Part Numbers Needed - (Cross posted!)
08-06-2005, 00:56
Does anyone have the current part #s for the Kohler Generator end
parts below. The gen is/was on a 35' FC 1982. Powered by Perkins 4 cyl. The new owners of our coach wants to convert the gen back to original equipment. 1. Rotor 2. Stator 3. Brush holder 4. Brush Thanks. If you want to take offline use: wjmorganjr@... Billy Morgan ex 82FC35 3208NA SB ex Chesapeake VA |
08-06-2005, 05:59
Billy:
Actually there are several different part numbers for the 12.5KW Kohler. We need the spec number off the name plate, usually found on the sloped bracket from engine to the Kohler. Example (961005C) and the gen set type; Example CCOPY67 or COPY or CCOPY. With this info I can give you the part numbers needed. On the CCOPY, Spec number (961015C) for instance. Those parts are listed in group 201 as 1. rotor # A258569 2. Stator $ 258393 3. Brush holder # 259275 4. Brush # 239282 then regulator part number has changed to #228602 Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 12:56 PM 8/6/2005 +0000, you wrote: >Does anyone have the current part #s for the Kohler Generator end >parts below. The gen is/was on a 35' FC 1982. Powered by Perkins 4 >cyl. The new owners of our coach wants to convert the gen back to >original equipment. > >1. Rotor >2. Stator >3. Brush holder >4. Brush > >Thanks. > >If you want to take offline use: wjmorganjr@... > >Billy Morgan >ex 82FC35 3208NA SB >ex Chesapeake VA > > > |
