Carpet Wet
04-22-2006, 00:44
Carpet Wet
My 1985 FC 35 Developed some klind of water leak . Carpet soaked from
the fridge to the hot water switch.Looked into the water tank area all seems dry. Before I start taking things apart any info available. Thanks in advance to all for your help. Mario 1985 FC 35 |
04-22-2006, 01:21
Carpet Wet
Mario:
Remove the kick plate under the last closet. The water tank extends under the closet behind that area. There is an indenture in the tank at that point and has been known to develop a split or crack in that area. Does it only leak when the tank is full? but not when 1/2 full? Also like Ernie mentioned, check the fittings from the water pump under the sink back to the tank. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 12:44 PM 4/22/2006 +0000, you wrote: >My 1985 FC 35 Developed some klind of water leak . Carpet soaked from >the fridge to the hot water switch.Looked into the water tank area all >seems dry. Before I start taking things apart any info available. >Thanks in advance to all for your help. > > Mario 1985 FC 35 > > > > |
04-22-2006, 01:27
Carpet Wet
Did you check under the kitchen sink, in my '83 that is where the
water pump is located. Where do you live? could it be a burst pipe caused by freezing pipes? It's not a problem here in florida, but elsewhere it's a big deal. There is also an access panel under the fridge. Thanks Bruce '83FCSB --- In WanderlodgeForum@yahoogroups.com, "ssyd1" <ssyd1@...> wrote: > > My 1985 FC 35 Developed some klind of water leak . Carpet soaked from > the fridge to the hot water switch.Looked into the water tank area all > seems dry. Before I start taking things apart any info available. > Thanks in advance to all for your help. > > Mario 1985 FC 35 > |
04-24-2006, 00:30
Carpet Wet
Icemakers are a common leaker, regardless of whether it's on or
off. The water supply hookup behind the grill is a garden hose type and can use a new washer on occasion. A leak can often manifest itself a long ways from the source. Good Luck, Gary Miller 83 FC 33 Milwaukee area --- In WanderlodgeForum@yahoogroups.com, "ssyd1" <ssyd1@...> wrote: > > My 1985 FC 35 Developed some klind of water leak . Carpet soaked from > the fridge to the hot water switch.Looked into the water tank area all > seems dry. Before I start taking things apart any info available. > Thanks in advance to all for your help. > > Mario 1985 FC 35 > |
