					60/66 PSI Switch
					04-14-2006, 10:25
				60/66 PSI Switch
					I appreciate all the suggestions regarding the location of the 60/66psi
			indicator (switch). I've been in, out front, under the Bird and I'm still trying to locate that switch. I've check all the suggested places...up front behind the headlight area and load panel, Bluebird thought it's mounted_ in_ one of the two air tanks located in front of the drive axle. So far I'm not finding a matching (to Bluebird) switch in those locations, or anywhere for that matter. The switch that Bluebird sent me is a round metal case with black plastic and wire connection out one end, pipe threads out the other end...is this the right switch?. I'm wondering if Bluebird sent the correct switch. Is it possible that the 66 psi switch could have been changed out in a prior life with an air spring switch? Any more ideas where I should be looking? Curt Sprenger 1987 PT38, Anaheim Hills, Calif.  |
					04-21-2006, 03:29
				60/66 PSI Switch
					Curt did you ever find that pressure switch? I had to rebuild the one up
			front beginning of last year. Oene Pomper '85 PT40 >>> curtsprenger@... 04/14/06 6:25 PM >>> I appreciate all the suggestions regarding the location of the 60/66psi indicator (switch). I've been in, out front, under the Bird and I'm still trying to locate that switch. I've check all the suggested places...up front behind the headlight area and load panel, Bluebird thought it's mounted_ in_ one of the two air tanks located in front of the drive axle. So far I'm not finding a matching (to Bluebird) switch in those locations, or anywhere for that matter. The switch that Bluebird sent me is a round metal case with black plastic and wire connection out one end, pipe threads out the other end...is this the right switch?. I'm wondering if Bluebird sent the correct switch. Is it possible that the 66 psi switch could have been changed out in a prior life with an air spring switch? Any more ideas where I should be looking? Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Yahoo! Groups Links [Non-text portions of this message have been removed]  |
					04-21-2006, 06:24
				60/66 PSI Switch
					Oene,
			Yes I did find that switch. Yesterday. It's located up high on the frame cross member that is in front of the drive axle, on the rear side of that cross member. It's physical appearance/size is the same as the suspension switches. It only has one wire where the suspension switches have 2 wires. I found 4 of the look like suspension switches on our Bird. The Blue Box documentation says 3 switches for suspension, one for the 66 psi. Using a magnification mirror (extension type), flash light, and stretching my neck, I found the 60 6+/- lettering on the frame side of that switch.. The other 3 say 30 psi. Now all I need is a pit to stand in so I can reach up and R&R the switch. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Oene Pomper wrote: > Curt did you ever find that pressure switch? I had to rebuild the one up > front beginning of last year. > Oene Pomper > '85 PT40 > > > >>> curtsprenger@... 04/14/06 6:25 PM >>> > > I appreciate all the suggestions regarding the location of the 60/66psi > > indicator (switch). I've been in, out front, under the Bird and I'm > still trying to locate that switch. I've check all the suggested > places...up front behind the headlight area and load panel, Bluebird > thought it's mounted_ in_ one of the two air tanks located in front of > > the drive axle. So far I'm not finding a matching (to Bluebird) switch > > in those locations, or anywhere for that matter. The switch that > Bluebird sent me is a round metal case with black plastic and wire > connection out one end, pipe threads out the other end...is this the > right switch?. I'm wondering if Bluebird sent the correct switch. Is it > > possible that the 66 psi switch could have been changed out in a prior > > life with an air spring switch? Any more ideas where I should be > looking? > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > Yahoo! Groups Links > > > > > > > > > [Non-text portions of this message have been removed] > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ >  |
