					BLUEBIRD CLOCK
					11-19-2008, 04:04
Post: #41
				BLUEBIRD CLOCK
					Leroy,
			Email your address. I'll send a tracing of the clock with measurements. On Wed, Nov 19, 2008 at 5:03 AM, Leroy Eckert <"jwasnewski@yahoo.com"> wrote:
 -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA  |
					11-19-2008, 05:46
Post: #42
				BLUEBIRD CLOCK
				 I have an original and will sell itfor $35,000. Andthe coach is free.
Cram-alot-inn
walker
84fc35
kcmo  |
					11-19-2008, 05:48
Post: #43
				BLUEBIRD CLOCK
					Leroy:
			The letters are 5/16 in. and are black transfer decals. The letter look to be "Arial" font. Don't hesitate to ask if you need anything else. Marv 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > Thanks, How big are the letters and what are they made of. Thanks again. > Leory Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > > --- On Tue, 11/18/08, Marv & Jean > From: Marv & Jean > Subject: [WanderlodgeForum] Re: Bluebird Clock > To: WanderlodgeForum@yahoogroups.com > Date: Tuesday, November 18, 2008, 7:47 PM > > > > > > > > > > > > Leroy: > > > > 20 1/2 in. from noxe to tip of bottom wing, 5 3/4 in. high and 1 1/2 > > inches thick. That is from an original clock out of a 1982. > > > > The numberals are: Blue Bird Emblem for 12 o'c;clock, W for 11, A > > for 10 and so forth until you spell out Wanderlodge. It looks to me > > if that is backwards but that is the way that they did it. Any other > > questions mine is in the room with me. > > > > Marv > > 2004 M380 > > Ocean Shores, WA > > > > --- In WanderlodgeForum@ yahoogroups. com, "Leroy A. Eckert" > > > > > > > > Anyone out there with a BB clock? If you would give me a measurement > > > from the nose of the bird to the end of the lower tail it would be > > > appreciated. Also, does the movement protrude out the back of the > > > wood? If so how far? > > > I cut a prototype today out of 3/4" thick wood and it is 19" long by > > > 6" high. It will accept a 2 3/4" to 3" quality quartz movement in > > the > > > wing. My prototype is made from white pine and the original will be > > > blonde. I plan to make 7 prototypes to see what I can do with them. > > I > > > will use red oak on others and I plan to prime, base coat and clear > > > coat some of the pine to see what happens. I don't have anything > > else > > > to do. Colors I am considering are rose,lagoon, black, red and > > blue. I > > > may air brush one in a bluebird style and see how that goes. I would > > > clear coat that one. I would like to put a chime movement in one of > > > them but it may need to be larger because of constraints in the size > > > if available dials. > > > > > > All are being hand made. > > > Thanks for any info. > > > > > > > > > Leroy Eckert > > > 1990 WB-40 Smoke N Mirrors > > > Dahlonega, GA > > > Royale Conversion > > > >  |
					11-19-2008, 10:45
Post: #44
				BLUEBIRD CLOCK
					11-19-2008, 14:59
Post: #45
				BLUEBIRD CLOCK
					gee sounds like a great deal!
			dwalks@... wrote:
					11-20-2008, 08:00
Post: #46
				BLUEBIRD CLOCK
				 Leroy, I have an extra clock I can send From:
