FEDERAL SMOG LAWS
12-11-2008, 10:29
FEDERAL SMOG LAWS
Hi all,
I'm going to jump in on this issue.
I receive email updates from the California Air Resources Board
regarding its regulations.
Below are excerpts of the latest Draft Proposed Regulation (dated Dec.
11, 2008) update email from the California Air Resources Board:
<http://www.arb.ca.gov/msprog/onrdiesel/d...ment_C.pdf>
"DRAFT PROPOSED REGULATION TO REDUCE EMISSIONS OF
DIESEL PARTICULATE MATTER, AND OTHER POLLUTANTS
FROM IN-USE HEAVY-DUTY DIESEL-FUELED VEHICLES
Adopt new section 2025, in title 13, article 4.5, chapter 1,
California Code of Regulations (CCR) to read as follows: (Note that
the entire text of section 2025 set forth below is new language
proposed to be added to the California Code of Regulations.)
Section 2025. Regulation to Reduce Emissions of Diesel Particulate
Matter, Oxides of Nitrogen and Other Criteria Pollutants, and
Greenhouse Gases from In-Use Heavy-Duty Diesel-Fueled Vehicles...
© Exemptions
This regulation does not apply to:
(11) Motor homes for non-commercial private use...
(d) Definitions
For purposes of this regulation, the following definitions apply:
(44) "Motorcoach (MC)" is a for hire, on-road motor vehicle having an
under floor luggage compartment separate from the passenger cabin used
for conveying passengers, is at least 35 feet in length, and is
designed for and has seating capacity for 40 or more passengers.
(45) "Motor Carrier" is the same as defined in California Veh. Code
section 408 for fleets other than those that are comprised entirely of
schoolbuses, which for the purposes of this regulation, means the
registered owner, lessee, licensee, school district superintendent, or
bailee of any schoolbus, who operates or directs the operation of any
such bus on either a for-hire or not-for-hire basis.
(46) "Motor Home" means a single vehicular unit designed for human
habitation for recreational or emergency occupancy and built on, or
permanently attached to, a self-propelled motor vehicle chassis,
chassis cab, or van, which becomes an integral part of the completed
vehicle."
The bottom line --
SECTION 2025, ©(11) specifically exempts motor homes.
SECTION 2025, (d)(44) and (45) defines a motorcoach and motor carrier
that operates a motorcoach.
SECTION 2025, (d)(46) defines a motor home.
As clearly stated, motor homes ARE NOT required under the proposed
regulations to modify, repower, or install any smog controls.
HOWEVER, if you use your motor home to conduct a business, as defined
by the California Code, you will probably be covered by the regulations.
I'll be posting a link to the CARB site that lists all the draft
regulation proposals on the SWBB website.
Phil Corpus
"iWander" 85PT40
Left Coast
http://southwest-bluebirds.org
12-11-2008, 10:53
FEDERAL SMOG LAWS
Phil; many thanks for getting this information and passing it along. This seems to be the true word and should dispel much of the rumor mill.
Wallace Craig
95 WLWB 42
Azle, Texas
--- On Thu, 12/11/08, iwander_85pt40 wrote:
From: iwander_85pt40 Subject: [WanderlodgeForum] FEDERAL SMOG LAWS
Date: Thursday, December 11, 2008, 4:29 PM
Hi all,
regarding its regulations. Below are excerpts of the latest Draft Proposed Regulation (dated Dec.
11, 2008) update email from the California Air Resources Board: <http://www.arb.ca.gov/msprog/onrdiesel/d...ent_C.pdf>
© Exemptions
(d) Definitions
vehicle."
The bottom line --
Phil Corpus
"iWander" 85PT40
Left Coast http://southwest-bluebirds.org
Yahoo! Groups Links
<*> Your email settings:
(Yahoo! ID required)
mailto:WanderlodgeForum-digest@yahoogroups.com mailto:WanderlodgeForum-fullfeatured@yahoogroups.com
12-11-2008, 11:20
FEDERAL SMOG LAWS
Hi Wallace,
Thanks.
Christina and I are still hoping you'll make it to Quartzsite.
It's going to be quite a party this time. I have a couple of
surprises that I'm working on and hope to spring on everyone.
Phil
'iWander' 85pt40
--- In WanderlodgeForum@yahoogroups.com, Wallace Craig
rumor mill.
> Wallace Craig
> 95 WLWB 42
> Azle, Texas
> From: iwander_85pt40 > Subject: [WanderlodgeForum] FEDERAL SMOG LAWS
> Hi all,
> © Exemptions
> (d) Definitions
> vehicle."
> The bottom line --
> Phil Corpus
> "iWander" 85PT40
> Left Coast
> Yahoo! Groups Links
