					Heart Interface
					04-04-2006, 05:37
				Heart Interface
					Thanks, Jack. I haven't installed it, yet. The fella that I got it from  says
			it works great. He needs carpet and I think I need an inverter. Ernie-83pt40 in Louisiana, moving up to hi-tech [Non-text portions of this message have been removed]  |
					04-04-2006, 08:37
				Heart Interface
					Jack, i did get the external panel. this loooks like a project.  ernie-83pt40
			in l;ouisiana [Non-text portions of this message have been removed]  |
					04-04-2006, 08:38
				Heart Interface
					I just acquired a heart interface freedom combi inverter with the 3
			stage charger. It has a 2000 watt output. Anyone care to comment about this unit? Thanks, ERnie-83pt40 in Louisiana  |
					04-04-2006, 08:51
				Heart Interface
					Hi Ernie,
			I had one on my last two boats and on my last two motor homes. It's a great device, especially while dry camping. The 100 amp fixed rate charge cuts battery charging time way down. Jack '87FC35 "Traveller" Franklin, NC [Non-text portions of this message have been removed]  |
					04-04-2006, 10:05
				Heart Interface
					If you didn't get it, you will need the external control panel to get full
			benefit of all the system is capable of doing. Jack [Non-text portions of this message have been removed]  |
					04-04-2006, 14:03
				Heart Interface
					I replaced the old "boat anchor" chargers and the old inverter both with the
			Heart. It's a nice upgrade. Good luck. Jack '87 FC35 "Traveller" Franklin, NC [Non-text portions of this message have been removed]  |
					04-04-2006, 14:35
				Heart Interface
					Ernie,
			The inverter is the single most important update you can do to improve the usability of your Bird, IMO. Install it CORRECTLY, and you will be VERY satisfied with it. You can cut a number of corners to make the install go easier. I wouldn't, it really limits the ability, durability, and effectiveness of the inverter. Use a Link 1000 control(at least, better yet Link 2000R!) Wire the inverter so the power supplied to the inverter comes from a 30amp breaker in the factory Bluebird distribution panel. Install an additional distribution panel next to the factory distribution panel and move the loads from the factory panel to the additional panel. Move all outlets, the microwave, the ice maker, the curtains(if electric)over to the aux box. With the automatic internal switch engineered into the Inverter, all these items that have been moved from the factory distribution panel to the additional panel will have 110V all the time. With the remote copntroler(Link 1000, for example) you will be able to monitor your batterys as well as turn the inverter/charger on/off from inside the Bird. I mounted my Xantrex in the same location where the Redi-Line was removed. Use at least 3/0 battery cable wired directly to the batterys, both positive and ground(well, if you use a Link controller, there will be a shunt in the ground circuit) At Maxton rally, I had the electric skillet making breakfast, the coffee pot doin its thing, the outside TV and satellite tuner and the icemaker running- NO GENERATOR RUNNING-NO SHORE POWER-NO PROBLEM! My current Inverter is the 6th install I have done with this system, it works so good ;~}! Jay Darst 85PT40 Xantrex 85-2530-12 equipped(2,500 watt dual in/dual output) --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Thanks, Jack. I haven't installed it, yet. The fella that I got it from says > it works great. He needs carpet and I think I need an inverter. Ernie-83pt40 > in Louisiana, moving up to hi-tech > > > [Non-text portions of this message have been removed] >  |
					04-04-2006, 15:36
				Heart Interface
					If you are going to install a link 1000/2000/200R to monitor the
			Heart inverter/charger then you will also have to install a shunt so that all of the negative loads go thru it. You will also have to install a new load center just to carry the loads of those devices inside the coach that you want to run off the inverter. I installed the inverter/charger so that the wall receptacles in the front, kitchen and rear plus the microwave were powered off it. The hardest part on the PTs is to find a place to mount the Heart unit close to the batteries. The closer the better. Then you can run the AC lines up into the rear compartment in back of the bed and install the new load center in there. Just an idea. Has anyone else installed an inverter/charger in a PT? Just be aware if you want to get the full charging capability from the chargers you need at least a 10 gauge wire for the 2500 watt units. Tom Warner Vernon Center,NY 1982 FC35 (for sale soon) 1985 PT 40 (undergoing some modifications) At 08:37 PM 4/4/2006, you wrote: >Jack, i did get the external panel. this loooks like a project. ernie-83pt40 >in l;ouisiana > > >[Non-text portions of this message have been removed] > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >----------  |
					04-04-2006, 16:16
				Heart Interface
					Jay how did you install the distribution panel next to the main load
			center in your PT40. In my 1985 PT40 there is absolutely no room to mount one on the back wall. There is already a main load center, the 30 amp disconnect panel and a panel for the 3 cruise air solenoids. I am thinking of installing mine in the rear closet behind the center bed. There is already a switch there for the engine battery heaters, etc. What model Heart did you install? Is there any problem with moisture where the rediline is? Tom Warner Vernon Center,NY 1982 Fc35 (for sale soon) 1985 PT40 At 10:35 PM 4/4/2006, you wrote: >Ernie, > >The inverter is the single most important update you can do to improve >the usability of your Bird, IMO. > >Install it CORRECTLY, and you will be VERY satisfied with it. You can >cut a number of corners to make the install go easier. I wouldn't, it >really limits the ability, durability, and effectiveness of the >inverter. > >Use a Link 1000 control(at least, better yet Link 2000R!) > >Wire the inverter so the power supplied to the inverter comes from a >30amp breaker in the factory Bluebird distribution panel. Install an >additional distribution panel next to the factory distribution panel >and move the loads from the factory panel to the additional panel. >Move all outlets, the microwave, the ice maker, the curtains(if >electric)over to the aux box. > >With the automatic internal switch engineered into the Inverter, all >these items that have been moved from the factory distribution panel >to the additional panel will have 110V all the time. > >With the remote copntroler(Link 1000, for example) you will be able to >monitor your batterys as well as turn the inverter/charger on/off from >inside the Bird. > >I mounted my Xantrex in the same location where the Redi-Line was >removed. Use at least 3/0 battery cable wired directly to the >batterys, both positive and ground(well, if you use a Link controller, >there will be a shunt in the ground circuit) > >At Maxton rally, I had the electric skillet making breakfast, the >coffee pot doin its thing, the outside TV and satellite tuner and the >icemaker running- NO GENERATOR RUNNING-NO SHORE POWER-NO PROBLEM! > >My current Inverter is the 6th install I have done with this system, >it works so good ;~}! > >Jay Darst >85PT40 Xantrex 85-2530-12 equipped(2,500 watt dual in/dual output) > > >--- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > > > Thanks, Jack. I haven't installed it, yet. The fella that I got it >from says > > it works great. He needs carpet and I think I need an inverter. >Ernie-83pt40 > > in Louisiana, moving up to hi-tech > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >----------  |
					04-04-2006, 19:53
				Heart Interface
					thanks jay- this electrical stuff may be way over my head. ernie -83pt40 in
			louisiana [Non-text portions of this message have been removed]  |
