Water Heater
01-23-2007, 04:32
Post: #21
Water Heater
Thanks
Great help guys. I'm on hold till after Quartzsite. I hope it will hold , everything dry this morning. Spoke to Stephen trying to decide where to ship heater.Next stop for me should be Moab UT.Thanks again.. Mario 1985FC35 ( dry in the desert near Quartzsite ) |
01-23-2007, 06:54
Post: #22
Water Heater
Stephen,
Do any have a SS tank or are all alum.? Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Stephen Birtles To: WanderlodgeForum@yahoogroups.com Sent: Monday, January 22, 2007 2:33 PM Subject: [WanderlodgeForum] Re: water heater Force 10 works well also and is les expensive than seaward and we got them Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com krminyl@... wrote: > > I just went through this a few weeks ago (third time in 6 yrs). Before you > go through the R&R of the water heater, just make sure all of your fittings > are tight and secure. If the fittings aren't leaking, check the T&P valve on > the water heater (pressure release valve)...make sure it isn't dripping. > > If you have determined that it is the water heater, time to change it out. > Either Atwood, or Seaward brands work well...Seaward is cheaper by over a > hundred bucks....corrosion is the culprit in the tanks...aluminum. Seaward now > replaces the drain spigot with a magnesium anode, and they claim that the > anode gets eaten away, not the tank...drawback....tough to drain the tank > without a drain spigot....something to consider when you are trying to remove a > water heater weighing around a hundred pounds from a place with VERY limited > working room. > > Use the stainless braided hoses when re-attaching the hoses...lots easier to > connect...also, make sure that the area where the heater goes is completely > dried out from the leak. Mold can grow quickly, and you'll never get that > musty smell to go away. I spray the area with a mixture of bleach and water, > and let it dry with the help of a little 110v muffin fan for a few days or so. > Make sure that the power is turned off when working back there with the > wiring, and keep lots of towels handy to soak up the coolant (heat exchanger) > and water when removing the hoses. > > I hope a FC is easier than my PT...I swore to my wife this last time that > the BB is going to be sold if my new water heater leaks, instead of having to > go through the headache of removing the water heater again (I went with the > anode, not the drain valve...that sucker is heavy!) > > Good luck....been there, done that (a few times). > > Kevin McKeown > Yorba Linda, CA > 1986 38' Pt > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
01-23-2007, 06:59
Post: #23
Water Heater
Tom,
Mine works just fine. I did, however, upgrade my water pump to the newer 5.7 gpm Shurflow, and got rid of the accumulator tank system. I've run both the shower and galley sink at the same time without any drop in pressure. Don't worry about it. If it doesn't meet your expectations in the spring time, toss the braided hoses and go back with the crappy Qest piping...I don't think you'll have to. Kevin McKeown Yorba Linda, CA (Nice 78 degrees) 1986 38' PT [Non-text portions of this message have been removed] |
01-23-2007, 09:55
Post: #24
Water Heater
Aluminum Tank with either a stainless or galvanized shroud
Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > Stephen, > Do any have a SS tank or are all alum.? > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > ----- Original Message ----- > From: Stephen Birtles > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, January 22, 2007 2:33 PM > Subject: [WanderlodgeForum] Re: water heater > > > Force 10 works well also and is les expensive than seaward and we got them > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com krminyl@ wrote: > > > > I just went through this a few weeks ago (third time in 6 yrs). > Before you > > go through the R&R of the water heater, just make sure all of your > fittings > > are tight and secure. If the fittings aren't leaking, check the > T&P valve on > > the water heater (pressure release valve)...make sure it isn't > dripping. > > > > If you have determined that it is the water heater, time to change > it out. > > Either Atwood, or Seaward brands work well...Seaward is cheaper by > over a > > hundred bucks....corrosion is the culprit in the tanks...aluminum. > Seaward now > > replaces the drain spigot with a magnesium anode, and they claim > that the > > anode gets eaten away, not the tank...drawback....tough to drain the > tank > > without a drain spigot....something to consider when you are trying > to remove a > > water heater weighing around a hundred pounds from a place with VERY > limited > > working room. > > > > Use the stainless braided hoses when re-attaching the hoses...lots > easier to > > connect...also, make sure that the area where the heater goes is > completely > > dried out from the leak. Mold can grow quickly, and you'll never > get that > > musty smell to go away. I spray the area with a mixture of bleach > and water, > > and let it dry with the help of a little 110v muffin fan for a few > days or so. > > Make sure that the power is turned off when working back there with > the > > wiring, and keep lots of towels handy to soak up the coolant (heat > exchanger) > > and water when removing the hoses. > > > > I hope a FC is easier than my PT...I swore to my wife this last time > that > > the BB is going to be sold if my new water heater leaks, instead of > having to > > go through the headache of removing the water heater again (I went > with the > > anode, not the drain valve...that sucker is heavy!) > > > > Good luck....been there, done that (a few times). > > > > Kevin McKeown > > Yorba Linda, CA > > 1986 38' Pt > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > |
01-23-2007, 11:49
Post: #25
Water Heater
Kevin, or anybody that knows
I just recently spent a day hanging into the rear closet to install a hot water tank bypass. I don't envy you replacing the whole heater three times?? I used the stainless braided hoses to hook it back up. My question and my concern was if they allowed enough flow through with the reduced diameter? My coach is still winterized and I don't want to un-winterize just to test it. Thanks Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > I just went through this a few weeks ago (third time in 6 yrs). Before you > go through the R&R of the water heater, just make sure all of your fittings > are tight and secure. If the fittings aren't leaking, check the T&P valve on > the water heater (pressure release valve)...make sure it isn't dripping. > > If you have determined that it is the water heater, time to change it out. > Either Atwood, or Seaward brands work well...Seaward is cheaper by over a > hundred bucks....corrosion is the culprit in the tanks...aluminum. Seaward now > replaces the drain spigot with a magnesium anode, and they claim that the > anode gets eaten away, not the tank...drawback....tough to drain the tank > without a drain spigot....something to consider when you are trying to remove a > water heater weighing around a hundred pounds from a place with VERY limited > working room. > > Use the stainless braided hoses when re-attaching the hoses...lots easier to > connect...also, make sure that the area where the heater goes is completely > dried out from the leak. Mold can grow quickly, and you'll never get that > musty smell to go away. I spray the area with a mixture of bleach and water, > and let it dry with the help of a little 110v muffin fan for a few days or so. > Make sure that the power is turned off when working back there with the > wiring, and keep lots of towels handy to soak up the coolant (heat exchanger) > and water when removing the hoses. > > I hope a FC is easier than my PT...I swore to my wife this last time that > the BB is going to be sold if my new water heater leaks, instead of having to > go through the headache of removing the water heater again (I went with the > anode, not the drain valve...that sucker is heavy!) > > Good luck....been there, done that (a few times). > > Kevin McKeown > Yorba Linda, CA > 1986 38' Pt > > > [Non-text portions of this message have been removed] > |
05-30-2007, 08:21
Post: #26
Water Heater
Anyone got advice on replacing the 10 gal water heater on my 1983 PT-
35? I have not been able to find a direct replacement for the original American Appliance Mor Flo marine 10 model. Anyone try a tankless? Jim Elliott jaelou2@... 1983 PT-35 |
05-30-2007, 08:24
Post: #27
Water Heater
Jim:
Steve Birtles has a replacement and at a reasonable price. Or I have put in Atwood EH11 heaters with a minimum of piping change. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 08:21 PM 5/30/2007 +0000, you wrote: >Anyone got advice on replacing the 10 gal water heater on my 1983 PT- >35? I have not been able to find a direct replacement for the original >American Appliance Mor Flo marine 10 model. Anyone try a tankless? > >Jim Elliott >jaelou2@... >1983 PT-35 > > > > >Yahoo! Groups Links > > > Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma |
05-30-2007, 08:27
Post: #28
Water Heater
Forgot to mention, while you have the heater out of that pocket, take the 3
way valve apart on the bench and clean and lube it, that way you won't have to re visit that hole. At 08:21 PM 5/30/2007 +0000, you wrote: >Anyone got advice on replacing the 10 gal water heater on my 1983 PT- >35? I have not been able to find a direct replacement for the original >American Appliance Mor Flo marine 10 model. Anyone try a tankless? > >Jim Elliott >jaelou2@... >1983 PT-35 > > > > >Yahoo! Groups Links > > > Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma |
05-30-2007, 08:40
Post: #29
Water Heater
From: jaelou2 To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, May 30, 2007 3:21 PM Subject: [WanderlodgeForum] water heater In March I replace mine with a Force 10 from West Mairne. $285.00 with shipping. the shelf that covers the heater had to be cut down a little.Other then that it was not to bad of a job. Bob Loomas 1985 PT 36 Anyone got advice on replacing the 10 gal water heater on my 1983 PT- 35? I have not been able to find a direct replacement for the original American Appliance Mor Flo marine 10 model. Anyone try a tankless? Jim Elliott jaelou2@... 1983 PT-35 [Non-text portions of this message have been removed] |
08-28-2007, 06:04
Post: #30
Water Heater
Howard, it is located in the rear closet area behind a couple of panels.
Bluebird thought that was the most difficult place to access that thing- they were correct on that. Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
