					Paint
					08-12-2005, 12:32
				Paint
					Ron.I need to know your color scheme on your bird. Must older birds
			where painted with Dupont Imron. Being a x Dupont jobber I probably have the Dupont numbers you need. Lee Condosta. Automotive Refinish Products. Sikkens,Lesonal,Utech,B.A.S.F.3M Distributor Wilmington N.C 85PT40  |
					08-12-2005, 13:02
				Paint
					Lee
			can you send me a email private becasue i need to talk to you about a paint deal thanks ahead of time woody 81fcrb at ft bragg nc- -- In WanderlodgeForum@yahoogroups.com, "lcondosta" wrote: > Ron.I need to know your color scheme on your bird. Must older birds > where painted with Dupont Imron. Being a x Dupont jobber I probably > have the Dupont numbers you need. Lee Condosta. Automotive Refinish > Products. Sikkens,Lesonal,Utech,B.A.S.F.3M Distributor Wilmington N.C > 85PT40  |
					07-20-2006, 07:56
				Paint
					Curt:
			I talked to Steve Birtles today about my paint codes. He says you may be able to decifer the numbers. I have not had success. Numbers follow: 92329----No clue what this number means. 73773----Base--Light silver--Frito-Lay Fleet I believe. 81573----Stripe--there are two different colored stripes. 79780----Light 81735----Dark Colors are---Light silver, dark silver, turquoise stripe, salmon? mauve? stripe. Thanks: Leroy Eckert 1990-WB-40 Niceville, FL  |
					07-20-2006, 09:52
				Paint
					Leroy,
			Sorry, my Wanderlodge Quick Reference Parts Catalog has paint codes from 1963 through the 1986 WLFC. I took the paint codes to an Automotive Paint Supply store. They got out their old Dupont Emron book and were able to make up the colors. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. jwasnewski wrote: > Curt: > I talked to Steve Birtles today about my paint codes. He says you may > be able to decifer the numbers. I have not had success. Numbers > follow: > > 92329----No clue what this number means. > 73773----Base--Light silver--Frito-Lay Fleet I believe. > 81573----Stripe--there are two different colored stripes. > 79780----Light > 81735----Dark > > Colors are---Light silver, dark silver, turquoise stripe, salmon? > mauve? stripe. > > Thanks: > > Leroy Eckert > 1990-WB-40 > Niceville, FL > >  |
					07-21-2006, 01:31
				Paint
					Hey Curt, would you happen to have the paint codes for my 83 FC35? Don't know
			what colors they used but mine are the brown and cream. There are pics in the photo section... Thank you Chris Reed 83 FC35 SB Plant City, FL Curt Sprenger Leroy, Sorry, my Wanderlodge Quick Reference Parts Catalog has paint codes from 1963 through the 1986 WLFC. I took the paint codes to an Automotive Paint Supply store. They got out their old Dupont Emron book and were able to make up the colors. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. jwasnewski wrote: > Curt: > I talked to Steve Birtles today about my paint codes. He says you may > be able to decifer the numbers. I have not had success. Numbers > follow: > > 92329----No clue what this number means. > 73773----Base--Light silver--Frito-Lay Fleet I believe. > 81573----Stripe--there are two different colored stripes. > 79780----Light > 81735----Dark > > Colors are---Light silver, dark silver, turquoise stripe, salmon? > mauve? stripe. > > Thanks: > > Leroy Eckert > 1990-WB-40 > Niceville, FL > > [Non-text portions of this message have been removed]  |
					07-21-2006, 02:26
				Paint
					in order to answer that question you have to know if your coach was
			built before or after 1/21/83 Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, Chris Reed wrote: > > Hey Curt, would you happen to have the paint codes for my 83 FC35? Don't know what colors they used but mine are the brown and cream. There are pics in the photo section... > Thank you > Chris Reed > 83 FC35 SB > Plant City, FL > > > Curt Sprenger > Leroy, > Sorry, my Wanderlodge Quick Reference Parts Catalog has paint codes from > 1963 through the 1986 WLFC. > > I took the paint codes to an Automotive Paint Supply store. They got out > their old Dupont Emron book and were able to make up the colors. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > jwasnewski wrote: > > > Curt: > > I talked to Steve Birtles today about my paint codes. He says you may > > be able to decifer the numbers. I have not had success. Numbers > > follow: > > > > 92329----No clue what this number means. > > 73773----Base--Light silver--Frito-Lay Fleet I believe. > > 81573----Stripe--there are two different colored stripes. > > 79780----Light > > 81735----Dark > > > > Colors are---Light silver, dark silver, turquoise stripe, salmon? > > mauve? stripe. > > > > Thanks: > > > > Leroy Eckert > > 1990-WB-40 > > Niceville, FL > > > > > > > > > > > [Non-text portions of this message have been removed] >  |
					07-21-2006, 02:34
				Paint
			built before or after 1/21/83 cream dupont 73964a after 1/12/83 dupont 73964u Light accent color Sand Metallic Dupont 44453u Dark Accent Dark Metalllic Brown Dupont 44444u Gold lh bird 3733516 gold rh bird 3733524 The last 2 number I dont think are dupont numbers but rather Bluebird number and seem to be an optional stripe Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, Chris Reed wrote: > > Hey Curt, would you happen to have the paint codes for my 83 FC35? Don't know what colors they used but mine are the brown and cream. There are pics in the photo section... > Thank you > Chris Reed > 83 FC35 SB > Plant City, FL > > > Curt Sprenger > Leroy, > Sorry, my Wanderlodge Quick Reference Parts Catalog has paint codes from > 1963 through the 1986 WLFC. > > I took the paint codes to an Automotive Paint Supply store. They got out > their old Dupont Emron book and were able to make up the colors. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > jwasnewski wrote: > > > Curt: > > I talked to Steve Birtles today about my paint codes. He says you may > > be able to decifer the numbers. I have not had success. Numbers > > follow: > > > > 92329----No clue what this number means. > > 73773----Base--Light silver--Frito-Lay Fleet I believe. > > 81573----Stripe--there are two different colored stripes. > > 79780----Light > > 81735----Dark > > > > Colors are---Light silver, dark silver, turquoise stripe, salmon? > > mauve? stripe. > > > > Thanks: > > > > Leroy Eckert > > 1990-WB-40 > > Niceville, FL > > > > > > > > > > > [Non-text portions of this message have been removed] >  |
					07-21-2006, 02:36
				Paint
					forgot to add air dry numbers are different
			--- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > in order to answer that question you have to know if your coach was > built before or after 1/21/83 > > Stephen 77fc35 > > > > --- In WanderlodgeForum@yahoogroups.com, Chris Reed > wrote: > > > > Hey Curt, would you happen to have the paint codes for my 83 FC35? > Don't know what colors they used but mine are the brown and cream. > There are pics in the photo section... > > Thank you > > Chris Reed > > 83 FC35 SB > > Plant City, FL > > > > > > Curt Sprenger > > Leroy, > > Sorry, my Wanderlodge Quick Reference Parts Catalog has paint codes > from > > 1963 through the 1986 WLFC. > > > > I took the paint codes to an Automotive Paint Supply store. They got > out > > their old Dupont Emron book and were able to make up the colors. > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > jwasnewski wrote: > > > > > Curt: > > > I talked to Steve Birtles today about my paint codes. He says you may > > > be able to decifer the numbers. I have not had success. Numbers > > > follow: > > > > > > 92329----No clue what this number means. > > > 73773----Base--Light silver--Frito-Lay Fleet I believe. > > > 81573----Stripe--there are two different colored stripes. > > > 79780----Light > > > 81735----Dark > > > > > > Colors are---Light silver, dark silver, turquoise stripe, salmon? > > > mauve? stripe. > > > > > > Thanks: > > > > > > Leroy Eckert > > > 1990-WB-40 > > > Niceville, FL > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > >  |
					07-24-2006, 13:01
				Paint
					81573 med lagoon met ford motor co 79780cumulus gray met ford motor
			co 81735 rose met ford motor co other two must be wrong codes Lee A Condosta BASF Jobber Holden Beach N.C 85PT40--- In WanderlodgeForum@yahoogroups.com, "jwasnewski" wrote: > > Curt: > I talked to Steve Birtles today about my paint codes. He says you may > be able to decifer the numbers. I have not had success. Numbers > follow: > > 92329----No clue what this number means. > 73773----Base--Light silver--Frito-Lay Fleet I believe. > 81573----Stripe--there are two different colored stripes. > 79780----Light > 81735----Dark > > Colors are---Light silver, dark silver, turquoise stripe, salmon? > mauve? stripe. > > Thanks: > > Leroy Eckert > 1990-WB-40 > Niceville, FL >  |
					07-24-2006, 13:42
				Paint
					leroy will probaly ship in but the second code i beilve should be
			79773 ithink thats what he said it was and the first I have no idea Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "lcondosta" wrote: > > 81573 med lagoon met ford motor co 79780cumulus gray met ford motor > co 81735 rose met ford motor co other two must be wrong codes Lee > A Condosta BASF Jobber Holden Beach N.C 85PT40--- In > WanderlodgeForum@yahoogroups.com, "jwasnewski" > wrote: > > > > Curt: > > I talked to Steve Birtles today about my paint codes. He says you > may > > be able to decifer the numbers. I have not had success. Numbers > > follow: > > > > 92329----No clue what this number means. > > 73773----Base--Light silver--Frito-Lay Fleet I believe. > > 81573----Stripe--there are two different colored stripes. > > 79780----Light > > 81735----Dark > > > > Colors are---Light silver, dark silver, turquoise stripe, salmon? > > mauve? stripe. > > > > Thanks: > > > > Leroy Eckert > > 1990-WB-40 > > Niceville, FL > > >  |
