					Factory heated stuff
					08-31-2006, 00:21
					I am far from an expert on this...I live in So Cal, so winter freezing, and
			winterizing is something my BB has never experienced. That said, I believe all BB's have space heaters with their own thermostat underneath the kitchen sink, in the area where the water heater is, under the rear bed where the water pump us, and I think in the bathroom where the plumbing fixtures are. Most of the pipes are plumbed inside the coach, so theoretically, if the coach is below freezing inside, your pipes will be OK. And yes, most of the plumbing is copper pipe. Those who have experienced frozen and burst pipes usually replace with PEX plumbing, and seem very happy with it. As for the holding tanks, they are insulated with spray on styrene foam, but I don't think they are actually heated, The batteries once had heating elements, but most owners have thrown them away after they fail, and never replace them. Keep in mind I'm speaking of my 1986 PT...perhaps the newer models have more advanced freeze protection, but I kinda think that if you live in freezing temps, you need to keep the BB heated or in a heated facility if you want to assure yourself protection against busted plumbing due to the freezing, or spend a day winterizing your rig, and expect not to use it until the big chill is gone. I'm actually glad I now live in So Cal! Best of luck in your search. Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed]  |
					08-31-2006, 03:32
					I am a BB wan'a'be and have been reading every ad I can find until I
			get the right bird for us. I recently saw an ad on Ebay that says Heated tanks, Heater under the sink, heat tape on all pipes. All this is very importtant to us cold Canadians. Can some one tell me if these options are standard on all BB or if this guy has gone out of his way to do some serious winter camping? Are all BB plumbed with copper? Has anyone had problems with leaks? I have an Allegro that was plumbed with copper and had a lot of leaks until it redid it all with flexplex.  |
					08-31-2006, 06:03
					My 1982 FC35 had freeze heaters under the kitchen sink, under the
			bath sink and behind the water tank all with thermostats. The same for the 1985 PT 40 that I now have. In addition both have battery and holding tank heaters and engine heaters. Both also have thermostatically controlled heat tapes on the copper pipes from the water tank to the bath and to the kitchen. Both of them have hardened copper pipe and fixtures throughout the coach.If you follow the winterizing procedures faithfully and pour a little antifreeze in each trap you will not have a problem freezing. Tom Warner Vernon Center,NY 1985 PT 40 All of them are harAt 12:21 PM 8/31/2006, you wrote: >I am far from an expert on this...I live in So Cal, so winter freezing, and >winterizing is something my BB has never experienced. That said, I believe >all BB's have space heaters with their own thermostat underneath the kitchen >sink, in the area where the water heater is, under the rear bed >where the water > pump us, and I think in the bathroom where the plumbing fixtures > are. Most >of the pipes are plumbed inside the coach, so theoretically, if the coach is >below freezing inside, your pipes will be OK. And yes, most of the plumbing >is copper pipe. Those who have experienced frozen and burst pipes usually >replace with PEX plumbing, and seem very happy with it. > >As for the holding tanks, they are insulated with spray on styrene foam, but >I don't think they are actually heated, The batteries once had heating >elements, but most owners have thrown them away after they fail, and never >replace them. > >Keep in mind I'm speaking of my 1986 PT...perhaps the newer models have more >advanced freeze protection, but I kinda think that if you live in freezing >temps, you need to keep the BB heated or in a heated facility if you want to >assure yourself protection against busted plumbing due to the freezing, or >spend a day winterizing your rig, and expect not to use it until >the big chill is > gone. > >I'm actually glad I now live in So Cal! > >Best of luck in your search. > >Kevin McKeown >Yorba Linda, CA >1986 38' PT > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > >  |
