Coolant change
07-04-2005, 09:49
Coolant change
Any advice on changing and flushing cooling system in 82FC. I have not
been under yet for a close look but will draining the radiator also drain all the coolant from lines running to the back for hot water and chassis heat? Any suggestion on flushing system or should I just drain and refill with new coolant. I plan on using Cat antifreeze and hopefully can determine the exact capacity. Thanks Bill 82FC33 |
