					Xantrex RV 3012 M Inverters & other stuff
					08-18-2008, 13:19
					Finally have the 2 new inverters and controls installed. It took a
			bit more than expected. The two inverters do fit into the inverter compartment with perhaps a ¼ to spare! One of the inline fuses was blown which wasn't an issue, they both had to be replaced with 400amp fuses upgraded from the old 250 amp fuses. Maryville Marine in Whitehouse TN did that part of the job. They upgraded some of the cables to handle the new load. Very professional and great price for labor, they do lots of Busses for the Nashville crowd. Very pleased with their work, they tested my old Freedom 458's both of them have dead boards in them, that with a blown fuses, they were baffled as to how anything was functioning. It also took a little time to decide how to FIX the wirering on the engine bulkhead between the engine compartment and the inverter bay. When they opened the side engine bay door they took a step back and after a long moment said, We've never seen anything like that! All I could say was, get over it, It's a BIRD! They did an exceptional job. They even liked the cooling fans mounted on the door of the inverter box. I also cut 2 - 4 1/2 holes on the inside back wall of the box, for air to enter thru. It will really blow with 3- 150 cfm fans mounted on the hinged door. I have them hooked up to power on the control panel for the engine compartment cooling fans. That is also working very well. The biggest problem was installing the controls in the side dash. I had to do three hours of fitting to get them in there without messing up the wood finish. I'm glad I caught that detail before I went to have the inverters installed I am very happy with these inverters, total cost two Xantex RV 3012 Inverters two RV- 7 GS controls installation with labor and parts, under $1800.00. A few other updates, the Indulgence now has all synthetic oils in everything you can put it in, engine, tranny, trans axle, wheels, generator, bulk fill tank needs to be drained and filled with syn oil but it's all done. I would say it's worth the trouble seems as though everything just works better. Empirical evidence, don't have it yet but I like what I see so far. I'm lacking cooling fans for the A/C condenser and the radiator but the controls and electric are in. Just home from ILL. Had a 6 day trip everything working fine.@#$#$% ^%! I should have never have said that within ear shot of the bus. There is a puddle of Hydraulic fluid under the right front bumper. The HWH system is leaking D--M!,,and just to ice the cake one bay door gas lift broke, and the propane gas outlet didn't work on the trip just in time to cook steaks for some guests. My wife read the NY Time article of our 2 friends and was in full agreement on the bottomless money pit statement. She'll get over it. Price of fuel is dropping! Gearing up for a three week trip at the end of Sept. Kansas and San Antonio. If anyone is up for a visit let me know we'll burn some beef and have a few cold ones:} Kurt Horvath 95 PT-42 WLWB 10AC  |
					08-18-2008, 15:53
					Kurt,
			We will expect to see you when you hit San Antonio this time! Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > Finally have the 2 new inverters and controls installed. It took a > bit more than expected. The two inverters do fit into the inverter > compartment with perhaps a ¼ to spare! One of the inline fuses was > blown which wasn't an issue, they both had to be replaced with 400amp > fuses upgraded from the old 250 amp fuses. Maryville Marine in > Whitehouse TN did that part of the job. They upgraded some of the > cables to handle the new load. Very professional and great price for > labor, they do lots of Busses for the Nashville crowd. > > Very pleased with their work, they tested my old Freedom 458's both > of them have dead boards in them, that with a blown fuses, they were > baffled as to how anything was functioning. It also took a little > time to decide how to FIX the wirering on the engine bulkhead between > the engine compartment and the inverter bay. When they opened the > side engine bay door they took a step back and after a long moment > said, We've never seen anything like that! All I could say was, get > over it, It's a BIRD! They did an exceptional job. > > They even liked the cooling fans mounted on the door of the inverter > box. I also cut 2 - 4 1/2 holes on the inside back wall of the box, > for air to enter thru. It will really blow with 3- 150 cfm fans > mounted on the hinged door. I have them hooked up to power on the > control panel for the engine compartment cooling fans. That is also > working very well. The biggest problem was installing the controls in > the side dash. I had to do three hours of fitting to get them in > there without messing up the wood finish. I'm glad I caught that > detail before I went to have the inverters installed I am very happy > with these inverters, total cost two Xantex RV 3012 Inverters two RV- > 7 GS controls installation with labor and parts, under $1800.00. > > A few other updates, the Indulgence now has all synthetic oils in > everything you can put it in, engine, tranny, trans axle, wheels, > generator, bulk fill tank needs to be drained and filled with syn oil > but it's all done. I would say it's worth the trouble seems as though > everything just works better. Empirical evidence, don't have it yet > but I like what I see so far. I'm lacking cooling fans for the A/C > condenser and the radiator but the controls and electric are in. > > Just home from ILL. Had a 6 day trip everything working fine.@#$#$% > ^%! I should have never have said that within ear shot of the bus. > There is a puddle of Hydraulic fluid under the right front bumper. > The HWH system is leaking D--M!,,and just to ice the cake one bay > door gas lift broke, and the propane gas outlet didn't work on the > trip just in time to cook steaks for some guests. My wife read the NY > Time article of our 2 friends and was in full agreement on the > bottomless money pit statement. She'll get over it. > > Price of fuel is dropping! > > Gearing up for a three week trip at the end of Sept. Kansas and San > Antonio. If anyone is up for a visit let me know we'll burn some beef > and have a few cold ones:} > > > Kurt Horvath > 95 PT-42 WLWB > 10AC >  |
					08-19-2008, 08:30
					Kurt,
			What part of Kansas. We will be working in Kansas from the end of Sept through Oct. -- Salina, Lawrence and KC area. If you are traveling I-70, let's try to hook up. We would love to meet you and trade money pit tours over a few cold ones. Trudy Lundgren Lisa Wade 1985 PT 40 Ã The Catbird Seat 917-699-7757 Currently in Rock Springs, WY > > Just home from ILL. Had a 6 day trip everything working fine.@#$#$% > ^%! I should have never have said that within ear shot of the bus. > There is a puddle of Hydraulic fluid under the right front bumper. > The HWH system is leaking D--M!,,and just to ice the cake one bay > door gas lift broke, and the propane gas outlet didn't work on the > trip just in time to cook steaks for some guests. My wife read the NY > Time article of our 2 friends and was in full agreement on the > bottomless money pit statement. She'll get over it. > > Price of fuel is dropping! > > Gearing up for a three week trip at the end of Sept. Kansas and San > Antonio. If anyone is up for a visit let me know we'll burn some beef > and have a few cold ones:} > > > Kurt Horvath > 95 PT-42 WLWB > 10AC >  |
					08-19-2008, 09:55
					Mike B,
			Call me. Kurt Horvath 95-PT-42WLWB 10AC Ku--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Kurt, > > We will expect to see you when you hit San Antonio this time! > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX  |
