1985 FC water problem
04-26-2005, 05:49
I finally was able to water and sanitized the water system. No leaks,
after that winter !!!!
The problem that I have is in the hot water system . No water hot or
otherwise.I have tried to follow the manual.I would appriciate if
anyone could help me. I'm that close to taking a (first)short trip.
Mario 1985 FC
04-26-2005, 06:00
Mario,
While not a standard feature on your Wanderlodge, someone may have
installed a water heater bypass circuit in the plumbing to assist with
winterizing the coach.
Assuming you have the side bath model, I'd pull up the bed (road side
if you have twins) and follow along the plumbing near the water
heater. If there are valves, turn them to the logical position to
allow flow through the heater.
Gary Miller
83 FC 33
Wauwatosa, WI
leaks,
> Mario 1985 FC
