No amps reading on #2 alternator
04-21-2005, 15:10
Today we checked out further the output of a re-built alternator on my
92WB. Found out it is putting out just fine, but not indicating at
the ampmeter on dash. We determined that the instrument was O.K..
George at BB indicated problem could be circuit breaker or Bosch
Relay. No problem with circuite breakers, but unable to tell which
Bosch Relay is involved.
There are 6 in a row in the battery compartment and all are wired the
same and with color codes that are identical. Short of trial and
error replacement, anyone have any experience with the problem or know
which relay it is?
Thanks,
R.E. (Ron) Marabito, Moderator
04-21-2005, 15:28
Ron there should be nothing between your alternator and the amp meter other
then the shunt. When the current from the alternator passes thru the shunt
it produces a very low voltage drop across it proportional to the current
and its this voltage that is read by your dash amp meter. I suspect you may
have a wire off at the shunt or a bad connection(wire) between the chassis
and the dash. What year is your coach?
Tom
1982 FC35
Vernon Center,NY
In the beautiful Mohawk Valley
>which relay it is?
>Thanks,
>Yahoo! Groups Links
anderlodgeForum/
Wanderl\
04-21-2005, 15:37
Tom: I have a 92WB40. According to George in service at BB, when
the wire comes off the shunt, it is routed through a circuit breaker
and relay on this coach. Alternator #1 shows up just fine, but not
Alternator #2. I believe the dash switch probably controls the
relay switching between the two alternators.
I have not check the switch, and I guess that could be possible, but
when we switched output wires from the alternators and I got a good
reading then for #2 which was actually #1.
meter other
the shunt
current
suspect you may
chassis
> Tom
> 1982 FC35
> Vernon Center,NY
on my
at
which
know
> >which relay it is?
> >Thanks,
> >Yahoo! Groups Links
> > subject=Unsubscribe>WanderlodgeForum-unsubscribe@yahoogroups.com
04-21-2005, 16:20
Ron I am not familiar with the dual alternator setup on the PTs. But I am
willing to learn . Cant figure out why they would want to run the wire
thru a circuit breaker and/or a switch after the shunt? Doesnt the output
of both alternators go thru the same shunt?
Tom
1982 FC35
Vernon Center,NY
In the beautiful Mohawk Valley (except for tonight, its cold)
>meter other
>the shunt
>current
>suspect you may
>chassis
> > Tom
> > 1982 FC35
> > Vernon Center,NY
>on my
>at
>which
>the
>know
> > >which relay it is?
> > >Thanks,
> > >Yahoo! Groups Links
><<http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group\
> <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo!
> Terms of Service.
>Yahoo! Groups Links
anderlodgeForum/
Wanderl\
04-21-2005, 21:47
I have dual alternators on my coach. don't know why- but willing to learn,
also. Ernie 83PT40 in Texas
04-22-2005, 02:02
It appears to be two separate shunts.
Ron 92WB40
But I am
wire
output
> Tom
> 1982 FC35
> Vernon Center,NY
breaker
not
but
good
> >meter other
thru
> >the shunt
> >current
> >suspect you may
> >chassis
> > > Tom
> > > 1982 FC35
> > > Vernon Center,NY
alternator
> >on my
indicating
> >at
O.K..
Bosch
> >which
wired
> >the
problem or
> >know
> > > >which relay it is?
> > > >Thanks,
> > > >Yahoo! Groups Links
>Yahoo!
> > Terms of Service.
> >Yahoo! Groups Links
04-23-2005, 06:19
I don't think it was an option until '88 Ernie (not sure on the year).
- Jeff Miller
http://www.wanderlodge.net
learn,
