freshwater clear tubing
02-20-2007, 12:48
Folks,
I'm looking for a source for the house freshwater tubing used in our birds. The stuff in my BB appears to be a clear PVC with a braided reinforcement. It has a 3/4" inside diameter, but has very thick walls. I wasn't able to see a PSI spec, or any writing for that matter, on the hose. It seems to be a lot tougher than the similar 3/4" clear hose that West Marine sells. Thanks, David Brady '02 LXi, Smokey NC |
02-20-2007, 12:51
Lowe's or Home Depot should have it David. It's reinforced PVC plumbing
hose. Comes is various sizes. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T David Brady wrote: > Folks, > > I'm looking for a source for the house freshwater tubing > used in our birds. The stuff in my BB appears to be a clear > PVC with a braided reinforcement. It has a 3/4" inside diameter, > but has very thick walls. I wasn't able to see a PSI spec, or > any writing for that matter, on the hose. It seems to be a lot > tougher than the similar 3/4" clear hose that West Marine > sells. > > Thanks, > David Brady > '02 LXi, Smokey > NC > > [Non-text portions of this message have been removed] |
02-20-2007, 13:14
David:
I have bought mine at Ace Hardware. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 07:48 PM 2/20/2007 -0500, you wrote: >Folks, > >I'm looking for a source for the house freshwater tubing >used in our birds. The stuff in my BB appears to be a clear >PVC with a braided reinforcement. It has a 3/4" inside diameter, >but has very thick walls. I wasn't able to see a PSI spec, or >any writing for that matter, on the hose. It seems to be a lot >tougher than the similar 3/4" clear hose that West Marine >sells. > >Thanks, >David Brady >'02 LXi, Smokey >NC > > |
02-20-2007, 13:43
We all like the easy ones too David.
Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T David Brady wrote: > Folks, > > Thanks for the replies, I'm a little disappointed though that the > answer was so simple (lol)! Next time I promise to do more > homework. > > David B > '02 LXi, Smokey > NC > > Terry Neal wrote: > > Lowe's or Home Depot should have it David. It's reinforced PVC plumbing > > hose. Comes is various sizes. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] |
02-20-2007, 13:44
Folks,
Thanks for the replies, I'm a little disappointed though that the answer was so simple (lol)! Next time I promise to do more homework. David B '02 LXi, Smokey NC Terry Neal wrote: > Lowe's or Home Depot should have it David. It's reinforced PVC plumbing > hose. Comes is various sizes. > > Terry Neal > Bozeman, MT > 82PT40 6V92TA > 74FC34 6V53T > > > > > > > > > |
02-20-2007, 14:12
David, We use the innerbraid hose for the hydroseeders and not all of
the clear innerbrade is fit for potable use. The good news is the less expensive types are potable and so listed on the spool. When fitting the hose I heat up the section in hotwater first Gregory O'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Folks, > > Thanks for the replies, I'm a little disappointed though that the > answer was so simple (lol)! Next time I promise to do more > homework. > > David B > '02 LXi, Smokey > NC > > Terry Neal wrote: > > Lowe's or Home Depot should have it David. It's reinforced PVC plumbing > > hose. Comes is various sizes. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > > > > > > > > > > > > > > > > |
02-20-2007, 14:56
Thanks for the tip Gregory. I'll definitely try heating before bending;
the thick wall stuff can be a bit ornery. David B '02 LXi, Smokey NC Gregory OConnor wrote: > David, We use the innerbraid hose for the hydroseeders and not all of > the clear innerbrade is fit for potable use. The good news is the > less expensive types are potable and so listed on the spool. When > fitting the hose I heat up the section in hotwater first > > Gregory O'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, David Brady > wrote: > >> Folks, >> >> Thanks for the replies, I'm a little disappointed though that the >> answer was so simple (lol)! Next time I promise to do more >> homework. >> >> David B >> '02 LXi, Smokey >> NC >> >> Terry Neal wrote: >> >>> Lowe's or Home Depot should have it David. It's reinforced PVC >>> > plumbing > >>> hose. Comes is various sizes. >>> >>> Terry Neal >>> Bozeman, MT >>> 82PT40 6V92TA >>> 74FC34 6V53T >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> > > > > > > Yahoo! Groups Links > > > > > > [Non-text portions of this message have been removed] |
