talk lately and asked to shed a little light so more of an understanding might be had. So I wrote a little blurb to do that. The RV industry is behind the curve with technology but are starting to get away from relay logic and going to multiplexing systems. Of course this technology has been out for years in the industrial arena along with fiber optics and 422 and 232 communications with up to 25 nodes on each single conductor. All the high line coaches are just now starting to pick up on some of this stuff, The problem being, most of this technology was never meant to be rolling down the road at 70MPH in a 40K plus motor coach. Yep, give me the tried and true any day, but one has to keep up with on going technology or get left behind. blue tooth and how to program the VCR. lol Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 08:06 PM 2/6/2007 +0000, you wrote: >Ralph, It may just be my nature but; I dont believe that all the >digital equipment is worth the worry. When I get a check engine >light; I check the engine. If the heat goes up; I back off the >demand. I have driven a good 400,000 on used class 8 diesel trucks >with as much as 700,000 miles on the clocks. Things do not often go >wrong and when they do: >1- it showes up in water/ oil heat and or performance >or >2-too late even while you watch a PC > > >digital stuff I see as more of a hobby. > >GregoryO'Connor >94ptRomolandCA > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Hello everyone: > > > > For those who are not familiar with codes, multiplexing or other >forms of > > reporting used in this day and age, I will attempt to bring to >light a > > little about these systems in the later Coaches. > > > > The reporting codes and information are inputs and outputs much >like on the > > computer you are using for the Forum. And each code is simply an >address of > > where in a computer, the information is stored. So in order to get >a > > readout for that code, you have to have the input/output (I/O) >schedule for > > the addresses. > > > > Though we see the codes reported in decimal (number) form, the >actual > > addresses are usually programmed in Hex or Octal or even machine >coding, > > then converted to binary and finally to numbers. In doing this, >one wire > > can be used to send a signal out on and to report back on several >addresses > > depending on the speed of the polling process. > > > > The reason for the software, readers and so forth is to convert >these > > multiplexed addresses to a form that we can attach a number to and >have a > > readout of what code or instruction is in that address. > > > > The codes are usually preset with a read out of what it is. >Example: A > > polling takes place sending out a question to a certain address, >then if no > > flags are set nothing comes back. But if an address, such as the >DDEC > > address for Low coolant is polled and a flag set, it sends back a >number of > > 13. Then you look up the code on the map and it tells you, code 13 >is > > coolant level sensor low, add coolant and the flag goes off >satisfied. > > > > This is much simplified, to be sure, but the general idea comes >across. > > Easy huh? Hope this helps a little for those wondering what people >are > > talking about in some of the posts. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > |
02-06-2007, 15:46
Ralph, I'm glad you posted your explanation - I'm not surprised that there were
questions. As a 3-year user of VMSpc, I find the advantages to be several. First, my mind processes digital data better. I see 65 MPH more readily than I do a needle pointing at the corresponding spot on the analog gauge. Second, I get data that is not otherwise available. I really like, for example, to be able to see the cruise set speed, so I know when I hit resume what it is going to take me to. Worked better on the last coach where that number was retained between power-on sessions, but it still is good after spending 30 minutes passing through a town off the cruise. The remaining thing is the ability to set yellow and red alarms at my own choice of set points. I'm going to get a red light from coolant temperature well before I'm in trouble, and I hope the same will be true for coolant level. My copilot keeps an eye on the laptop, and alerts me the moment any status changes from green to any other color, without her having to know what numbers are "bad" ones. On 2/6/2007 at 7:11 PM Ralph L. Fullenwider wrote: >Greg: > >I agree with the use of the KISS method and analog readouts. > >I had a couple of back channel questions concerning some of the technical >talk lately and asked to shed a little light so more of an understanding >might be had. So I wrote a little blurb to do that. Don Bradner http://www.arcatapet.net |
02-07-2007, 03:28
Don, Input from the copilot is another thing I dont want in my bus.
T " its red" G "whats red" T "the thing you told me to watch" G "...............what happened to yellow" T "OK its yellow..........., now its red" G "Whats Red" T "Hold on, Its 4th and 3,.... RUN IT, DAM'IT RUN IT" G " Run WHAT!, What the hell is 4th & 3 ?" T " Florida vs WVU,.....I cant do two things at once, you watch the PMS-pc thing your self" G " Focus, we have a problem" T " OK OK , it says Windshield fluid low" GregoryO'Connor 94ptRomoland --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" wrote: > > Ralph, I'm glad you posted your explanation - I'm not surprised that there were questions. > > As a 3-year user of VMSpc, I find the advantages to be several. First, my mind processes digital data better. I see 65 MPH more readily than I do a needle pointing at the corresponding spot on the analog gauge. > > Second, I get data that is not otherwise available. I really like, for example, to be able to see the cruise set speed, so I know when I hit resume what it is going to take me to. Worked better on the last coach where that number was retained between power-on sessions, but it still is good after spending 30 minutes passing through a town off the cruise. > > The remaining thing is the ability to set yellow and red alarms at my own choice of set points. I'm going to get a red light from coolant temperature well before I'm in trouble, and I hope the same will be true for coolant level. My copilot keeps an eye on the laptop, and alerts me the moment any status changes from green to any other color, without her having to know what numbers are "bad" ones. > > On 2/6/2007 at 7:11 PM Ralph L. Fullenwider wrote: > > >Greg: > > > >I agree with the use of the KISS method and analog readouts. > > > >I had a couple of back channel questions concerning some of the technical > >talk lately and asked to shed a little light so more of an understanding > >might be had. So I wrote a little blurb to do that. > > Don Bradner > http://www.arcatapet.net > |
02-07-2007, 03:35
That would have to come in while I was drinking coffee!!! Spfffft
My copilot enjoyed it as well. On 2/7/2007 at 3:28 PM Gregory OConnor wrote: >Don, Input from the copilot is another thing I dont want in my bus. >T " its red" >G "whats red" >T "the thing you told me to watch" >G "...............what happened to yellow" >T "OK its yellow..........., now its red" >G "Whats Red" >T "Hold on, Its 4th and 3,.... RUN IT, DAM'IT RUN IT" >G " Run WHAT!, What the hell is 4th & 3 ?" >T " Florida vs WVU,.....I cant do two things at once, > you watch the PMS-pc thing your self" >G " Focus, we have a problem" >T " OK OK , it says Windshield fluid low" >GregoryO'Connor >94ptRomoland Don Bradner http://www.arcatapet.net |
