Breaking-in the new 77FC on Thanksgiving
11-25-2006, 12:23
We are really excited about our new Wanderlodge. I got our new 1977
FC31 home last Saturday from Eugene, OR. The 900 mile drive home
was mostly a pleasure, though my ears where ringing after 12.5
hours. I averaged 10 mpg - mostly 60-63 mph. (I think I can do
better with practice).
here are some pictures of the new rig, my wife Hillary, and her
sister at the beach near Ventura, CA where we spent Thanksgiving
(bbq'd the turkey)
http://www.pbase.com/bajaroad/wanderlodge
I must admit the purchase was a stressful process. The generator
wasn't as new as suggested, the engine heaters don't work, the
instrument panel lights are mostly out, the tach doesn't work, the
speedo is off by about 5%, the front tires are about 8yrs old, the
storage compartment pans are rusting badly, and the previous owner
didn't know the ins & outs of the rig's systems.
The interior, the body & paint, brakes, engine, and trans all seem
in good shape and well maintained.
The generator worked fine after I got home. In fact I used it to
power my saw to trim a low hanging tree. But later in the week it
wasn't cranking over. I could here the starter clicking when I
toggled the switch, but no crank. I removed the starter this
morning and it is definitely shot. One of the permanent magnets is
broken, but I'm not sure if I did that while initially persuading
the starter to work with a few light taps with a wrench. So I will
replace the starter and see if that was the problem.
? Anyone have experience with an Onan non-OEM replacement starter.
The issue I am most determined to remedy, but fear could get
expensive, is the generator slide-mount. Whoever installed the Onan
did a hack job and didn't maintain the same level of mechanical
structure. I had to use a come-along to pull it out. The Onan
doesn't require as much overhead clearance, so I would like to raise
the whole system while I'm at it.
? Has anyone had experience with these slide supports
Brent
77FC31
Ventura, CA
11-25-2006, 12:46
Congratulations on your purchase. It looks nice. Sounds like your generator
battery may
be bad. Do you have a switch tht connects the generator and engine batteries to
crank the
thing over when one set is weak? Did you try it when starting the generator?
Kerry82 Fc 35
Denver
--- In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber"
> (bbq'd the turkey)
> Brent
> 77FC31
> Ventura, CA
11-25-2006, 13:20
So why are you worried about an engine heater in California?
Definitely get rid of those old tires, or up your life insurance!
Check the age and condition on all of the batteries and replace as
needed. Maintenance is a fact of life, you didn't buy new so face
the music and buy, buy, buy what ever the Bird needs. It's not an
investment, it's a money pit that returns great pleasure to your
life.
Gardner
78FC33 (spending like a drunken sailor)
your generator battery may
engine batteries to crank the
generator?
> Kerry82 Fc 35
> Denver
1977
home
> > (bbq'd the turkey)
generator
owner
seem
to
it
is
persuading
will
starter.
Onan
raise
> > Brent
> > 77FC31
> > Ventura, CA
11-25-2006, 13:27
Kerry - I used a battery charger on the Gen battery and it indicated
a full charge very quickly, so the problem didn't appear to be the
battery. My battery charger has a start mode, which I tried with
similar results (click but no crank). Next I cleaned all the power
cables and ground cables that connect to the Gen with no
improvement..
generator?
> Kerry82 Fc 35
> Denver
1977
home
> > (bbq'd the turkey)
generator
owner
seem
to
it
is
persuading
will
starter.
Onan
raise
> > Brent
> > 77FC31
> > Ventura, CA
11-25-2006, 13:53
Brent, The '77 FC31 did not have a slide-out, what
you have is an after market add-on.
Tach is attached to front of engine, could be DC gen.
The coupling could be broken as well.
Valve to circulate water may be off, manual valve.
Age on tires says that would be priority item.
Tire size larger than std could affect the speedo or
it may just be off.
Tapping a starter to get the last out of it is a
sign the brushes are worn out and the armature is dirty.
You'll Love the Adventure,
Welcome, and happy trails in your new to you bird.
Bob Janes, '87FC35, Greenville, SC
1977
> (bbq'd the turkey)
Onan
raise
> Brent
> 77FC31
> Ventura, CA
11-25-2006, 18:06
---Don't you just love to hear all the things we have already been
thru that seemed like big things to us at the time! such as
the "water running out above the fuel tank." no problem, just turn
off the water because the tank is full!! whew!!
front tires are very important!! I like Garndners reply BEST SO
FAR..."spend like a drunken sailor." A money pit that gives
occasional pleasure.! I love it!! I love these birds!!
Wish I had one down here!! Back to poker. Sunday afternoon here.
Regards,
Hank Hannigan..In Australia..
90SP36
80FC31
Both stored in Vegas
In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw"
> life.
> Gardner
> generator?
> > Kerry82 Fc 35
> > Denver
new
> 1977
> home
do
her
Thanksgiving
> > > (bbq'd the turkey)
> generator
> the
> the
> owner
> seem
> to
week
> it
I
magnets
> is
> persuading
> will
> starter.
> Onan
mechanical
Onan
> raise
> > > Brent
> > > 77FC31
> > > Ventura, CA
11-26-2006, 03:35
Gardner,
The temperatures are supposed to drop to the low 60's later this
week, so yes I need that engine heater to work.
Seriously though, we camp in the snow so heat is a good thing. The
furnace heaters work well enough.
I do plan on buying tires, though these don't show signs of
cracking. Do they fail from the inside?
As for maintenance, I bought a maintenance-free Wanderlodge, so that
shouldn't be a problem.
Brent
Ventura,CA
77FC31
--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw"
> life.
> Gardner
> generator?
> > Kerry82 Fc 35
> > Denver
new
> 1977
> home
do
her
Thanksgiving
> > > (bbq'd the turkey)
> generator
> the
> the
> owner
> seem
> to
week
> it
I
magnets
> is
> persuading
> will
> starter.
> Onan
mechanical
Onan
> raise
> > > Brent
> > > 77FC31
> > > Ventura, CA
11-26-2006, 03:48
Brent, You brought home a winner, a maintenance-free
Wanderlodge is worth 10-15 grand more to you for the
first 3 years of operation.
Bob Janes, 87FC35, Greenville, SC
> Gardner,
that
> Brent
> Ventura,CA
> 77FC31
as
> > life.
> > Gardner
> the
> > generator?
> > > Kerry82 Fc 35
> > > Denver
> new
> > 1977
> > home
12.5
> do
> her
> Thanksgiving
> > > > (bbq'd the turkey)
> > generator
work,
> > the
old,
> > the
> > owner
> > seem
it
> > to
> week
> > it
> I
> magnets
> > is
> > persuading
I
> > will
> > starter.
> the
> > Onan
> mechanical
> Onan
to
> > raise
> > > > Brent
> > > > 77FC31
> > > > Ventura, CA
11-26-2006, 05:13
Mine starts pretty easily down into the 20's without using the block heater. It
will smoke
out the neighborhood for blocks around for about 15 minutes though. The heater
makes
for less smoke on start up. Make sure you have plenty of PowerServe in the tank
or the
appropriate mixture of #1 and #2 diesel in cold weather. Since you have a gas
generator,
you will always have the option of starting the generator and using the block
heater before
starting the CAT.
Kerry
82 FC 35
Denver
> Gardner,
> Brent
> Ventura,CA
> 77FC31
> > life.
> > Gardner
> the
> > generator?
> > > Kerry82 Fc 35
> > > Denver
> new
> > 1977
> > home
> do
> her
> Thanksgiving
> > > > (bbq'd the turkey)
> > generator
> > the
> > the
> > owner
> > seem
> > to
> week
> > it
> I
> magnets
> > is
> > persuading
> > will
> > starter.
> the
> > Onan
> mechanical
> Onan
> > raise
> > > > Brent
> > > > 77FC31
> > > > Ventura, CA
11-26-2006, 12:47
Brent,
I missed out on that 'maintenance free' option, so I bought the
extended warranty kit (tools, wire, blueprints, more tools, fuses,
10,000 watt flashlight, Advil, Beer, more Advil, more beer,
etc..etc...)
Gardner
78fc33
> Gardner,
The
that
> Brent
> Ventura,CA
> 77FC31
as
face
an
> > life.
> > Gardner
> the
> > generator?
> > > Kerry82 Fc 35
> > > Denver
Swartzentruber"
> new
> > 1977
> > home
12.5
can
> do
> her
> Thanksgiving
> > > > (bbq'd the turkey)
> > generator
work,
> > the
old,
> > the
> > owner
all
> > seem
it
> > to
> week
> > it
when
> I
this
> magnets
> > is
> > persuading
I
> > will
> > starter.
> the
> > Onan
> mechanical
> Onan
to
> > raise
> > > > Brent
> > > > 77FC31
> > > > Ventura, CA
