Strange Lever
08-19-2006, 06:10
Post: #31
Strange Lever
Hi Bob, take a trip over to St Anthony sand dunes in Idaho on Sept 1. I'm
finally going to take a couple days off work. It's been cool here in Montana.
Brenda is here till Wed. Had to clean up the coach before she got here. 2 dogs
and old man~
83 PT40
Livingston, Montana
08-19-2006, 08:19
Post: #32
Strange Lever
Mike, Canada allows visitors with 'quick witt' you gan get in armed.
unless your talking about the iron collectables so many Americans
hide behind.
94ptRomolandCa
<MHOHNSTEIN@...> wrote:
> I appreciate the thought, however I don't think I'll get over the
border with my weaponry.
> MH
> From: Stephen Birtles
> Sent: Saturday, August 19, 2006 11:50 AM
> Subject: [WanderlodgeForum] Re: Strange Lever
> Bill do you think we should invite mike up here for a holiday
between
> the east coast and the west coast we could drive him completely
around
> the bend
> Stephen 77fc35 from the east
> <MHOHNSTEIN@> wrote:
> > You seem to be a little too critical. I believe I said, "works
like
> electric trailer brakes "IN A WAY" and I have one more reason to
hate
> Canada.
> > MH
> > From: Wilhelmus Schreurs
> > Sent: Saturday, August 19, 2006 10:19 AM
> > Subject: Re: [WanderlodgeForum] Re: Strange Lever
> > Mike:
> > Not so at all.
> > Electric trailer brakes actually has a puck that rubs on the
drum
> which is attached to the brake shoes, which in turn stops the
trailer,
> so electrical/mechanical/mechanical, yuk, lots of wear and
maintenance.
> > With the Jacob's driveline retarder, it is electricity which
> creates a magnetic field to slow down the vehicle. there are no
> rubbing parts. Maintenance is very simple, cleaning, checking of
> contacts and greasing.
> > One thing which Jeff Miller alluded to, there is no connection
> between the driveline retarder and the rest of the system ,
> acceleration or braking. Gosh one of the things when I get my BB
home,
> I will look at installing circuitry that will either allow the
brake
> to be applied or disengage it when the throttle is applied.
> > Bill
> > 84FC35SB
> > Terrace, B.C.
> > Mike Hohnstein <MHOHNSTEIN@> wrote:
> > That would be one way to characterize the down grade retarder.
It
> functions like electric trailer brakes, in a way.
> > The well marked grease zerk, if not covered with road grime is a
> critical maintainence point. I'm greatful that my retarder works
> pretty well so far, my chassis has roughly 170k miles.
> > Mike Hohnstein
> > Germantown WI, Myrtle ID
> > 83FC35rb
> > From: Scott
> > Sent: Friday, August 18, 2006 11:25 PM
> > So this thing is like a driveline breaking system?
> > Scott Waldy
> > '83FC35SB
> > Boise, Idaho
> > --- In WanderlodgeForum@yahoogroups.com, "Scott"
> > wrote:
> > > Lots of great posts on the Jacobs Driveline retarder. (that
is what
> > is
> > > on our coach 86FC) BUT no one mentioned the need to grease
> > bearings
> > > inside. When we got ours you could not even tell it had a
grease
> > > fitting. Find it on the side of the retarder. Use a GOOD HIGH
TEMP
> > > GREASE. I grease mine pretty frequently.
> > > I did the dummy thing last year on the way to RIV and left it
one
> > by
> > > mistake when entering the highway, thought I was draging an
anchor,
> > > (actually felt like a fuel filter cloggin up) It got hot and
> > smelled,
> > > when shot with a temp gun it was just over 300* got back
underway
> > in a
> > > hurry and got air to it. No harm works fine. I use it in stop
> > go
> > > traffic, to limit the use of the service brakes. Works great
for me.
> > > ScottB
> > > 86FC 4sale
> > > SC
> > wrote:
> > > > I have a Strange Lever mounted to the side of the shifter
box.
> > The
> > > > lever goes into a small black box with numbers on the side.
As
> > the
> > > > lever is pulled down, the numbers increase and the lever is
> > > internally
> > > > notched to stop on each of the numbers. Any clue?
> > > > Scott Waldy
> > > > '83FC35SB
> > > > Boise, Idaho
> > Share your photos with the people who matter at Yahoo! Canada
Photos
08-19-2006, 09:33
Post: #33
Strange Lever
Hi Ernie: Carol and I are down in Jackson Hole,been fishing in the
Snake river. Great weather here, a little smoke from a couple fire's.
Best regard's...Bob 93pt
08-19-2006, 17:07
Post: #34
Strange Lever
So Greg,
With that philosophy of hiring as smart or smarter than you, which we
both share, we become the dumbest employees in the business. ;-)
Tommy 2 Shoes McCarthy
Poway. CA
95 PT42
> Bill, just check the nut behind the steering wheel. With all the
> safety systems you describe, the operator has limited chances to
make
> a mistake but many more chances for failed response from the
> retarder. Education from others like Scott talking of 'felt like
> dragging an anchor' is a good a way for all of us to recall the
fix.
> There was an instance in Ca where a fully loaded septic pumper
truck
> driver lost his brakes headed down hill. He was able to engage the
> engine driven pump. The input was capped and the load of the vacuum
> pump slowed the trucks engine and stopped the rig. I understand the
> only spill was in the cab. Had his rig a fail-safe system that did
> not allow it to be engaged while in motion, response from surprised
> motorist in his path would be literal. "S*&%"
> I will only allow operators as smart or smarter then myself to
drive
> my trucks.
> Gregory O'Connor
> 94ptRomolandCa
> Self-employed, no operators
> --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs
> > Mike:
> > Not so at all.
drum
> trailer, so electrical/mechanical/mechanical, yuk, lots of wear and
> maintenance.
> home, I will look at installing circuitry that will either allow
> brake to be applied or disengage it when the throttle is applied.
> > Bill
> > 84FC35SB
> > Terrace, B.C.
> retarder. It functions like electric trailer brakes, in a way.
> > Mike Hohnstein
> > 83FC35rb
> > From: Scott
> > Scott Waldy
> > '83FC35SB
> > Boise, Idaho
> > wrote:
> > > Lots of great posts on the Jacobs Driveline retarder. (that is
> what
> > is
> > > on our coach 86FC) BUT no one mentioned the need to grease the
> > bearings
grease
> TEMP
one
> > by
> anchor,
> > smelled,
underway
> > in a
> > go
for
> me.
> > > ScottB
> > > 86FC 4sale
> > > SC
box.
> > The
As
> > the
> > > internally
> > > > Scott Waldy
> > > > '83FC35SB
> > > > Boise, Idaho
Photos
