					bus lights
					03-27-2011, 12:09
				bus lights
				 Had a bulb that needed to be replaced at the top of the rear of my 1983 PT 35 WL . When I removed the fixture the wire came loose from a crimp connector inside a small hole only seen one wire which I reconnected and replaced the blub. When I replaced none of the light around the top of the bus would come on. Looked for bad fuse but could not locate. Does anyone know where the fuse is for the lights around the top of the coach and should there have been two wires to each light? Not sure if they are series or parallel wiring. The head lights and all other lights work , but none of the lights at the top of the coach will come on. Bill 1983 PT 35 WL PC FL  |
					03-27-2011, 13:12
				bus lights
					Bill:
			The power for the marker lights is in the over head load center a 15 amp breaker with a green 14 ga. wire number 31. The marker lights are orig a one wire unit with the ground supplied by one of the screws holding the body of the light on the Coach. Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma At 07:09 PM 3/27/2011 -0500, you wrote: >Had a bulb that needed to be replaced at the top of the rear of my 1983 PT >35 WL . When I removed the fixture the wire came loose from a crimp >connector inside a small hole only seen one wire which I reconnected and >replaced the blub. When I replaced none of the light around the top of the >bus would come on. Looked for bad fuse but could not locate. Does anyone >know where the fuse is for the lights around the top of the coach and >should there have been two wires to each light? Not sure if they are >series or parallel wiring. The head lights and all other lights work , but >none of the lights at the top of the coach will come on. > > > >Bill > >1983 PT 35 WL > >PC FL > >  |
					03-27-2011, 14:05
				bus lights
				 Thanks so much. Bill 1983 PT 35 WL PC FL. From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ralph L. Fullenwider   Bill: The power for the marker lights is in the over head load center a 15 amp breaker with a green 14 ga. wire number 31. The marker lights are orig a one wire unit with the ground supplied by one of the screws holding the body of the light on the Coach. Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma At 07:09 PM 3/27/2011 -0500, you wrote: >Had a bulb that needed to be replaced at the top of the rear of my 1983 PT >35 WL . When I removed the fixture the wire came loose from a crimp >connector inside a small hole only seen one wire which I reconnected and >replaced the blub. When I replaced none of the light around the top of the >bus would come on. Looked for bad fuse but could not locate. Does anyone >know where the fuse is for the lights around the top of the coach and >should there have been two wires to each light? Not sure if they are >series or parallel wiring. The head lights and all other lights work , but >none of the lights at the top of the coach will come on. > > > >Bill > >1983 PT 35 WL > >PC FL > >  |
