Safe
09-18-2006, 01:53
Safe
RObert,
There is some info on the safe in the Files section.
The combo can be changed if the safe is open,
If it is locked shut, this could be expensive.$$$$
Do you know a safe cracker or a friendly Burglar???
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "chapelhill2901"
> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@>
> i found the safe under the seat, but i don't have the combination,
> so i guess i need to go to the lock smith.
> thanks,robert
> 1989 pt40
> oklahoma city, ok.
> > chapelhill2901,
> > Typically in the PT40 of that age, it is located under the rear
> > dinette seat. Hope you also got the combination in your
records,
> as
> > the key only unlocks the tumbler spinner dial.
> > Please sign your posts.
> > Thanks,
> > Mike Bulriss
> > 1991 WB40 "Texas Minivan"
> > San Antonio, TX
> > wrote:
> > > i just bought a 1985 pt40, and i found info., including a key,
> in the
> > > paprwork about a safe. i have looked every place i can think
of,
> but
> > > to no avail. any suggestions from anyone as to where one
might
> be.
09-18-2006, 02:16
Safe
Mine was unlocked but since I didn't have the special key to reset the
combination I took it
to a locksmith. It took a week or so since he himself had to order the special
key, but he
reset it for $50.
Kerry
82 FC 35
Denver
> thanks,robert
> 1989 pt40
> oklahoma city, ok.
> > chapelhill2901,
> > dinette seat. Hope you also got the combination in your records,
> as
> > Thanks,
> > Mike Bulriss
> > San Antonio, TX
> in the
> > > paprwork about a safe. i have looked every place i can think of,
> but
> > > to no avail. any suggestions from anyone as to where one might
> be.
01-18-2007, 18:18
Safe
How would I get the safe combination, previous owner never got it to
open.
Dale Cooper
85FC35sb
01-19-2007, 02:36
Safe
Dale: I just went through this problem. Do you have the original safe
manual? Try using the factory setting. The mfr. also told me that if
that does not work try going just over the #. For instance if it calls
for left 40 4 times, try 41. Hope this helps.
Bruce
1988FC35
01-19-2007, 03:25
Safe
Dale, If all else fails, I can walk you through removing the safe and opening it
from the back. A little involved, but it will work. Best Wishes, Doug Engel,
Gunnison, CO, 1981 FC35SB "Pokey"
dbcooper98 wrote: How would I get the safe
open.
Dale Cooper
85FC35sb
Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey"
Never miss an email again!
Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out.
01-19-2007, 05:26
Safe
Hi, I'm new here. I've been lurking about reading posts for a couple
days and posted some pix in the photo gallery last night. I don't own
a bird, but have been hired to help restore and upgrade one. I'm on a
quest to eventually be an expert on these, so reading through these
informative posts is very helpful.
My customer has the same problem with his safe. I'd love to be the
hero and get it open for him. Neither one of us have any info on this
unit & don't even know how many number sequences to look for, nor do
we know whether to start by turning CW or CCW. If I remove and open
from the back, can the tumblers be observed & correct combination be
figured out then? Who knows, maybe I'll find a million dollars in
there & can retire early Smile. Tim
--- In WanderlodgeForum@yahoogroups.com, Doug Engel
and opening it from the back. A little involved, but it will work.
Best Wishes, Doug Engel, Gunnison, CO, 1981 FC35SB "Pokey"
> open.
> Dale Cooper
> 85FC35sb
out.
01-19-2007, 05:55
Safe
Tim,
There is some info. on the safe in the files section of this forum.
Try this link. cut & paste
http://f1.grp.yahoofs.com/v1/EPmwRYm6SJZ...6nipehs0b7
FotuxusKFXtpZBV1qvg1dGFZN6UoNKn8mm5TJ8G88hlN5RTUnzvekgf/Safe_Combinati
on_doc.pdf
A lock smith, safe cracker is very expensive, The best idea someone
posted is to remove the safe, cut a hole in the back, and Yes, I
have opened the rear cover of the combination lock and reset the
combination. I did not have a safe combination , but fortunately our
safe was not locked.
Bill 88 FC
couple
own
a
this
do
be
> > open.
> > Dale Cooper
> > 85FC35sb
> out.
01-19-2007, 06:57
Safe
Tim, E-mail me at reddog@... with a phone # and I'll give you a call. Doug
n' Pokey
tims_rv wrote: Hi, I'm new here. I've been
> open.
> Dale Cooper
> 85FC35sb
out.
TV dinner still cooling?
Check out "Tonight's Picks" on Yahoo! TV.
01-19-2007, 06:58
Safe
Thanks! The link didn't work, but I found it where you said (in the
files section). I printed it up and will try it next time I'm there.
Wish me luck. Tim
> Tim,
> on_doc.pdf
our
> Bill 88 FC
> couple
> own
on
> a
these
> this
> do
open
> be
safe
work.
> > > open.
> > > Dale Cooper
> > > 85FC35sb
it
> > out.
01-19-2007, 07:34
Safe
I'd bet on the money being in D.B. Cooper's safe. He's been roaming around in a
Bird since he jumped out of that jet plane. I hope you both have
success opening your safe.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Friday, January 19, 2007 11:55 AM
Subject: [WanderlodgeForum] Re: safe
Tim,
on_doc.pdf
Bill 88 FC
couple
own
a
this
do
be
> > open.
> > Dale Cooper
> > 85FC35sb
> out.
