Cruise Control???
11-23-2006, 10:54
Cruise Control???
Hey Gang, Happy T-Day! Nothing like a day of BB chores. I think I have
a handle on my water problems, looks like a bad regulator/check valve
and a seeping Sporlan letting the water run in a loop instead of
building pressure when using the pump. Gonna look for parts tomorrow.
The cruise does not work on our rig, so we used the hand throttle on
the way home, kinda scary in traffic Sad. While adjusting the throttle
linkage, I saw a heavy gauage beaded chain laying in the valley under
the air plentum. I pulled gently on the chain (it was not attatched to
anything) and it came loose, bringing a short, light, broken cable
with
it. Is this the throttle/cruise connection? If so, where does it hook
up, is there some bellcrank assy that I am missing? Any light that
could be shed on the cruise control assy would be greatly appreciated.
Thanks as always. Doug
11-23-2006, 13:43
Cruise Control???
Yes, I believe that is the throttle cruise connection. On mine it goes from the
actuator to
the throttle linkage. Do you have an actuator in place? My vacuum generator
failed and I
decided it to replace the vacuum system with an electric version since the
vacuum system
did not work that well anyway.
Kerry
82 Fc 35
Denver
> with
11-23-2006, 15:21
Cruise Control???
If it's an '80-'83 FC it should have a vacuum-actuator for the cruise
control mounted to the rearmost bolts for the intake manifold,
driver's side.
- Jeff Miller
goes from the actuator to
generator failed and I
since the vacuum system
> Kerry
> 82 Fc 35
> Denver
have
valve
tomorrow.
throttle on
throttle
under
attatched to
cable
> > with
hook
that
appreciated.
11-23-2006, 15:41
Cruise Control???
Kerry, Thanks, The actuator is still in place, but no connection to the throttle
linkage, I'll do some recon tomorrow to look for connection opportunities. Doug
davidkerryedwards wrote: Yes, I believe that
is the throttle cruise connection. On mine it goes from the actuator to
failed and I
vacuum system
Kerry
82 Fc 35
Denver
> with
Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey"
Everyone is raving about the all-new Yahoo! Mail beta.
11-24-2006, 05:29
Cruise Control???
I''m in the same situation with my 83 FC35. Please keep us posted
on what you figure out.
Thanks,
Thomas
11-24-2006, 05:43
Cruise Control???
Mine attaches to the throttle linkage up above the rubber booted
component of the throttle linkage with the cable end at the actuator
and the ball chain at the linkage.
Kerry
82 FC 35
Denver-
the throttle linkage, I'll do some recon tomorrow to look for
actuator to
> Kerry
> 82 Fc 35
> Denver
have
attatched to
> > with
appreciated.
11-24-2006, 07:22
Cruise Control???
Thanks Kerry. I looked into it more today and found the ball chain component
that I had found connects to a vaccum dashpot via a small (read:tiny) cable. The
cable is broken. Any ideas on parts sources for this before I start fabricating?
What happened to the Broncos yesterday??? Doug
davidkerryedwards wrote: Mine attaches to the
Kerry
82 FC 35
Denver-
actuator to
> Kerry
> 82 Fc 35
> Denver
have
attatched to
> > with
appreciated.
Check out the all-new Yahoo! Mail beta - Fire up a more powerful email and get
things done faster.
11-24-2006, 10:07
Cruise Control???
Thomas, Currently, I have some similar cable and am going to try fabricating a
new one. I'll post the results. Doug
M Thomas Eastham wrote: I''m in the same situation
Thanks,
Thomas
