1982 PT40 Air Compression
10-26-2012, 05:14
Hi Wayne,
Thank you so much for your feedback. I will forward this to Herman. He is coming back to California this weekend to resolve and get her on the road. Your info will be a great help. Jerry LeGris
On Fri, Oct 26, 2012 at 9:50 AM, waynekotila <"waynekotila@yahoo.com"> wrote:
Jerry LeGris, Broker Associate
Commercial & Residential
DRE # 00885785
Prudential Calif Realty
3728 Atlantic Ave.
Long Beach, CA 90807
Cell: 949 510-2370
Office: 562 989-4608
Fax: 562 989-4803
email: "jerrylegris@gmail.com"
Â
10-26-2012, 11:01
If you do have to replace one of your level control valves (in your case it sounds like the one above the front axle may be bad), they are a common heavy truck part and can be purchased from a trucking parts store. I had one of the back valves go bad about 5 years ago and only one side of my coach would air up. I think I paid about $30.00 forthe new valve andit doesn'ttake very long to change.
Good Luck
Wayne kotila
Buffalo, MN.
1996 PT42
From: Jerry LeGris To: WanderlodgeForum@yahoogroups.com Sent: Friday, October 26, 2012 12:14 PM Subject: Re: [WanderlodgeForum] Re: 1982 PT40 Air Compression Hi Wayne, Thank you so much for your feedback. I will forward this to Herman. He is coming back to
Jerry LeGris On Fri, Oct 26, 2012 at 9:50 AM, waynekotila <"waynekotila@yahoo.com"> wrote:
DRE # 00885785
3728 Atlantic Ave.
Cell: 949 510-2370
Fax: 562 989-4803
10-29-2012, 02:05
Jerry, Did Herman make any progress over the weekend? Thanks. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA "curtsprenger@gmail.com" One of the "Birds of a Feather" (BoF) Organizers On Fri, Oct 26, 2012 at 4:01 PM, Wayne Kotila <"waynekotila@yahoo.com"> wrote:
10-30-2012, 08:28
Hi Curt,
Yes. We rolled her yesterday, Mon 10-29 about 1 PM and they are headed to Cisco Texas. Diesel mechanic driving and Herman following in the Ford 150, loaded with tools etc. they are prepared to keep her running and a safe trip. as of this moment Tues 12:30 PM I have not gotten a call or update. I asked them to confirm a safe arrival. Praying fro traveling mercy for them. Thanks for your inquiry, both Herman and Bob and great down to earth guys.
Jerry
On Mon, Oct 29, 2012 at 6:05 AM, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
DRE # 00885785
3728 Atlantic Ave.
Cell: 949 510-2370
Fax: 562 989-4803
Â
10-30-2012, 16:01
Jerry, ÃÂ That's great. I'm always interested in WHY 'Birds won't air-up. Any resolutionÃÂ information that you can provide?ÃÂ Also, I'm currently tracking more than 1,700 'Birds. I'd like the two fellows contact information if you have it.ÃÂ Thanks.
Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA "curtsprenger@gmail.com" One of the "Birds of a Feather" (BoF) Organizers On Tue, Oct 30, 2012 at 12:28 PM, Jerry LeGris <"jerrylegris@gmail.com"> wrote:
11-01-2012, 10:39
Hi Curt,
New owner: Herman Eaker, Cisco, Texas.. buss- 254-4421047 His helper/mechanic was Bob. Very nice guys...good mechanics and learning every day. Jerry
On Tue, Oct 30, 2012 at 8:01 PM, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
DRE # 00885785
3728 Atlantic Ave.
Cell: 949 510-2370
Fax: 562 989-4803
Â
11-01-2012, 11:36
Thank you, Jerry. Do you have Herman'sÃÂ email address? I'll set him up in my database and also forward his information to the Lone Star Birds group. Herman is very close to several 'Bird owners in hisÃÂ area.ÃÂ ÃÂ
Curt Sprenger On Thu, Nov 1, 2012 at 2:39 PM, Jerry LeGris <"jerrylegris@gmail.com"> wrote:
11-01-2012, 12:15
HI Curt,
He is not email connected. One of his workers is: "Randy....captain475@yahoo.com" Maybe Herman will get re-setup. I have been telling him about Wanderlodge Forum etc and all the great support and family that helps each other.
Thanks, Jerry
On Thu, Nov 1, 2012 at 3:36 PM, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
DRE # 00885785
3728 Atlantic Ave.
Cell: 949 510-2370
Fax: 562 989-4803
Â
11-02-2012, 05:30
Hi Curt and others interested in "air
up"... On 10/30/2012 11:01 PM, Curt Sprenger wrote: ÃÂThis thread doesn't not sound exactly like my recent experience, but it may find it's way into your useful info? Mine is a 1995 BMC-37 Bird with a Spartan chassis of the MM series. I've had three hose failures in the past year, one air and two hydraulic -- all caused by vibration & chafe. This week, after hydraulic hose replacement the rear failed to air up while the front did air up. With Spartan tech help, the problem was suspected to be related to my use of the leveling jacks to provide maximum crawl space under the rear end [and lift the tire off the ground]. I learned there are three level control valves -- two front and one rear -- for 3-point support [IMHO kewl engineering]. With focus on the level control valve and the dump valve, my likely fix came down to trying:
the regular operating sequence again] [*]Tap the valves with a rubber hammer [sticky valve again but worse] [*]Lift and flip the level control valve actuating arm [a design shortcoming?] [/list] The first two are draconian but typical prior to valve replacement. The "flip" solution came as a surprise to me.ÃÂ It is described as the result of overextending the valve arm & adjustable link to the chassis.ÃÂ It seems that occasionally the arm can return in the wrong direction when storing the jacks.ÃÂ The test for this solution is to visually inspect the linkage.ÃÂ If the link is not essentially vertical then the valve arm probably is on the wrong side of the valve.ÃÂ The solution can be to raise the chassis again and guide the valve arm as the chassis is lowered.ÃÂ Best done from a pit?ÃÂ Or the solution may be to disassemble and reassemble in the correct orientation. In my case the first option worked.ÃÂ After cycling a couple times in the "barn" I use for winter storage where we did the maintenance, then moving the rig to another spot [for an unrelated reason], when moving back into the barn, the rear did air up.ÃÂ Now I'm wondering exactly what went wrong because I never got to the hammer nor the flip options. If you explained how I might search your database, I missed it.ÃÂ I'm sorry. What you are doing seems like a worthy work. Thank you and others on this reflector. I do hope my experience might be useful to someone in the future... George |
11-02-2012, 08:36
From George..."If you explained how I might search your database, I missed it. I'm sorry. What you are doing seems like a worthy work." ÃÂ My database is not available for searching.ÃÂ Many Birds owners do not want their information shared. What I have done is publish lists of informationÃÂ on WOG under Takin' It Easy, Birds of a Feather (BoF).ÃÂ Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA "curtsprenger@gmail.com" One of the "Birds of a Feather" (BoF) Organizers On Fri, Nov 2, 2012 at 9:30 AM, George F. VerDuin <"verduin@ameritech.net"> wrote:
