Sump Air Problem
12-26-2006, 23:04
Sump Air Problem
Kevin, I have been plagued with a sticky ride height valve. Dump your
suspension and try it again. I have a personal solution to my problem. My left side would not air up, but going out my drive the coach goes into a right hand lean- airs those bags right up. Ernie Ekberg 83PT40 Weatherford, tx [Non-text portions of this message have been removed] |
12-26-2006, 23:51
Sump Air Problem
Have a safe trip- glad I could help.
Ernie Ekberg 83PT40 Weatherford, tx sometimes my suspension sticks- sometimes it doesn't~ [Non-text portions of this message have been removed] |
12-27-2006, 03:50
Sump Air Problem
All:
I was getting ready to pull out this morning with my '82 PT-40 and the sump warning light will not go out. After airing up the front and rear air gauges show to be normal, but the Tag gauge is 0 PSI. The tag airbags and the front airbags are "not" aired up, but I do not hear any air leakage. Anyone have any ideas, before I cancel my vacation? Thanks. Kevin Ford 1982 PT-40 Richmond, TX |
12-27-2006, 04:12
Sump Air Problem
Thanks Ernie I will give that a try. If this doesn't work would it do
any damage to drive it to see if I can unstick something? Or drive 10 miles to a repair shop if I have too? Thanks you and this Forum are livesavers.... Kevin 82 PT-40 Richmond Tx --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Kevin, I have been plagued with a sticky ride height valve. Dump your > suspension and try it again. I have a personal solution to my problem. My left > side would not air up, but going out my drive the coach goes into a right hand > lean- airs those bags right up. > > Ernie Ekberg > 83PT40 > Weatherford, tx > > > > [Non-text portions of this message have been removed] > |
12-27-2006, 04:20
Sump Air Problem
Erine that fixed me up she airing up now. Thanks you saved my
vacation!!! On the road to San Marcos Tx... Kevin Ford 82 PT-40 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Kevin, I have been plagued with a sticky ride height valve. Dump your > suspension and try it again. I have a personal solution to my problem. My left > side would not air up, but going out my drive the coach goes into a right hand > lean- airs those bags right up. > > Ernie Ekberg > 83PT40 > Weatherford, tx > > > > [Non-text portions of this message have been removed] > |
