FC 3208 Fan Bracket Plate
06-22-2006, 01:46
My recently acquired 84 FC35 has had 2 Horton Air Fans and 2 radiators
in as many years (not on my dime). There are no plates (spacers)
between the bolt heads and the fan bracket where the fan bolts to the
front of the engine and I would like to get some of these plates and
install them. Can anyone recall if these plates are simply flat stock
with 2 holes in them or is there more to them?
Thanks
David Hollis 84 FC35 Springfield,IL
06-22-2006, 01:50
3/16" flat stock will work well.
MH
Sent: Thursday, June 22, 2006 8:46 AM
Subject: [WanderlodgeForum] FC 3208 Fan Bracket Plate
Thanks
06-22-2006, 10:58
radiators
stock
> Thanks
as mike said,3/16 steel flatbar will work well,but when you drill the
holes they need to be offset just a bit to the side,or you may have to
grind a bevel on one side,the side that goes toward the bearing
casting,you have to make damn sure the flatbar is flat against the
casting when the bolts are tight.
randy
06-22-2006, 11:25
Thanks, Randy and Mike.
David Hollis
--- In WanderlodgeForum@yahoogroups.com, "randydupree2000"
> radiators
(spacers)
to
> the
> stock
> > Thanks
have to
> randy
06-29-2006, 14:09
They carry a cat part number, but like emike says they are just flat stock
re brake 1983 fc-35 sb " sagecoach"
-------------- Original message from "Mike Hohnstein" <MHOHNSTEIN@...>:
MH
Thanks
06-29-2006, 23:15
Thanks. Got them made and put on. Not sure if I got the wrong
Horton fan or if they are made in "one size fits all." The slots
where you bolt the fan to the front of the engine are about 1/2"
wide but the bolts are 3/8". I made some bushings.
flat stock
<MHOHNSTEIN@...>: --------------
> MH
> From: dthollis1961
radiators
stock
> Thanks
