CHECK VALVE WB-40
07-16-2012, 06:39
CHECK VALVE WB-40
HI ALL
I wanted to know if anyone knows where I can get the check valve on a 1990 wb40
water fill ??where you hook up the hose
thanks
all help is appreciated
Jamie Brandt
1990 wb40
Florida
email JamieJBrandt@...
07-16-2012, 06:47
CHECK VALVE WB-40
I never did find a replacement for the OEM in my '84 FC. Ended up adapting
one off the shelf from Camping World.
Bob Griesel '84 FC31 WLII WA
On 7/16/12 11:39 AM, "Jamie" wrote:
> HI ALL
> wb40 water fill ??where you hook up the hose
> thanks
> Jamie Brandt
> 1990 wb40
> Florida
> Yahoo! Groups Links
07-16-2012, 08:34
CHECK VALVE WB-40
I replaced mine with a Shurflo unit. The old one was working fine, but it was 40
psi, and I wanted to bring it up to the pressure the water pump puts out.
Shurflo makes theirs in more than one pressure, and I chose to go to 65 psi.
I had to modify in two ways. First was to cut out some of the opening after the
old one was removed. Second was to cut off some of the new one at top and bottom
(it is a plastic housing) to fit in the chamber. It has been working fine for a
couple of years now.
Picture here: http://www.arcatapet.net/travel/bluebirds/shurflo.jpg I use brass
quick-connects on the fill hose.
Example of place to buy:
http://www.adventurerv.net/shurflo-press...960.h\
tml
Don Bradner
90 PT40 "Blue Thunder"
On 7/16/2012 at 6:39 PM Jamie wrote:
>HI ALL
>thanks
>Jamie Brandt
>1990 wb40
>Florida
>Yahoo! Groups Links
07-16-2012, 08:37
CHECK VALVE WB-40
Last summer I updated the water input on the bus. Mine was leaking, so I took the whole plastic unit out. Replaced with a non-regulator version on the bus which was brass and metal, then bought brass pressure regulators which I screw onto the hose I am filling with, and quick disconnects as well. Works like a charm. Bought my stuff at Tweety's:
Markus
Date: Mon, 16 Jul 2012 13:34:18 -0700
Subject: Re: [WanderlodgeForum] CHECK VALVE WB-40
I replaced mine with a Shurflo unit. The old one was working fine, but it was 40 psi, and I wanted to bring it up to the pressure the water pump puts out. Shurflo makes theirs in more than one pressure, and I chose to go to 65 psi.
I had to modify in two ways. First was to cut out some of the opening after the old one was removed. Second was to cut off some of the new one at top and bottom (it is a plastic housing) to fit in the chamber. It has been working fine for a couple of years now.
Picture here: http://www.arcatapet.net/travel/bluebirds/shurflo.jpg I use brass quick-connects on the fill hose.
Example of place to buy: http://www.adventurerv.net/shurflo-press...-1960.html
Don Bradner
>HI ALL
>thanks
>Jamie Brandt
>1990 wb40
>Florida
>email "JamieJBrandt%40yahoo.com"
>Yahoo! Groups Links
