					Polydyn TX7
					07-26-2007, 06:28
				Polydyn TX7
					Has anyone used this stuff before. I just put some in my Cummins engine and I
			swear it increased oil pressure. Or is it snake oil?http://www.polydyn.com/tx7.htm Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion [Non-text portions of this message have been removed]  |
					07-26-2007, 06:38
				Polydyn TX7
					Leroy,
			Tell us more about it. Just what is it suppose to do. Howard T., Sowega, Camilla, Ga. 86 PT40 > > From: "Leroy Eckert" > Date: 2007/07/26 Thu PM 02:28:10 EDT > To: > Subject: [WanderlodgeForum] Polydyn TX7 > > Has anyone used this stuff before. I just put some in my Cummins engine and I swear it increased oil pressure. Or is it snake oil?http://www.polydyn.com/tx7.htm > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > > > [Non-text portions of this message have been removed] > > >  |
					07-26-2007, 07:10
				Polydyn TX7
					It is supposed to extend engine life, reduce friction, decrease heat, increase
			oil pressure etc. It is some type of fluoropolymer that coats moving engine parts. It apparantly is extensively used in racing. It is expensive. $28.00/qt. It must be good. lol I thought I would try it in my Dodge on a long trip to California next week and see if it increases my fuel milage. That is all I have been able to learn. It also states it can be used in diesel engines. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: truitt44@... To: WanderlodgeForum@yahoogroups.com Sent: Thursday, July 26, 2007 1:38 PM Subject: Re: [WanderlodgeForum] Polydyn TX7 Leroy, Tell us more about it. Just what is it suppose to do. Howard T., Sowega, Camilla, Ga. 86 PT40 > > From: "Leroy Eckert" > Date: 2007/07/26 Thu PM 02:28:10 EDT > To: > Subject: [WanderlodgeForum] Polydyn TX7 > > Has anyone used this stuff before. I just put some in my Cummins engine and I swear it increased oil pressure. Or is it snake oil?http://www.polydyn.com/tx7.htm > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]  |
					07-26-2007, 07:28
				Polydyn TX7
					Leroy,
			Sounds to me at quick glance suspiciously like another one of those products that have been around since the 70s & 80s that Dupont brought suit against to prohibit use of the word "teflon" in their content or advertising. TFE or PTFE, polytetrafluoroethylene, more commonly known as Teflon, has been stated by Dupont as not effective for bonding to metal surfaces in the described fashion. While coated engine parts benefit from it, coated engines parts are done pre-assembly in temperatures much higher than your internal combustion engine will generate or withstand. That's roughly the story as I recall reading it.... Been discussed many times on the Net on different automotive enthusiast forums. I am sure that one of our chemically astute members will give you a more technical explanation soon. ;^) Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > It is supposed to extend engine life, reduce friction, decrease heat, increase oil pressure etc. It is some type of fluoropolymer that coats moving engine parts. It apparantly is extensively used in racing. It is expensive. $28.00/qt. It must be good. lol I thought I would try it in my Dodge on a long trip to California next week and see if it increases my fuel milage. That is all I have been able to learn. It also states it can be used in diesel engines. > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: truitt44@... > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, July 26, 2007 1:38 PM > Subject: Re: [WanderlodgeForum] Polydyn TX7 > > > Leroy, > Tell us more about it. Just what is it suppose to do. > Howard T., Sowega, Camilla, Ga. 86 PT40 > > > > From: "Leroy Eckert" > > Date: 2007/07/26 Thu PM 02:28:10 EDT > > To: > > Subject: [WanderlodgeForum] Polydyn TX7 > > > > Has anyone used this stuff before. I just put some in my Cummins engine and I swear it increased oil pressure. Or is it snake oil?http://www.polydyn.com/tx7.htm > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville, FL > > Royale Conversion > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] >  |
					07-26-2007, 07:30
				Polydyn TX7
					I recall using "Motor Medic" (a very heavy oil) in a very sick engine
			many years ago before trading in the old car... I note that TX-7 claims a viscosity of 60 -- so it's a heavy oil. That, alone, will tend to increase oil pressure, if enough of the product is used. However, that isn't, necessarily, a useful result if it is simply done by causing more resistance in the oil delivery system (by higher viscosity). Over the years, there have been many products with TFE (Teflon) as a component. All claim to coat the inside of the engine with Teflon to reduce friction. Since most of those other products didn't really work, I note that TX-7 claims to "burnish" the TFE into the metal at "wear points." They offer no proof that this has a better result than other TFE products. Many additives claim all sorts of engine efficiency improvements -- but none ever seem to have scientifically valid data to document the claims. (Anecdotal reports are not scientifically valid data.) The fact that it is used in race cars only means (1) that the manufacturer sponsors a race car or (2) that race car owners are willing to try experimental means if they think it may improve their performance. Race car drivers are also known to wear a "lucky" piece of clothing for the same result. Snake oil? Could be -- The stuff might work, but no real proof is provided. Diesel use also appears to be rather poorly documented, even on the manufacturer's web site. Personally, I wouldn't want to experiment on an engine that might cost $20,000 to rebuild if it causes a problem. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jul 26, 2007, at 12:10 PM, Leroy Eckert wrote: > It is supposed to extend engine life, reduce friction, decrease > heat, increase oil pressure etc. It is some type of fluoropolymer > that coats moving engine parts. It apparantly is extensively used > in racing. It is expensive. $28.00/qt. It must be good. lol I > thought I would try it in my Dodge on a long trip to California > next week and see if it increases my fuel milage. That is all I > have been able to learn. It also states it can be used in diesel > engines. > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: truitt44@... > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, July 26, 2007 1:38 PM > Subject: Re: [WanderlodgeForum] Polydyn TX7 > > > Leroy, > Tell us more about it. Just what is it suppose to do. > Howard T., Sowega, Camilla, Ga. 86 PT40 >> >> From: "Leroy Eckert" >> Date: 2007/07/26 Thu PM 02:28:10 EDT >> To: >> Subject: [WanderlodgeForum] Polydyn TX7 >> >> Has anyone used this stuff before. I just put some in my Cummins >> engine and I swear it increased oil pressure. Or is it snake oil? >> http://www.polydyn.com/tx7.htm >> Leroy Eckert >> 1990 WB-40"Smoke N Mirrors" >> Niceville, FL >> Royale Conversion >> >> >> [Non-text portions of this message have been removed] >> >> >> > > > > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed]  |
					07-26-2007, 07:36
				Polydyn TX7
					I suspected teflon but didn't know. Perhaps someone out there will.
			Thanks, Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: mbulriss To: WanderlodgeForum@yahoogroups.com Sent: Thursday, July 26, 2007 2:28 PM Subject: [WanderlodgeForum] Re: Polydyn TX7 Leroy, Sounds to me at quick glance suspiciously like another one of those products that have been around since the 70s & 80s that Dupont brought suit against to prohibit use of the word "teflon" in their content or advertising. TFE or PTFE, polytetrafluoroethylene, more commonly known as Teflon, has been stated by Dupont as not effective for bonding to metal surfaces in the described fashion. While coated engine parts benefit from it, coated engines parts are done pre-assembly in temperatures much higher than your internal combustion engine will generate or withstand. That's roughly the story as I recall reading it.... Been discussed many times on the Net on different automotive enthusiast forums. I am sure that one of our chemically astute members will give you a more technical explanation soon. ;^) Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > It is supposed to extend engine life, reduce friction, decrease heat, increase oil pressure etc. It is some type of fluoropolymer that coats moving engine parts. It apparantly is extensively used in racing. It is expensive. $28.00/qt. It must be good. lol I thought I would try it in my Dodge on a long trip to California next week and see if it increases my fuel milage. That is all I have been able to learn. It also states it can be used in diesel engines. > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: truitt44@... > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, July 26, 2007 1:38 PM > Subject: Re: [WanderlodgeForum] Polydyn TX7 > > > Leroy, > Tell us more about it. Just what is it suppose to do. > Howard T., Sowega, Camilla, Ga. 86 PT40 > > > > From: "Leroy Eckert" > > Date: 2007/07/26 Thu PM 02:28:10 EDT > > To: > > Subject: [WanderlodgeForum] Polydyn TX7 > > > > Has anyone used this stuff before. I just put some in my Cummins engine and I swear it increased oil pressure. Or is it snake oil?http://www.polydyn.com/tx7.htm > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville, FL > > Royale Conversion > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed]  |
					07-26-2007, 13:16
				Polydyn TX7
					Thanks Pete:
			Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Passing through Montgomery, AL ----- Original Message ----- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Thursday, July 26, 2007 2:30 PM Subject: Re: [WanderlodgeForum] Polydyn TX7 I recall using "Motor Medic" (a very heavy oil) in a very sick engine many years ago before trading in the old car... I note that TX-7 claims a viscosity of 60 -- so it's a heavy oil. That, alone, will tend to increase oil pressure, if enough of the product is used. However, that isn't, necessarily, a useful result if it is simply done by causing more resistance in the oil delivery system (by higher viscosity). Over the years, there have been many products with TFE (Teflon) as a component. All claim to coat the inside of the engine with Teflon to reduce friction. Since most of those other products didn't really work, I note that TX-7 claims to "burnish" the TFE into the metal at "wear points." They offer no proof that this has a better result than other TFE products. Many additives claim all sorts of engine efficiency improvements -- but none ever seem to have scientifically valid data to document the claims. (Anecdotal reports are not scientifically valid data.) The fact that it is used in race cars only means (1) that the manufacturer sponsors a race car or (2) that race car owners are willing to try experimental means if they think it may improve their performance. Race car drivers are also known to wear a "lucky" piece of clothing for the same result. Snake oil? Could be -- The stuff might work, but no real proof is provided. Diesel use also appears to be rather poorly documented, even on the manufacturer's web site. Personally, I wouldn't want to experiment on an engine that might cost $20,000 to rebuild if it causes a problem. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jul 26, 2007, at 12:10 PM, Leroy Eckert wrote: > It is supposed to extend engine life, reduce friction, decrease > heat, increase oil pressure etc. It is some type of fluoropolymer > that coats moving engine parts. It apparantly is extensively used > in racing. It is expensive. $28.00/qt. It must be good. lol I > thought I would try it in my Dodge on a long trip to California > next week and see if it increases my fuel milage. That is all I > have been able to learn. It also states it can be used in diesel > engines. > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Royale Conversion > ----- Original Message ----- > From: truitt44@... > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, July 26, 2007 1:38 PM > Subject: Re: [WanderlodgeForum] Polydyn TX7 > > > Leroy, > Tell us more about it. Just what is it suppose to do. > Howard T., Sowega, Camilla, Ga. 86 PT40 >> >> From: "Leroy Eckert" >> Date: 2007/07/26 Thu PM 02:28:10 EDT >> To: >> Subject: [WanderlodgeForum] Polydyn TX7 >> >> Has anyone used this stuff before. I just put some in my Cummins >> engine and I swear it increased oil pressure. Or is it snake oil? >> http://www.polydyn.com/tx7.htm >> Leroy Eckert >> 1990 WB-40"Smoke N Mirrors" >> Niceville, FL >> Royale Conversion >> >> >> [Non-text portions of this message have been removed] >> >> >> > > > > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]  |
