Tire monitoring system
10-24-2005, 08:16
Hi All Has anyone ever heard of this monitoring system? I had a valve stem
failure this past week and am thinking about one. I don't know about the way
it is monitored through the caps that are screwed on the valve stems. What
do you think? www. tirepressure monitor. com/# Remove the spaces
Don
89 SP 36'
Butler, PA
10-24-2005, 19:22
Don,
We have the system only it's not under pressure pros name. D------ Damon or
??. It's great - - - and expensive. About $600 for 6 MH tires and 4 toad
tires. I luv the sense of security it gives me - - - - especially after we had
a
toad front flat and didn't know it. Could have ended up towing a ball of fire.
It continually monitors pressure and each tire transmitter send a signal to
the monitor every 5 minutes.
Ed Nowokunski
95BMC37
10-24-2005, 20:26
Don,
Here's the D----- web site. D is for Doran. I believe Doran is the
manufacturer and sells to pressure pro.
_http://www.doranmfg.com/tirepressuremonitors.htm_
(http://www.doranmfg.com/tirepressuremonitors.htm)
Ed Nowokunski
95BMC37
10-24-2005, 22:03
In a message dated 10/25/2005 8:31:18 A.M. Eastern Daylight Time,
enow626@... writes:
Don,
Ed Nowokunski
95BMC37
Thanks Ed I see what you mean they are both the same& the same price
Don
89 SP 36'
Butler, PA
10-25-2005, 01:44
In a message dated 10/25/2005 7:23:24 A.M. Eastern Daylight Time,
enow626@... writes:
Don,
had a
fire.
Ed Nowokunski
95BMC37
Thanks Ed The one I saw is the same as yours.
Don
89 SP 36'
Butler, PA
