pyrometer quite
05-08-2005, 14:21
pyrometer quite
The indicator on the pyrometer guage has not moved this year. Last
year it wouldn't stop moving. Do I start with the sensor/sender? dandarst86fc35rbhuntleyil. |
05-08-2005, 14:26
pyrometer quite
Dan,
Do you know where the sender is on that cute lil keeety CAT? :~) (VBG!) My sender was pretty rotten but still working when the new exhaust went on. New sender was under 20. my 2 cents Your YOUNGER brother Jay Darst 85PT40Springfield,IL --- In WanderlodgeForum@yahoogroups.com, "dandarst" wrote: > The indicator on the pyrometer guage has not moved this year. Last > year it wouldn't stop moving. Do I start with the sensor/sender? > > dandarst86fc35rbhuntleyil. |
05-08-2005, 14:36
pyrometer quite
nope
--- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > Dan, > Do you know where the sender is on that cute lil keeety CAT? :~) (VBG!) > > My sender was pretty rotten but still working when the new exhaust > went on. New sender was under 20. > > my 2 cents > > Your YOUNGER brother > Jay Darst > 85PT40Springfield,IL > > > > --- In WanderlodgeForum@yahoogroups.com, "dandarst" > wrote: > > The indicator on the pyrometer guage has not moved this year. Last > > year it wouldn't stop moving. Do I start with the sensor/sender? > > > > dandarst86fc35rbhuntleyil. |
05-08-2005, 14:42
pyrometer quite
Dan:
The sender is located to the rear of the bum out at the rear of the dog house on my '85. I had to repair the wire going to the sender once. Also the face plate on the gauge will move and bind the needle in the gauge. My sender is directly located in the top of the turbo exhaust piping screwed into the top of the pipe. Safe travels, Ralph Fullenwider Dream_35_Team '85FC35 in Oklahoma Ralph's RV Solutions At 02:21 AM 5/9/2005 +0000, you wrote: >The indicator on the pyrometer guage has not moved this year. Last >year it wouldn't stop moving. Do I start with the sensor/sender? > >dandarst86fc35rbhuntleyil. > > |
05-08-2005, 15:00
pyrometer quite
Thanks Ralph. Is this a Napa part?
dandarst86fc35rbhuntleyil. -- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > Dan: > > The sender is located to the rear of the bum out at the rear of the dog > house on my '85. I had to repair the wire going to the sender once. Also > the face plate on the gauge will move and bind the needle in the gauge. My > sender is directly located in the top of the turbo exhaust piping screwed > into the top of the pipe. > > Safe travels, > > Ralph Fullenwider > Dream_35_Team > '85FC35 in Oklahoma > Ralph's RV Solutions > > > At 02:21 AM 5/9/2005 +0000, you wrote: > >The indicator on the pyrometer guage has not moved this year. Last > >year it wouldn't stop moving. Do I start with the sensor/sender? > > > >dandarst86fc35rbhuntleyil. > > > > |
05-09-2005, 00:38
pyrometer quite
Dan:
I have never replaced one so have not done any research for a replacement. I don't know if Napa has it or not. Benny at BB may be able to tell you. Ralph At 03:00 AM 5/9/2005 +0000, you wrote: >Thanks Ralph. Is this a Napa part? > >dandarst86fc35rbhuntleyil. > >-- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > Dan: > > > > The sender is located to the rear of the bum out at the rear of >the dog > > house on my '85. I had to repair the wire going to the sender >once. Also > > the face plate on the gauge will move and bind the needle in the >gauge. My > > sender is directly located in the top of the turbo exhaust piping >screwed > > into the top of the pipe. > > > > Safe travels, > > > > Ralph Fullenwider > > Dream_35_Team > > '85FC35 in Oklahoma > > Ralph's RV Solutions > > > > > > At 02:21 AM 5/9/2005 +0000, you wrote: > > >The indicator on the pyrometer guage has not moved this year. Last > > >year it wouldn't stop moving. Do I start with the sensor/sender? > > > > > >dandarst86fc35rbhuntleyil. > > > > > > |
05-09-2005, 02:55
pyrometer quite
Dan,
I had to replace the complete Pyro system on my unit. When the exhaust flange broke it allowed the exhaust to burn the wires to the thermocouple. Those are calibrated wires and cannot be just spliced as I had tried to do. Then the pyro gauge in mine was obsolete and I had to get a new gauge. We ended up running a complete new wire front to rear and install a new sender and gauge. I got the whole system from Commercial Speedometer in West Sacramento, CA. They have the experience in repairing and installing these things that NAPA will never have. Check a local speedometer or instrument shop. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD Ralph L. Fullenwider wrote: > Dan: > I have never replaced one so have not done any research for a replacement. > I don't know if Napa has it or not. Benny at BB may be able to tell you. > > Ralph > > At 03:00 AM 5/9/2005 +0000, you wrote: > >>Thanks Ralph. Is this a Napa part? >> >>dandarst86fc35rbhuntleyil. >> >>-- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" >> >> >>>Dan: >>> >>>The sender is located to the rear of the bum out at the rear of >> >>the dog >> >>>house on my '85. I had to repair the wire going to the sender >> >>once. Also >> >>>the face plate on the gauge will move and bind the needle in the >> >>gauge. My >> >>>sender is directly located in the top of the turbo exhaust piping >> >>screwed >> >>>into the top of the pipe. >>> >>>Safe travels, >>> >>>Ralph Fullenwider >>>Dream_35_Team >>>'85FC35 in Oklahoma >>>Ralph's RV Solutions >>> >>> >>>At 02:21 AM 5/9/2005 +0000, you wrote: >>> >>>>The indicator on the pyrometer guage has not moved this year. Last >>>>year it wouldn't stop moving. Do I start with the sensor/sender? >>>> >>>>dandarst86fc35rbhuntleyil. >>>> >>>> > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > |
