Exhaust Update
10-25-2008, 08:10
Exhaust Update
Exhaust Update, Still no parts from BB. Looking into 304 Stainless Steel for a custom built system. Crunched the numbers and it's about 35% more $'s I had to use an air chisel to rip the muffler off the muffler to flex connector pipe. Now that I'm inside the left side of the engine bay I can see I have a lot of work ahead of me. New insulation in the entire compartment, I could go on but it's depressing. ![]() Kurt Horvath 94 PT 42 Ground for repairs in 10AC |
10-25-2008, 12:02
Exhaust Update
--- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath"
wrote: > > > Exhaust Update, > > Still no parts from BB. > > Looking into 304 Stainless Steel for a custom built system. > > Crunched the numbers and it's about 35% more $'s > > I had to use an air chisel to rip the muffler off the muffler to flex > connector pipe. > > Now that I'm inside the left side of the engine bay I can see I have > a lot of work ahead of me. > > New insulation in the entire compartment, most of the hoses, all the > hoses, show some sort of wear or chaffing, The hydraulic fan needs a new > alarmstat, I might as well get the radiator checked out because it's > coming out. new turbo, exhaust blankets, all new clamps and rubber > connecting boots for the radiator and intake pipes, re-engineer the > mounting bracket for the exhaust pipe, it's to close to the turbo > for the exhaust blankets to fit on without cramming them in. A/C > compressor bracket need to be fixed , it's a bit worn in the mount > holes and the pulleys are off a few degree from inline with the belts, > wearing on one side of belts. > > I could go on but it's depressing. [ ![]() > > Kurt Horvath > > 94 PT 42 > > Ground for repairs in 10AC > Kurt, I don't know if this will help you any but when our 1993 had to have a new muffler and exhaust system, Jack worked with Ralph Fullenwider. They used 5 " components and those worked fine. Maybe you could contact Ralph and he could give you more information on our exhaust redo. I believe that Ralph is listed in the membership here. Regards, Liz Pearce 1993 WLWB Currently in Lakewood, NM |
