					Propane Furnace in Kitchen
					07-31-2005, 21:40
					Steve, you can take it apart  and clean it real good. The probes can  be
			cleaned with a small wire brush- gently. The cut off valve - I believe in your coach is behind the refer outside panel. Ernie 83pt40 in cool Montana [Non-text portions of this message have been removed]  |
					08-01-2005, 01:18
					I have to remove the propane furnace under the stack of drawers in the
			kitchen to get to a water leak. Is there any preventative or routine maintenace I should do while it is out? Thanks, Steve Johnson Grand Rapids, MI '82 FC35  |
					08-01-2005, 01:45
					HI Steve:
			Other than checking for mud, gut's and beer in the unit, you can remove the local/remote sensor and igniter, clean it with a soft bristle brush, check the gap between the sensor and igniter ( 1/8th inch) and with a long soft bristle brush, clean off the beaver tail burner then re assemble. Check intake and exhaust tub for mud dobber nests. Check the wiring in general for abrasions cuts and lose connections. The fan motor is permanently lubed and sealed. Check the sail switch for freedom of movement. Caution: when replacing the unit back into it's space, double/triple check that the intake and exhaust tubes to be sure they went into the out side sleeves at least 2 1/4 inches to prevent Co2 problems. One can put it back in and it will seem to be in the right position but in fact miss those tubes. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions,, Oklahoma At 01:18 PM 8/1/2005 +0000, you wrote: >I have to remove the propane furnace under the stack of drawers in the >kitchen to get to a water leak. Is there any preventative or routine >maintenace I should do while it is out? > >Thanks, > >Steve Johnson >Grand Rapids, MI >'82 FC35 > >  |
