alternator and inverter dc charge
04-21-2006, 05:11
David, don't feel like a newbie- i believe we aren't supposed to know about
some things.Ernie-83pt40- electrically challenged
04-21-2006, 09:07
Folks,
Maybe you can help me understand something. When the
engine alternator is supplying electrical power and there's
a source of 120V ac power (shore power or generator),
and the house batteries require a charging current. Is the
charge current coming from the inverters and the alternator
or just from the alternator? If the charging current is coming
from just one source, alternator or inverter, what makes that
happen? For instance, if the charging current is from the
alternator, is there an isolator somewhere that isolates the
inverters, or do the inverters simply see a high voltage on
the batteries and back off into a float charge state?
Thanks, (Feel like a newbie all of a sudden)
David Brady
'02 LXi, Smokey
Va
04-21-2006, 10:39
David,
That's a reasonable question, sounds like the electrical
sources are butting heads to charge the battery, doesn't it?
The alternator has several poles in the stator windings that produce
several cycles per revolution each slightly out-of-phase. This AC
voltage is flattened out to a DC voltage by the use of a full-wave
bridge rectifier then regulated to output a nominal 14.5 VDC.
The alternator is not a smart charger so it tries to maintain the
14.5 volts DC and will unless the engine speed is reduced.
Except for wire, the alternator post, positive battery terminal, and
charger output terminal are at the same electrical potential, 14.5
VDC. The smart charger senses this voltage at the door, and,
realizing a no work period, rolls over and goes back to sleep.
Now if the engine stops, the alternator is on break. Provided the
genset is running, it's time to go to work bringing the battery
voltage to pre-defined set-points.
A converter changes AC to DC, an inverter changes DC to AC. The
word converter and charger are synonymous so what you have is a
inverter/converter combination.
Hope this answered your question.
Bob Janes
77 FC 31
Greenville, SC
--- In WanderlodgeForum@yahoogroups.com, David Brady
> Folks,
> David Brady
> '02 LXi, Smokey
> Va
04-21-2006, 11:10
Thanks Bob, crystal clear.
David
'02 LXi, Smokey,
Va
one_dusty_hoot wrote:
> David,
